| Forum topic by trice | posted 1717 days ago | 7825 views | 0 times favorited | 28 replies | ![]() |
1717 days ago |
Topic tags/keywords: tools chisels tool Hey guys, I am putting together some tools for traditional wood working and need some chisels. Problem is there are so many out there I don’t know which to get. I also am on a budget, so I need some suggestions.Should I : 1)Get a set of the blue handled Marples, which have pretty good reviews and quite reasonably priced? Most say they are pretty good and would make good entry level chisels. 2)Get a little better set (my budget is max $125.00) For instance C.I. Falls look pretty nice at traditionalwoodworker.com. 3)Get 1 or 2 high quality chisels of say 1/4” and 1/2” to get started with and then add 1 or 2 chisels here and there as need to finally complete a top quality set. Ok guys, which should I do. Also if you have suggestions on paticular brands of chisels that would be helpful too. Thanks guys |
28 replies so far
#1 posted 1717 days ago |
Coming from a woodcarver of about 6 years, I would suggest starting out with just a couple of chisels. I made the mistake of buying a set of knives when I first started. I thought cool now that I have knives I can carve. Out of the set of 10, I might use 5. I would suggest buying a couple of chisels and start with that. After carving for a while, you will see which other tools you will need. As for the brand, I believe it is personnal choice. -- Twenty years from now you will be more disappointed by the things that you didin't do then by the ones you did. - Mark Twain |
#2 posted 1717 days ago |
You are going to get a lot of different answers than mine, and I’ll probably get pummeled… lol… but here it goes… I bought a 5-set package of chisels from sears about 10 years ago for $20. Nothing fancy. I’ve used them in construction and pounded the heck out of them. When I want to do something fine in the shop, I sharpen them and they work terrific. I may be seriously missing out on some other “Super carbon double rolled laser guided triple titanium max epoxy bonded japanese master chisel”...(for a thousand bucks)..lol.. but mine still work great- for twenty bucks. I’m a firm believer in the fact that you don’t have to have something really expensive to have it work correctly. It’s your own confidence and practice that makes the tool work. Just my .02cents… -- As iron sharpens iron, so one man sharpens another. (Proverbs 27:17) † |
#3 posted 1717 days ago |
the Blue Marples are pretty good and are not too expensive – make sure you get those that are “made in england” though! another brand that got good reviews are the Czech Republic’s Narex – they sell them at LeeValley and Amazon Also Rockler is having this special for Japanese Chisel Set but I wouldn’t use those on a normal day-to-day basis -- ㊍ When in doubt - There is no doubt - Go the safer route. |
#4 posted 1717 days ago |
The Marples would be fine, think about sharpening…I have a double sided DMT 3×10 600/1200 which is a great stone ( not really a stone ) for the bench…it’s also wide enough for a sharpening guide if you wanted at some point …...for plane blades and such.. -- If knowledge is not shared, it is forgotten. |
#5 posted 1717 days ago |
Thanks for all the replies guys. I am starting to lean toward getting a set of the blue marples. This will like you said get me started.After a while I will probably have a better idea of my needs then I can upgrade. I could still keep the Marples for backup and maybe rougher jobs that I wouldn’t want to use high dollar chisels on. |
#6 posted 1717 days ago |
I love my 4 chiesel set of Marples. They hold and edge and aren’t that hard to get sharp. -- Adrian ..... The 11th Commandment...."Thou Shalt Not Buy A Wobble Dado" |
#7 posted 1717 days ago |
The again, just when I think I have made a decision I read another tool review somewhere and I change my mind. Good grief! And to think, my last relpy sounded so level headed. LOL! |
#8 posted 1717 days ago |
