Slow setting glue
Forum topic by GT350 posted 02-02-2013 04:26 PM 1337 views 0 times favorited 9 replies Add to Favorites Watch
View GT350's profile
GT350
361 posts in 1854 days
02-02-2013 04:26 PM
I have a rather large piece of furniture I’ve been building. I need to glue it and there are a lot of joints, what slow setting glue do you like and what is considered slow setting?
Mike
9 replies so far
View gawthrrw's profile
gawthrrw
206 posts in 2320 days
#1 posted 02-02-2013 04:53 PM
Titebond extend wood glue has worked for me.
-- Rob, Dallas TX
View jdmaher's profile
jdmaher
417 posts in 2452 days
#2 posted 02-02-2013 04:59 PM
Titebond “Extend” has 15 minute open time, 20-25 minutes assembly time. But I like Titebond Liquid Hide Glue (water clean up), which only has 10 minute open time, but still has 20-25 minute assembly tiime.
I break down assembly to stages that won’t take more than 5 minutes with glue open to the air and no more than 15 minutes ‘til I have it clamped. And I actually rehearse that in a final dry fit, WITH clamping. That way, I get all the clamps and mallet and square and tape laid out for quick use after I apply the goop. If I have doubts about making it in time, I wait until I have a helper on hand.
Staged assembly really takes the time pressure off. And I can spend a few more moments getting things tight and square.
-- Jim Maher, Illinois
4827 posts in 2366 days
#3 posted 02-02-2013 05:02 PM
I ran into that last year, and wound up using liquid hide glue. It has a one hour working time, and can be reversed if you do screw up. First time I ever used it….it does have a long clamp time which was a little unhandy, but I guess you can’t have everything.
View SamuraiSaw's profile
SamuraiSaw
513 posts in 1837 days
#4 posted 02-02-2013 05:14 PM
I use Titebond 3 when I need extended assembly time.
-- Artisan Woodworks of Texas.... www.awwtx.com
View Loren's profile
9765 posts in 3521 days
#5 posted 02-02-2013 05:21 PM
Elmer’s white glue has pretty good open time
for furniture assembly. That’s what I used
for many years for interior work… or whatever
brand of white glue was available at the various
suppliers I bought from.
I’m using Titebond 2 “extend” now and it has
a long open time too. I use it because it
works well with hot presses though. In
cold clamping it doesn’t grab as fast as the
Elmer’s white glue, which can be annoying
if you are doing a lot of gluing and want to
take the clamps off sooner.
View Dallas's profile
Dallas
3599 posts in 2360 days
#6 posted 02-03-2013 01:51 AM
TB Comparison Chart
GT350
#7 posted 02-03-2013 06:21 AM
Thanks for all the reply’s. I think I’ll probably use the tight bond 2 and get a helper like was suggested.
View pintodeluxe's profile
pintodeluxe
5544 posts in 2686 days
#8 posted 02-03-2013 07:03 AM
I like Titebond II for most common projects, however I use Titebond II Extend for detailed glueups like chairs.
View Mark Kornell's profile
Mark Kornell
1169 posts in 2404 days
#9 posted 02-03-2013 07:21 AM
Urea formaldehyde glue. Either the powder you mix with water, or the 2-part. Open time of 30-60 minutes, depending on specific formulation. The drawback is that it takes overnight to cure, and it must be kept warm (at least about 70 degrees, depends on formulation) for that duration. It cleans up with water, but don’t breathe the power.
Another option is epoxy. You can find epoxies with long open times (West Systems, for example, makes a few), but generally not available at your local big box store. Epoxy odors can be an irritant (while curing), and cleanup is with acetone.
-- Mark Kornell, Kornell Wood Design
