Another stupid person not using splitter
Forum topic by steffen707 posted 02-02-2013 02:28 AM 2127 views 1 time favorited 34 replies Add to Favorites Watch
View steffen707's profile
steffen707
98 posts in 2262 days
02-02-2013 02:28 AM
Well its been a while since i’ve logged in. Wish it was because I completed something fun, but I had a close call today. shot a 8” piece of malamine 15 feet into my drywall. Its the small hole to the right of the 2 electrical boxes on the back wall. Left a pretty mark on the board too. Pretty sure i’ve seen this same exact arc cut from another guy on this forum when he shot a piece of wood into his belly. I was wearing saftey goggles so i guess i’m not completely stupid.
I’m thinking about buying a shark guard splitter now.
-- If you think it will take a week and cost $100, it will take a month and cost $400.
34 replies so far
View AandCstyle's profile
AandCstyle
3027 posts in 2226 days
#1 posted 02-02-2013 02:44 AM
Glad you weren’t hurt. I love my SharkGuard, but the time from order to delivery was an eternity when I ordered mine.
-- Art
steffen707
#2 posted 02-02-2013 03:17 AM
I was looking at some other posts and learned about the gripper by microjig. Looks like a pretty nice safety tool. I need to put a splitter on as well.
Funny how I just read that a push stick can raise the front of the piece causing it to want to kick back, which is exactly what I did.
View BroncoBrian's profile
BroncoBrian
438 posts in 1927 days
#3 posted 02-02-2013 03:32 AM
would a riving knife have prevented that? I am considering a Back saw for small boards like that to prevent the higher risk of kickback.
-- Bigfoot tries to take pictures of me
runswithscissors
2725 posts in 1994 days
#4 posted 02-02-2013 03:34 AM
I have always distrusted the push sticks that are no more than a notch in the end of a stick. If your pusher doesn’t hold down the board, the leading edge wants to climb the saw blade (strange but true, especially with short material). I only buy or make push sticks that have a significant extension going over at least 6 inches of the stock so I can hold it down at the beginning of the cut. Gives much better control, in my experience. You can make a very serviceable push stick with 1/4” (or thicker) ply. Cheap and disposable. Put a handle on that elevates your hand well above the blade.
View ajosephg's profile
ajosephg
1880 posts in 3530 days
#5 posted 02-02-2013 03:48 AM
http://microjig.com/products/grr-ripper/index.shtml would have prevented that.
They also make an after market splitter
-- Joe
View MonteCristo's profile
MonteCristo
2099 posts in 2157 days
#6 posted 02-02-2013 04:05 AM
Not using a splitter is only part of what went wrong here. At 8”, the piece of melamine is too f’in short to rip safely of a TS . . .
View Cosmicsniper's profile
Cosmicsniper
2202 posts in 3127 days
#7 posted 02-02-2013 04:09 AM
Bingo, MC. I’m using my miter sled for that cut.
-- jay, www.allaboutastro.com
steffen707
#8 posted 02-02-2013 04:50 AM
Cosmicsniper and montecristo, can you point me to a good miter sled, or did you guys just make your own?
View waho6o9's profile
waho6o9
8168 posts in 2546 days
#9 posted 02-02-2013 05:06 AM
View don1960's profile
don1960
227 posts in 2656 days
#10 posted 02-02-2013 05:38 AM
I feel your pain…..literally. I think I may be the guy you’re referring to that got hit in the belly. It does happen fast doesn’t it? I have the piece hanging on my garage door (shop door) to remind me all the time not to do stupid things. Here’s a picture.
That little piece of red in the middle of the cut is my DNA. I don’t know about the shark splitter, but have heard of the microjig splitter. Seems to be popular. Bottom line, get anything to help. My solution was to finally get a new tablesaw with a riving knife (Ridgid 4512). To be fair, my other tablesaw was a piece of crap.
Oh, and I see waho609 has posted a link to cutoff sleds. Definitely make one of those. Not only safer, but makes very accurate cuts easily. Very easy to build.
-- -- Don from PA
View EEngineer's profile
EEngineer
1102 posts in 3582 days
#11 posted 02-02-2013 12:25 PM
I don’t think a splitter would help in this case. Perhaps one of those splitters that curves way up over the leading edge of the saw blade would keep it from catching the teeth of the saw blade and circling back on the user?
Frankly, I don’t see how a sled would help either unless the sled has a clamp to lock down the piece as you are cutting it. It doesn’t look to me like the piece was “pinched” against the fence. As runswithscissors noted, there is always a tendency for a board to want to “climb” at the front end of the saw blade since the blade is traveling up at that point. Once it climbs a little, the teeth of the saw catch and turn the piece to throw it back at the user. The circular pattern on the bottom of this piece is pretty good evidence that is what happened. And a sled won’t help with that.
I haven’t used Grrrippers but I quite often use a featherboard on the fence to keep the stock tight against the table. I think that would have helped more in this case than a splitter or sled.
View lj61673's profile
lj61673
261 posts in 2368 days
#12 posted 02-02-2013 12:36 PM
A properly installed riving knife prevents this from happening. No other add on gimmick or hold down can do what a riving knife does.
View knotscott's profile
knotscott
7983 posts in 3344 days
#13 posted 02-02-2013 12:40 PM
A splitter is a good idea whenever possible. So is a ZCI…
16274 posts in 4187 days
#14 posted 02-02-2013 02:36 PM
It could have been worse…. you almost damaged your air conditioner!
View SamuraiSaw's profile
SamuraiSaw
515 posts in 1933 days
#15 posted 02-02-2013 02:43 PM
There are folks on here that brag about having a saw for years and the splitter and guard have never been out of the package. One of the reasons I updated my saw was to gain the riving knife and an improved guard.
-- Artisan Woodworks of Texas.... www.awwtx.com
showing 1 through 15 of 34 replies
