Split drawbore pin. Help!!
Forum topic by jshattoc posted 02-02-2013 11:24 PM 804 views 0 times favorited 4 replies Add to Favorites Watch
View jshattoc's profile
jshattoc
13 posts in 2448 days
02-02-2013 11:24 PM
So today my FIL and I put my benchtop onto the base, and I pounded in the drawbore pins. And wouldn’t ya know it, #32 out of 32 split apart. Looking at it, I realize its my own fault: the grain was as curly as it comes. I’d like to get it out of there and repin that bit, but I’m at a bit of a loss on how to do it.
The top and base are doug fir, the pin is Borg red oak dowel stock. I think it made it to the bottom of the taper, and the split when it needed to go back to the “straight” part in the top. The depth is a bit of a guess, though, based on what the other pin in that tenon did. Straight stock made it through the 5/64 offset no problem. Whats the easiest way to get it out of there?
View nwbusa's profile
nwbusa
1021 posts in 2435 days
#1 posted 02-02-2013 11:48 PM
I’m assuming from your post that these are blind and not through pins. Is it glued in?
-- John, BC, Canada
jshattoc
#2 posted 02-03-2013 12:11 AM
yes, its a blind pin. Total depth would be 5”; this one went 2.5 at best. No glue at all, I’ll be moving at some point, and I want to be able to drill the pins out to help the movers. Is that my best bet here?
nwbusa
#3 posted 02-03-2013 12:36 AM
That would be my advice.
-- John, BC, Canada
View paratrooper34's profile
paratrooper34
915 posts in 3101 days
#4 posted 02-03-2013 12:46 AM
If you were planning on drilling it out later anyway, drill it out now. Of course that makes the draw boring advantage a moot point after that.
Not sure how you got your pins. If you have the ability to make your own, I suggest doing that. You get a much better product with straight grain all the way through. If you do not have a dowel plate, you can make one easily enough with some thick steel. You won’t have issues with pins splitting when you make your own.
-- Mike