I have considered getting 2 cherries chisels. Seems like from what I read these were really good quality. Maybe start with a 1/4 and a 1/2 inch pair. I don’t know. I am just trying to be careful. I have bought tools before that ended up being junk and a waste of money and am determined not to do this. I have also bought cheap tools before only to end up upgrading very soon afterwards which was also a waste of money. Obviously with money getting tighter and tighter and everything costing more and more I want to be careful about what I spend my hard earned money on. I definately don’t want to end up with cheap, low quality tools. That being said, I don’t want to buy anything just cause its expensive. Ok guys, I’m done rambling. |
#9 posted 1717 days ago |
I suggest learning to sharpen the chisels before buying something expensive. |
#10 posted 1717 days ago |
I have Pfeil Swiss Made chisels and I love them. Check out Woodcraft.com you can order them ala cart or as sets. They hold an edge and have a great feel to them. FFW just did a chisel review in the SEPT/OCT 2008 issue and the Pfeil came in runner up (best overall was Lie-Nielsen). A set of 4 cost $110 -- Brian, Folsom, CA http://www.brianfullerdesigns.com |
#11 posted 1717 days ago |
Thanks guys. I think I am gonna go with the 2 Cherries. The Pfeil chisels do look nice as well. If you were gonna buy say 2 to get started with, what size would you recommend? I was thinking 1/4 ” and mayybe 1/2” or 3/4”. Any suggestions. I guess I am asking if you could only have 2 chisels, what 2 sizes would you get? Appreciate all the info. |
#12 posted 1717 days ago |
1/2” is a for sure, then you need to decide if you are going to work in to very small places (ie dovetails/narrow mortises) if yes then 1/4” will be great other wise look at somethinging wider…. While learning to sharpen the 1/4” is a big challenge as it is very easy to rock side to side and put a camber on the blade…. -- //FC - Round Rock, TX - "Experience is what you get just after you need it" |
#13 posted 1717 days ago |
You have had some good advice on the posts. I will just reinforce what several have said. Even the most expensive chisels need some work. First, always flatten the back. I mean down to where it shines like a mirror. then the bevels. (plural). Whether its scarey sharp, waterstones, whatever. I have a Veritas MkII jig, and I love it. I don’t believe those who say they can get a consistent bevel by eye alone. As to size, I would get a 1/4, 1/2, 3/4, and 1” -- "non illegitimis carborundum" |
#14 posted 1717 days ago |
I agree withyou that there is alot of good advise here. This is why I love this site. Everyone is very helpful and kind. Alot of sites would just give you alot of flaming and very little info. I will definately need to look into a good system for sharpening. Also with the steel being so hard, the 2 cherries will probably be more work to sharpen but should also hold an edge very good. Thanks alot guys |
#15 posted 1717 days ago |
Trice, since budget is a concern for an entry level set, I’m going to chime in with SteveKorz, but toss my hat in for the $25 basic set of Stanley Fat Max chisels. ( Individual pieces run from $8 to $18 up to 2”) I have the full set from 1/4” to 2”. The Fat Max with the full through tangs are made in both China and in England, ,but typically the sets are of Chinese origin, and the individual pieces are from Sheffield England. Look closely at the package if the source matters for you. My initial surprize was that the Chinese set had a very useable edge fresh from the package. seemingly better than the English versions. They’re readily available at the blue ‘borg store’. They’re inexpensive enough that you won’t be afraid to use them. They have an edge guard that snaps in place to protect the individual chisel. I like the handle size with combo plastic and rubber grip for a better fit in my medium / large and sometimes sweaty hands. Take the money you’ve saved and follow cmadea’s advice on a good sharpening jig and stones. I honed a couple of sizes that had the misfortune of falling on the concrete floor, they take a good edge and seem to hold it well. Good luck with your journey. Q -- I don't make sawdust...I produce vast quantities of "Micro Mulch." |
| Forum | Topics |
Woodworking Skill Share
8798 |
Woodturning
224 |
Woodcarving
28 |
Scrollsawing
61 |
Joinery
82 |
Finishing
1536 |
3554 |
15805 |
Hand Tools
2039 |
Jigs & Fixtures
496 |
Wood & Lumber
2846 |
810 |
Focus on the Workspace
903 |
766 |
Woodworking Trade & Swap
2741 |
LumberJocks.com Site Feedback
1547 |
Coffee Lounge
6165 |
