Dremel scroll saw won't turn on
Forum topic by snuff posted 02-02-2013 09:29 AM 4387 views 0 times favorited 3 replies Add to Favorites Watch
View snuff's profile
snuff
2 posts in 1911 days
02-02-2013 09:29 AM
I bought a used 16 inch , model 1680, Dremel scroll saw on Craig’s List last summer. I checked it out before buying it and it seemed in good condition. It ran very smoothly and didn’t seem to have any issues. I haven’t used it since then, but I started a project recently where I would be using it. I’ve used it maybe 10 minutes, and today I was using it and it was working fine. I turned it off to move it and when I turned it on again it would not turn on. I’m not getting anything. No fan, no noise , just nothing. I don’t have I light bulb installed, I guess I could get one to see if anything is getting juice. My question is, is there some kinda of re-set button that I’m missing that could fix this problem? I checked the bushings and they seemed good. I lubricated it. I’m stumped. Don’t want to buy another one having barley used this one. Any suggestions? Thanks
3 replies so far
View RonInOhio's profile
RonInOhio
721 posts in 2833 days
#1 posted 02-02-2013 09:50 AM
Remove brush caps and check condition of brushes.
If the surfaces of the brushes that contact the commutator are rough,pitted,or less than 1/8”, replace them.
The brushes will wear unevenly usually. If one is bad, replace both. If you do replace the brushes, run the saw with no load (freely) for 5 minutes. This seats the brushes and will provide longer life for them.
Assume you already checked the outlet for power. Did you leave it plugged in when you moved it ? Is it the same outlet ?
Maybe the cord has an intermittment open in it and when you moved the saw , the cord moved and lost conduction.
Blow out the motor with compressed air.
Check wiring at the motor
Check Plug and cord for opens with a voltmeter. If everything else checks out, try a new plug.
If that doesn’t do it. Its could be the commutator in the motor is bad.
snuff
#2 posted 02-02-2013 02:57 PM
Thanks Ron. I got it to work yesterday. I took an air compressor and blew out the switch area. I was getting power to the switch. I plugged the connections, but that didn’t work until I blew the dust out. I’ll remember you advice in the future. I’m new to using a scroll saw and hopefully in the future your good advice will come in handy. Thanks.
RonInOhio
#3 posted 02-03-2013 09:39 PM
No problem.
I have heard of that before. Dust or critters getting into the switch box and shorting out the unit. Glad you found the problem and was an easy fix.
