Need advice on Table Saw
Forum topic by Jeff1968 posted 02-02-2013 09:25 AM 1881 views 0 times favorited 16 replies Add to Favorites Watch
View Jeff1968's profile
Jeff1968
4 posts in 2184 days
02-02-2013 09:25 AM
I’m new here and got the pcb270ts for Christmas and have yet to use it or even take it out of the box. I’m doing a new wiring project on my 12×20’ shed. I might go ahead and set it up for 240v or does it really matter? I don’t want to spend $2000 for a cabinet saw but I’m worried about the pcb 270ts not being a saw that can grow with me as I get into more advanced wood working projects. This is my first table saw so I’m sure it is good enough for now. Maybe this is a dumb question but I’ve read I can’t use moulding heads on this table saw. Can I still do cove cuts on the porter cable ts using standard 10” blades? Thanks in advance for any advice you can give me.
Jeff
I was looking at the Rigid R4512 table saw from Home Depot. I didn’t read in the owners manual that I can’t use moulding heads with it. Are the table inserts thicker then 1/8”. The porter cable 270ts uses thin inserts.
16 replies so far
View Howie's profile
Howie
2656 posts in 3164 days
#1 posted 02-02-2013 12:28 PM
check with knobscott. He can tell you all you want to know about this saw and a few things you don’t want to know.
-- Life is good.
View knotscott's profile
knotscott
8186 posts in 3617 days
#2 posted 02-02-2013 01:11 PM
LOL….what don’t you want to know?!
If you’re going to be running wire, I’d definitely include a 240v circuit (aka as 220v, but 240v is the actual). It can free up the 120v circuits for other things, allows bigger motors to be run, allows smaller gauge wire, and is more likely to deliver to full amperage during peak demands, which can prevent bogging and overheating.
The PCB270TS is one of a handful of entry level full size cast iron saws with belt drive induction motors (Ridgid R4512, Cman 21833, Steel City 35990CS are others). You bought into the right class of saw IMO….many of us mistakenly purchase cheap benchtop saws as a starter because of price. The PCB270TS is essentially a modified version of the former Hitachi C10FL that was also made exclusively for Lowes, and now includes a riving knife and better wheels….the fact that it says “Hitachi” or “Porter Cable” means very little. All of these saws are capable of good hobby work and furniture building with proper setup and blade selection, and are but none at the level of a 3hp industrial cabinet saw. All of them have pros and cons, and none offers all the “good stuff” in one package. All are in the range of 1.5hp (the 270TS is not “3hp”), all come with steel wings vs cast, all have somewhat weak fences. The PCB270TS in particular has what I’d consider one of the weaker fence in this class, but in fairness, it does seem to work. I’m also concerned about the non-metal gear used in the blade elevation mechanism. I probably would have suggested the R4512 over the PCB270TS, because I think the fence is a little better, it has a lifetime service agreement, 90 day return, and can be purchased for ~ $400 with a 20% off Harbor Freight coupon (it sometimes requires asking more than one manager or store, or getting HQ involved). Whether or not it’s worth returning and buying the R4512 is up to you.
Some table saw reading for you.
Please keep us posted on your decision.
View toolie's profile
toolie
2148 posts in 2870 days
#3 posted 02-02-2013 02:13 PM
if you paid full retail for that PC, and since it’s still in the box, i’d return it in favor of a 4512, for the reasons KS noted. @ $600, it’s overpriced for what you get , IMHO. a little effort with a harbor freight “20% off any single item” coupon at a HD will save you $100 on the $500 list price of a 4512. a net saving relative to the PC of $200 could go towards more shop tools. like the PC, the 4512 is a dual voltage saw.
View Tedstor's profile
Tedstor
1678 posts in 2874 days
#4 posted 02-02-2013 02:24 PM
As usual, KS covered the saw in expert detail.
Most hobbyists don’t have large table saws (i.e 3-5hp cabinet saws) . In fact, most of us use table saws that fall into the same general class as your PC. You might grow into a bigger saw in the future. But it’ll likely be because you want a bigger saw, not because you need a bigger saw. And there is certainly nothing wrong with that.
Your owners manual should indicate if moulding heads are compatible. However, I’d assume it can not accomodate moulding cutters. A router is probably a better way to go in any case.
I can’t think of any reason that larger coves could not be done on the PC with the right jig/sled. I think Rockler sells a cove sled for $50ish.You wouldn’t want to hog-out large coves in one pass though.
