Work surface that's resistant to wood glue.
Forum topic by Fridgecritter posted 02-02-2013 04:08 AM 16248 views 0 times favorited 47 replies Add to Favorites Watch
View Fridgecritter's profile
Fridgecritter
176 posts in 2079 days
02-02-2013 04:08 AM
Topic tags/keywords: jig question
I have Googled a little bit about this, but I figure since this forum is specifically for woodworking, why not pose the question here? I am building a cutting board gluing jig, and I was wondering if anyone had some advice on the work surface for the best medium to use that will be the most resistant to wood glue sticking.
I am thinking plywood with melamine after my brief bit of research, but maybe someone has a better idea? I know you could just suspend the work with clamps, but I really would like a make a jig that also keeps the bottom slats of endgrain wood level while drying, and be able to pick up the work off the work surface without it sticking.
Any ideas?
-- "Anyone can post a quote on the internet and attribute the quote to a famous person." -Abraham Lincoln
47 replies so far
View Grandpa's profile
Grandpa
3259 posts in 2639 days
#1 posted 02-02-2013 04:22 AM
wax paper
Fridgecritter
#2 posted 02-02-2013 04:24 AM
Yeah I could put wax paper down each time, or even use the sticky side of painter’s tape. I was more looking for a permanent solution that glue will not stick to. I guess my predicament is not unlike one that my old high school science teacher posed to us… He says, how do you find an acid that will eat through everything? What are you going to hold it in?
Grandpa
#3 posted 02-02-2013 04:30 AM
Melamine is not glue resistant but glue can be scraped off it many time before you need to replace it. Wax paper is good because you don’t have to scrape it. roll it up and trash it.
Fridgecritter
#4 posted 02-02-2013 04:32 AM
Well I got my answer for the melamine… thanks. I guess it’s gonna be wax paper or blue painter’s tape unless there exists some kind of surface I can use… maybe a silicon paint over the work surface?
10248 posts in 3611 days
#5 posted 02-02-2013 04:35 AM
Just apply paste wax to melamine and I think you’ll
find yellow and white glues pop right off with a chisel.
Fridgecritter
#6 posted 02-02-2013 04:36 AM
Another good suggestion. That is still an extra step though. My question is more of a no-step non-stick surface (if one exists) that maybe someone else is using already?
View mrg's profile
mrg
817 posts in 2963 days
#7 posted 02-02-2013 04:40 AM
Try one of those silicone cooking sheets. Nothing stocks to them and the new silicone paint brushes are all the rage.
-- mrg
Fridgecritter
#8 posted 02-02-2013 04:42 AM
That is an awesome idea! I will cut one or two to fit the bottom work surface of the jig and screw it down, ensuring the screws are recessed enough so they don’t hit the wood. Amazing idea.
View mds2's profile
mds2
310 posts in 1907 days
#9 posted 02-02-2013 04:46 AM
The top of my workbench is hardboard. Glue really doesn’t stick to it, or if it does it pops right up with a chisel. I’ve never had clamp down pressure between a work piece and the top directly, I’m just talking about drips and squeeze out, etc. I use wax paper too.
Fridgecritter
#10 posted 02-02-2013 04:48 AM
Jonathan I like that material too. I will see if they sell it on Amazon. 10 bucks a square foot is not bad at all.
View MT_Stringer's profile
MT_Stringer
3160 posts in 3194 days
#11 posted 02-02-2013 04:50 AM
The top of my workbench is white Formica installed over a solid core door. I use a razor blade scraper to easily remove glue from glue up projects.
Fridgecritter
#12 posted 02-02-2013 04:55 AM
I will probably go with this product here:
http://www.amazon.com/dp/B000FPD638
Fridgecritter
#13 posted 02-02-2013 05:03 AM
After reading the reviews, I think I will stick with a couple pieces of flexible silicon rubber like mentioned above. Thanks all for the ideas.
View Woodknack's profile
Woodknack
11478 posts in 2343 days
#14 posted 02-02-2013 07:28 AM
Yes melamine is glue proof and the glue will pop right off with a putty knife: yellow glue, white glue, contact cement, and spray glue (the last two wash off with solvent). Melamine is resistant to most any chemical you will use in a wood shop and by resistant I mean you can wash the stuff down with acetone/MEK/toulene/xylene/water/whatever 1000x and it won’t affect it. Melamine is also heat resistant to 400-something degrees and doesn’t melt until 600-something. I say all this from personal experience and decades working around melamine in the printing trade.
View AlaskaGuy's profile
AlaskaGuy
4042 posts in 2272 days
#15 posted 02-02-2013 07:44 AM
+1 for Rick M.
I’ve been use melamine for 20 years. Works as Rick says.
showing 1 through 15 of 47 replies
