Bees wax and mineral oil
Forum topic by Betsy posted 107 days ago 616 views 3 times favorited 13 replies Add to Favorites Watch
View Betsy's profile
Betsy
2826 posts in 2062 days
107 days ago
Topic tags/keywords: bees wax mineral oil
A quick question before I start my day job….
I want to try the bees wax and mineral oil finish for a few endgrain cutting boards. Is there a magic formula for how much wax to oil to use or is it a try it until you find the right fit?
Also, I do not have a double boiler so I was planning to use low heat on the stove top in a glass pan, is that okay or am I better off using the microwave on low heat?
Thanks in advance.
-- Like a bad penny, I keep coming back!
13 replies so far
View TheDane's profile
TheDane
2672 posts in 1829 days
#1 posted 107 days ago
Do you have two pans … one larger than the other? I have used a small sauce pan inside a bigger pan. Works as well as a double boiler.
—Gerry
View Manitario's profile
Manitario
1862 posts in 1049 days
#2 posted 107 days ago
don’t use direct heat unless you want to have a kitchen fire!
-- Rob, Sault Ste. Marie, Ontario
View PurpLev's profile
PurpLev
7729 posts in 1814 days
#3 posted 107 days ago
you should use a pot-in-a-pot (larger pot with water on the stove as the heating source, and smaller pot in the water with the wax+minural oil mix in it. – that is a make shift double boiler).
you should start with 50/50 let it cool, and see how that consistency works for you. I don’t think there is a ‘magic’ formula out there, but more what suits each person and their likes. more mineral oil will make it more liquidy but also more time to dry.
View JesseTutt's profile
JesseTutt
707 posts in 276 days
#4 posted 107 days ago
Here a video I bookmarked on making and using bees wax finish.
View Dallas's profile
Dallas
1867 posts in 653 days
#5 posted 107 days ago
I use a 2 oz. blob of beeswax melted into a 16 oz. bottle of mineral oil.
You can melt the wax in the microwave, but I usually just use a tin can in a pot of boiling water. The tin can will serve to store the wax in.
2 oz. of beeswax will harden the mineral oil to the consistency of Johnson’s paste wax.
To apply I warm the board in the oven to about 110-120°F and spread the wax on with an old scrap of Tee shirt.
place it back in the warm oven and warm it until the oil soaks in.
I do this 3 or 4 times rubbing in more wax on all sides each time.
Let it cool after the last coating/oven cycle then rub it to a beautiful soft sheen.
Just my way.
View Pdub's profile
Pdub
826 posts in 1346 days
#6 posted 107 days ago
The last time I made a batch, I put the bees wax in a glass jar and placed it in a pot of boiling water. The wax melted much nicer than when I used the microwave. The only problem I had is I didn’t heat the mineral oil with it so when I added the oil, some of the wax solidified. I just put the jar back in the boiling water and everything mixed.
-- Paul, North Dakota, USAF Ret.
View lew's profile
lew
8971 posts in 1921 days
#7 posted 107 days ago
glass jar in the microwave
-- Lew- Time traveler. Purveyor of the world's finest custom rolling pins!
View BinghamtonEd's profile
BinghamtonEd
652 posts in 535 days
#8 posted 107 days ago
I don’t have an exact ratio, but like Dal, mine comes out to a paste wax-consistency, I use a double-boiler setup. I buy little glass jars at Target or Chistmas Tree Shop and gave some out with the cutting board gifts.
View Emma Walker's profile
Emma Walker
539 posts in 276 days
#9 posted 107 days ago
Why couldn’t you just apply this when it’s still a warm liquid? Seems like it’d be easier. Nothings worse that trying to spread cold butter on a piece of bread.
-- I'm a twisted 2x4 in a pile of straight lumber.
Dallas
#10 posted 107 days ago
You can put it on while it’s warm but if the board isn’t warm it will immediately solidify. Kind of like pouring hot candle wax on an ice cube.
Mineral oil is nothing but paraffin and when you heat it it has a tendency to turn into paraffin. (Not exactly like, but it does change consistency).
View Brandon's profile
Brandon
3736 posts in 1117 days
#11 posted 107 days ago
I’ve used this stuff a ton and it works great. May be an option unless you prefer the stove process.
http://lumberjocks.com/reviews/2785
-- "hold fast to that which is good"
View lumberjoe's profile
lumberjoe
2394 posts in 414 days
#12 posted 107 days ago
This works best for me:
1 – buy small crock pot. You can get a Rival one at walmart for under 10$
2 – Buy a bottle of mineral oil and some beeswax
3 – Dump the whole bottle in the crock pot. add 25% wax by volume
4 – heat it on LOW until you have a clear liquid
5 – Let the oil cool a bit. I use a candy thermomoter and try to get it down to about 100 degrees
6 – pour the mixture back into the bottle with a small funnel.
The next time you go to wax a board, you life will be so much easier. Throw some water in your crock pot and toss the closed bottle in the water. It’s best to use a clear bottle so you can see the wax/oil liquify.
It’s expensive, but I like to use the general finishes butcher block oil. It’s really just mineral oil, but it is much lower viscosity than the drug store stuff. I find I use a lot less because it penetrates better. The pour spout is nice as well
Here is my oil/wax mix ready to be heated and squirted
Also I would never recommend using a microwave. It’s impossible to tell how hot you are getting the oil, and it will never heat evenly. you could be asking for a lot of trouble if you get it too hot.
-- http://www.etsy.com/shop/KandJWoodCrafts
Betsy
#13 posted 107 days ago
Wow – I didn’t expect this many responses. Thanks for all the tips. I’ll let you know how I come out. Hopefully I will be posting my first project in a very long time.
Thanks all!
