Rikon 10-325 assembly question
Forum topic by Sandra posted 02-01-2013 01:38 AM 2516 views 0 times favorited 5 replies Add to Favorites Watch
View Sandra's profile
Sandra
7207 posts in 2040 days
02-01-2013 01:38 AM
Topic tags/keywords: bandsaw rikon assembly question
For those who have a Rikon 10-325 bandsaw….
I’m in the process of assembling the base for my saw. I’ve followed the instructions, keeping in mind the issues that I had read about here – shelf not fitting quite right and the fiddling factor of getting the bolts in the corners. Despite that, it went together fairly quickly. And then I get to this line on page 8:
“6. Install the door on to the left end panel, and add the hex socket screw, bushing and nylon nut.”
I installed the door, and then I could not figure out where the screw, bushing and nut go.
I thought I must be tired, so I walked away and went back to it a few hours later. Still not a clue what I’m supposed to do with the socket screw bushing and nut. It would seem obvious that it has something to do with the door, but I’m missing it completely.
Here’s a picture of the stand so far. I’ve yet to tighten any bolts as per the instruction until I put the saw portion atop the base. I also noticed that I’ll have to put a piece of plywood under the base to allow the door to open over the lip of the shopfox mobile base.
I hate to continue without putting the socket screw where it belongs…..
Any suggestions would be greatly appreciated.
Thanks
Sandra
-- No, I don't want to buy the pink hammer.
5 replies so far
View ShaneA's profile
ShaneA
6909 posts in 2563 days
#1 posted 02-01-2013 02:11 AM
Been a long time since I put mine together. Just a wild guess, but could be for the knob/door catch assembly. There are a few contortion moves in the assembly of this saw. Seems like when it came time to mount the saw to the base I reversed the direction of the bolt/nuts, so the nut was on top of the base, made it easier to start. Good luck.
View DIYaholic's profile
DIYaholic
19596 posts in 2640 days
#2 posted 02-01-2013 02:52 AM
Good job ShaneA!!!
I just check the manual & would agree with ShaneA!!!
DIYaholic
#3 posted 02-01-2013 03:02 AM
I hope you are having fun assembling your saw.
It can get frustrating, but you know that & did the right thing. Walk away, regroup, come back to it.
I too needed to add a sheet of ply, to my mobile base. I also made the base square (if I remember correctly). This widened the narrower dimension, for added stability.
The items in question go on the door, at the same location as the knob.
Sandra
#4 posted 02-01-2013 11:09 AM
Thank you very much Randy! I’ll be headed out to the shop this morning to work on it.
DIYaholic
#5 posted 02-01-2013 01:16 PM
Anytime, Sandra, anytime!
Should you have more Q’s, ask away…...
I’ll do my best to provide a good answer!!!