I personally wouldn’t return the PC for the Ridgid. I don’t think the Ridgid is appreciably better. And being a xmas present, I wouldn’t diss’ a gift only to exchange it for a saw with essentially the same characteristics. But thats just my opinion. And my advice is only worth what you paid for it ;)
##If you decide to return: Buy the Ridgid BEFORE returning the PC. Those 20% HF coupons are VERY hit/miss. I’ve tried to use them at both my local Home Depots. In both cases they basically told me to “F#$* off”. I even called the regional manager…...only to be told to “F^%$ off” again.They argued that Harbor Freight does not sell a comparable product. And I have to admit; that is true.
Now I’m sure these accounts of people successfully using them are 100% factual. I’m just saying that its not consistently accepted at every HD store. And HD seems to be getting more consistent in NOT accepting the coupon. Doesn’t hurt to ask/try though.##
View SamuraiSaw's profile
SamuraiSaw
515 posts in 2206 days
#5 posted 02-02-2013 02:32 PM
I agree with Ted, I’m not the least bit impressed with Rigid. Cove cuts are a definite possibility, but I doubt the molding head is.
-- Artisan Woodworks of Texas.... www.awwtx.com
117423 posts in 3819 days
#6 posted 02-02-2013 04:04 PM
I feel that knotscott is one of the best versed person’s on LJs re table saws so I would not take his opinion lightly.
I have not used or seen the saw you have but I have seen and used the Ridgid 4512 and feel it’s a great bargain for the money.
View JesseTutt's profile
JesseTutt
854 posts in 2352 days
#7 posted 02-02-2013 04:16 PM
If you are going to be running new electric I would suggest that you run 10-3 with ground to each outlet. For the time being you can tape the ends of the red wire and ignore it. If you decide you need 220 at that outlet then use the red wire and move the black to a 220 breaker. The incremental cost of the larger gauge (10 v. 12 gauge) and the third wire (red) is minimal compared to the cost of running the wire not to mention the cost of adding a circuit later.
Also, I would suggest you consider 4×4 (4 inch square) extra deep metal boxes at each location. This would allow more room for wire. I absolute hate the situation where the wire is extra short and I have to fight to get wire off of an old receiptcal and onto a new one.
Jeff1968
#8 posted 02-02-2013 11:33 PM
Thank you for taking the time to help me make a decision about my Christmas present. In reality the PCB 270ts was not the saw for my Christmas present but is what I exchanged my Skil $179 Christmas special table saw. Lol. I’m going to go ahead and keep the Porter Cable. Thanks again for all the help.
Jeff
runswithscissors
2928 posts in 2267 days
#9 posted 02-03-2013 05:20 AM
I would like to hear other opinions on the necessity for 3 wires for 220v. I see a lot (and have done so myself) of wiring that uses 10-2 or 12-2 (you don’t need bigger wire for 220v.—in fact, you can get away with smaller wire, though I never use less than 12-2). All you need to do with 12-2 is to tape or paint—or use a black felt marker—the end of the white wire. That’s to show that it is not being used as the neutral. The only reason I know of to use 3 wire cable is when you are going to have both 220v and 110v. on the same circuit, as on a kitchen range. I use 12-2 on all my 220 circuits and they operate just fine. There is, of course, a ground wire as well.
It really surprised me in Australia that all the outlets are 220v, and none have a ground. All simple 2 prong outlets. How do they get away without a ground wire?
Surely some LJ can give a definitive answer as to the 2 vs. 3 wire question?
View History's profile
History
399 posts in 2223 days
#10 posted 02-03-2013 03:34 PM
I feel that knotscott is one of the best versed person’s on LJs re table saws I’d have to disagree.
View Alexandre's profile
Alexandre
1417 posts in 2432 days
#11 posted 02-03-2013 03:43 PM
Why would you disagree Sawsucker?
I find his information extremely helpful..
-- My terrible signature...
History
#12 posted 02-03-2013 04:07 PM
Alex, in my opinion he knows his stuff to a point, but I feel that he’s a little too commercialized in some of his recommendations.
toolie
#13 posted 02-03-2013 09:59 PM
wow, what a surprise! somehow, i feel if we all agreed that the sun rose in the east, someone (who shall remain nameless) would take issue with that to.
SamuraiSaw
#14 posted 02-03-2013 10:10 PM
Scott provides some of the most unbiased reviews you’ll ever find. He consistently discusses tools in a factual manner without regard to brand loyalty. He’s far more credible than some folks around here.
Hey toolie….on a completely different note, my all time favorite question on the Newlywed Game was: In your neighborhood, does the sun rise in the North, South, East, or West? It was funny (in a sad sort of way) to see how many of the contestants would answer other than East!
Howie
#15 posted 02-04-2013 12:51 AM
Can you expound on “commercialized”?
Frankly I consulted him about a saw and he was spot on with his answers. He wasn’t trying to sell me anything or disswade me from buying it just what I could expect if I bought it. (which I did)
-- Life is good.
