Jointing legs to slab
Forum topic by watermark posted 01-31-2013 08:30 AM 1930 views 0 times favorited 11 replies Add to Favorites Watch
View watermark's profile
watermark
483 posts in 1812 days
01-31-2013 08:30 AM
Topic tags/keywords: question joining
I am in the process of making a coffee table with a cross cut slab of Albizia about 3” thick similar to this table.
the table in the pic I used 4 biscuits to join each leg to the slab but I made it for my self so if the joint fails it just part of the learning curve the table I am making is to sell so I want to make sure I do it right. IS a biscuit jointer the right way to go about it or is there a better method.
Thanks for any help.
-- "He who has no dog, hunts with a cat" Portuguese proverb
11 replies so far
View TCCcabinetmaker's profile
TCCcabinetmaker
932 posts in 2224 days
#1 posted 01-31-2013 08:40 AM
Honestly, I would think doweling would be a better way to go.
-- The mark of a good carpenter is not how few mistakes he makes, but rather how well he fixes them.
View Bill White's profile
Bill White
4816 posts in 3830 days
#2 posted 01-31-2013 04:37 PM
Mortise and tenon joinery will give ya a strong joint. Through wedged tenons might look cool.
Bill
-- bill@magraphics.us
View Marcus's profile
Marcus
1161 posts in 1889 days
#3 posted 01-31-2013 06:59 PM
I agree with both the posts…a through M&T joint would look very cool and a dowel would be a considerably easier and strong solution too.
View Cosmicsniper's profile
Cosmicsniper
2202 posts in 3028 days
#4 posted 01-31-2013 07:03 PM
Yep, dowel or M&T for that one. Love the wedged tenon idea!
-- jay, www.allaboutastro.com
View rockindavan's profile
rockindavan
299 posts in 2505 days
#5 posted 01-31-2013 08:38 PM
I have used dowels in a similar situation and it is still going strong. You could use multiple dowels for more strength. Just drill the holes you want in a piece of plywood then use that as a template for table and legs so the dowels line up correctly.
View RussellAP's profile
RussellAP
3103 posts in 2156 days
#6 posted 01-31-2013 08:59 PM
I’d use a colorful wood dowel even if I have to turn it myself. I’d use aluminum or steel dowels under the table to give strength where it would not show. In fact I’m designing my living room furniture out of 8/4 walnut and plan to use 8/4 on the legs which will be more of a teardrop design and plan on steel dowels to join it.
View crank49's profile
crank49
4028 posts in 2840 days
#7 posted 02-01-2013 02:38 AM
Dowels, big ones, or floating tenons.
watermark
#8 posted 02-01-2013 06:13 AM
Dowels it is… The wood I have for the legs is not long enough for the tenons. I have 3 more slabs from the same stump and plan on trying through mortise and tenon joints on the next one. Thanks for the advice.
116804 posts in 3447 days
#9 posted 02-01-2013 06:17 AM
If you have room for dowels you have room for a loose tenon.
View nwbusa's profile
nwbusa
1021 posts in 2156 days
#10 posted 02-01-2013 06:24 AM
Basically the same concept, just different shapes.
-- John, BC, Canada
#11 posted 02-01-2013 06:30 AM
Yes and no, loose tenons can have much more mass to them than dowels have making them much stronger.
