| Forum topic by Eddie | posted 112 days ago | 541 views | 0 times favorited | 11 replies | ![]() |
112 days ago |
Hi guys,
I am looking to add a dado set to my blade collection. I noticed that the manual says not to use a dado larger than 6”. Im assuming this is due to the power of the saw but wanted to ask if any one has had experience with larger dados on a saw similar to this one… |
11 replies so far
#1 posted 112 days ago |
Be afraid. Be VERY afraid of a dado head larger than 6” on that saw. -- bill@magraphics.us |
#2 posted 112 days ago |
I have the same saw. The limitation per the manufacturers manual says Maximum dado width is 1/2 in. and do not use a dado with a diameter larger than 6 in. Having got that out of the way, as long as the hole is 5/8ths for the arbor you can put what ever you want. The logic to this is that in reality you won’t need in most cases a dado blade that is more than 6 in in dia. since you won’t be cutting extreme dado channels. I do know from my saw that the 1/2 thickness is for the dado stack is predicated on getting the nut to engage and have at least a thread showing. So the dado package that I bought at Sears I can’t use all the blades together because of the width restrction. But I have found a new use for my old circular saw blades. I have taken a couple so far and used them like a dado blade. I hope this helps! -- Ken from Ft Hood, TX |
#3 posted 112 days ago |
My saw can spin an 8” and is limited to 13/16” width so I bought a full size set. -- Michael :-{| Diapers and politicians both need to be changed often; and for the same reason. |
#4 posted 112 days ago |
I bought an 8” and it was a big mistake. Saw handles it OK, it’s just that I can’t imagine ever needing the extra 2”. (Never thought I’d ever say something like that) -- Gene 'The true soldier fights not because he hates what is in front of him, but because he loves what is behind him.' G. K. Chesterton |
#5 posted 112 days ago |
Mee too Gene & Crank. After I got the 8” set I wondered why did I get that. I cant ever IMAGINE cutting a dado deeper than 1/2” anyway! -- Perform A Random Act Of Kindness Today ... Pay It Forward |
#6 posted 112 days ago |
Unless you have a constant need for dadoes that are more than 3” deep , you’ll be wasting your money. -- When did quiet and quite become the same word ? I'm guessing about the same time as your and you're did. |
#7 posted 112 days ago |
The safe bet is to follow the manual. I’d upgrade the regular blade while you’re at it….the saw’s performance is only as good as the blade, and it’s capable of better than what’s on there. -- Happiness is like wetting your pants...everyone can see it, but only you can feel the warmth.... |
#8 posted 111 days ago |
I have a 1998 model Jet 3hp cabinet saw and the owners manual says to use a 6” dado. The 6” is big enough for me although I have wondered why an 8” would be too much for this saw. Any thoughts. -- John, Kansas |
#9 posted 111 days ago |
I prefer 8” dados for one reason… SLEDS! Miter gauges suck… Most sleds of decent size have a 3/4” bottom, so, once you add the table thickness and sled floor, you sometimes need the extra wedding tackle to reach where you need to reach. That said, I’d never put an 8” dado on that saw. -- It's all good, if it's wood... |
#10 posted 111 days ago |
Thanks guys! |
#11 posted 111 days ago |
I have used the 8” nearly full height on a number of occasions, but I could see how someone could never need that much. Taking off that much material takes a lot of power, something a but lacking on these saws. I would agree that the 6” for that saw would cover your needs. |
| Forum | Topics |
Woodworking Skill Share
8794 |
Woodturning
223 |
Woodcarving
28 |
Scrollsawing
61 |
Joinery
81 |
Finishing
1534 |
3552 |
15793 |
Hand Tools
2037 |
Jigs & Fixtures
495 |
Wood & Lumber
2841 |
809 |
Focus on the Workspace
902 |
766 |
Woodworking Trade & Swap
2740 |
LumberJocks.com Site Feedback
1547 |
Coffee Lounge
6162 |
