Zero clearance insert for TS
Forum topic by BJODay posted 01-30-2013 09:35 AM 1446 views 0 times favorited 5 replies Add to Favorites Watch
View BJODay's profile
BJODay
527 posts in 2181 days
01-30-2013 09:35 AM
Topic tags/keywords: table saw zero clearance insert craftsman
Last spring I purchased a Sears Craftsman Hybrid table saw. I love it. It was a great step up from a +40 year old craftsman. It works well for my small projects.
I’m looking for a zero clearance insert for the saw. It has a granite top so the insert is a heavy metal plate that clips in place. I have not been able to find a zero clearance for this model. (351.221161). Does anyone know if there is one available. Has anyone tried to manufacture their own?
Thanks for any help.
BJ
5 replies so far
View bondogaposis's profile
bondogaposis
5151 posts in 2589 days
#1 posted 01-30-2013 01:33 PM
Easy to make your own.
-- Bondo Gaposis
View BentheViking's profile
BentheViking
1782 posts in 2802 days
#2 posted 01-30-2013 01:58 PM
I have the Porter Cable 220 TS, which all over the internet I see the biggest drawback is you can’t buy a ZCI and because of how its made it is impossible to build one. I finally figured out last week that if I get an extra couple of the stock inserts I may be able to take a piece of hardboard or mdf and glue it to the underside of the insert plate with a slight recess for the thickness of the insert so that everything is flush on top. Not 100% sure if it would work for my situation, but the reason I mention it here is I would think that this could be a way that it could work on any TS that doesn’t have a stock ZCI available.
-- It's made of wood. Real sturdy.--Chubbs Peterson
View IrreverentJack's profile
IrreverentJack
727 posts in 3081 days
#3 posted 01-30-2013 03:19 PM
Bondo’s right BJ. Not hard to make. These inserts for a Steel City saw might work.
Ben, JimH had a post on that insert about a year ago. -Jack
View PurpLev's profile
PurpLev
8548 posts in 3886 days
#4 posted 01-30-2013 03:42 PM
From the sound of it, it’s the same saw as the Rigid 4511 with the granite top and the SteelCity equivalent which all share the same blade insert.
I made a few inserts from phenolic here: http://lumberjocks.com/PurpLev/blog/8111 (seems like the pictures are no longer available, and I’ll try to repost them later tonight). you can make your own inserts. can be done using the saw + router, or the saw + files/sanding. Or you can try and find the Steel City inserts for sale and/or equivalent.
BJODay
#5 posted 02-09-2013 02:49 AM
Found the proper insert at peach tree, made by Steel City. Thanks for the help.
BJ
