What size is a biesmeyer
Forum topic by noweyrey1 posted 138 days ago 364 views 0 times favorited 8 replies Add to Favorites Watch
View noweyrey1's profile
noweyrey1
20 posts in 965 days
138 days ago
what size is the guide tube on a biesmeyer fence? 2×3 or 2×2.5”? I cant find the specs online. thanks
8 replies so far
View toolie's profile
toolie
1202 posts in 825 days
#1 posted 138 days ago
buy one locally, measure it and return it.
View MarcusM's profile
MarcusM
31 posts in 1177 days
#2 posted 138 days ago
Mine is 2×3; there is, or used to be different grades of the Biesmeyer fences and I don’t know if the tubes were the same size on the lower grade models.
Mark
-- Tilbilly Mark
View Tenfingers58's profile
Tenfingers58
58 posts in 874 days
#3 posted 138 days ago
Why go to the hassle of buying / returning? Just take a ruler or tape to the store and measure it there. Don’t forget to measure the wall thickness. You don’t want to crush the tube when clamping the fence in place.
Thicker wall tube is more expensive but won’t crush under clamping pressure. Outside dimensions are the same.
Maybe just to be on the “safe” side take your fences with you to be sure they fit.
Do you want to sell the fence you don’t use? PM me.
toolie
#4 posted 138 days ago
DUH!!! sometimes, the blatantly obvious just escapes me.
View Underdog's profile
Underdog
182 posts in 232 days
#5 posted 138 days ago
This series of videos shows you how to make your own fence rails, and gives you the sizes needed:
http://www.youtube.com/watch?v=W1kEZ9Pforo
View stevejoly's profile
stevejoly
2 posts in 254 days
#6 posted 138 days ago
Just finished making some rails… The commercial line is 2×3 the more entry level one is 2×2. Entry level is the wrong word… The factory angle iron was a little small I think it was 2×2 so on ours we used 2.5×2.5 and it worked very nicely.
noweyrey1
#7 posted 137 days ago
Thanks for the video link. I may end up having to do this because the fences I have dont seem to fit standard size rails. Appreciate the feedback.
Tenfingers58
#8 posted 136 days ago
What I think I would try at this pint would be to cut a slightly larger than “rail size block” on the table saw, then keep trimming until the width fits the fence. The height isn’t really that important as long as it’s over 2”.
Once you have a block size that works, measure it and then you know what you need.
Standard steel sizes available here are 1.5 1.75 2.0 2.5 in square and rectangular.
If one of these sizes don’t work for you, it may be metric. I’ve never seen metric tube available, but I’ve never looked either.
Call a local steel supplier. Most are willing to help if you know what you need.
If the rail IS metric, you could glue, tape, or weld a strip of sheet to bring it to the required dimension.
It may be easier (and cost effective) to buy the rail from whomever made the fence.
