Delta Mortise Chisel Bit
Forum topic by DonJ posted 112 days ago 303 views 0 times favorited 3 replies Add to Favorites Watch
View DonJ's profile
DonJ
199 posts in 1698 days
112 days ago
The Freud bit set I’m using to build some cabinet doors resulted in extended tenons that are ~7/32” thick. I have a Delta Table top Mortising Machine, but the smallest chisel bit I have is 1/4”. Does anyone know of a source for smaller chisel bits? My only recourse is to drill and chisel out the mortises….oh, how I hate hand tools—lol. Thanks.
-- Don, San Antonio, TX
3 replies so far
View SCOTSMAN's profile
SCOTSMAN
4312 posts in 1756 days
#1 posted 112 days ago
Try ebay.Alistair
View CessnaPilotBarry's profile
CessnaPilotBarry
602 posts in 281 days
#2 posted 112 days ago
If you can’t find the bit, you could also rout the mortise with a 7/32” spiral upcut.
Another solution would be to pick up some 1/64” veneer, and add a piece to each side of the tenon, then cut the mortise with a 1/4” bit.
-- It's all good, if it's wood...
View crank49's profile
crank49
2289 posts in 1141 days
#3 posted 112 days ago
I was thinking veneer as well.
-- Michael :-{| Diapers and politicians both need to be changed often; and for the same reason.
