| Forum topic by simmothewoodturner | posted 116 days ago | 615 views | 0 times favorited | 9 replies | ![]() |
116 days ago |
Topic tags/keywords: question lathe woodturning I was wondering if the titanium nitride coating on the sorby tools was actually worth it, or would it be better just to buy a standard tool due to a slightly lower price? -- http://www.simmothewoodturner.blogspot.co.uk |
9 replies so far
#1 posted 116 days ago |
Guess if can sharpen HSS, TN, & tungsten cutters that go with Sorby’s Turnmaster tool might prove more economical than carbide cutters. They sell a sharpening jig, guess can make your own. http://www.woodturnerscatalog.com/p/7/2/31/131/-/5728/Robert-Sorby-TurnMaster-Turning-Tool http://www.woodturnerscatalog.com/p/7/2/31/131/-/5726/Robert-Sorby-TurnMaster-Cutter-Holder http://www.robert-sorby.co.uk/turnmaster.htm While nice kit, more into cutting than scraping so probable would not buy a Turnmaster tool and cutters. -- Bill |
#2 posted 116 days ago |
I don’t know because I’m not a turner, but I’m interested in this as I have some TiN coated mortiser chisels from Axminster. -- Do or do not, there is no try |
#3 posted 115 days ago |
Question – What happens to the all the different coatings as soon as the tool is sharpened? :o[ -- *Arachnoleptic*: The frantic dance performed just after you've accidently walked through a spider web. |
#4 posted 115 days ago |
I have TN coated forstner drill bits and sharpen with diamond file and my dremel tool with HF diamond coated bits for spurs. Have no way of knowing how many microns sharpening away but know removed TN coating where am sharpening. TN coated tool all about thickness of the coating. How thick is the TN coating on these cutters and on your Axminster chisels? People do use credit card diamond hones to touch up edge on their carbide cutters doubt they know how many microns of carbide removing. Here are sharpening instructions from Turnmaster instruction sheet. 2. High Speed Steel (HSS) 3. Titanium Nitride (TiN) Tungsten Carbide tips can be sharpened using diamond abrasives -- Bill |
#5 posted 115 days ago |
I just got the sorby Turnmaster. it has interchangeable cutter heads. I have the round and square head made from titanium case hard carbon steel, the best in other words. These heads cost 16$. They aren’t for taking out huge amounts of material, I like a HSS round nose scraper for most of my lathe work, it takes more time but there are less gouges and mistakes that can take the wood off the chuck. -- Failure does not stop me, it makes me try harder..... because I'm crazy. |
#6 posted 115 days ago |
My guess is that it is more about marketing than anything else. -- Dwight - "Free legal advice available - contact Dewey, Cheetam & Howe"" |
#7 posted 115 days ago |
I agree with MONTECristo it’s anopther way to part the needy from their hard earned poppy.I guess a nice looking useless gimmick as the cutting edge when sharpened will be devoid of the coating as it will be removed as it is sharpened.A|s simple IMHO as that. Alistair -- excuse my typing as I have a form of parkinsons disease |
#8 posted 114 days ago |
I think to answer your question how successful are the drill bits that are coated. IMHO not successful and as for sorby’s turnmaster the tool looks very bulky at the business end.Regards Tamboti -- Africa is not for sissies |
#9 posted 114 days ago |
once sharpened the coating is removed. with regular drill bits the coating still helps minimize heat and friction caused by the side of the drill as it goes into deep holes, but with lathe tools I’m not sure how much of a benefit you’ll get from it given that the first time you’ll resharpen the edges the TiN coating will be lost. I wonder how Sorby is marketing this -- ㊍ When in doubt - There is no doubt - Go the safer route. |
| Forum | Topics |
Woodworking Skill Share
8798 |
Woodturning
224 |
Woodcarving
28 |
Scrollsawing
61 |
Joinery
82 |
Finishing
1538 |
3556 |
15816 |
Hand Tools
2039 |
Jigs & Fixtures
496 |
Wood & Lumber
2847 |
810 |
Focus on the Workspace
903 |
766 |
Woodworking Trade & Swap
2742 |
LumberJocks.com Site Feedback
1547 |
Coffee Lounge
6166 |
