Unisaw switch mounting question
Forum topic by snowstorm posted 01-13-2013 08:47 PM 1828 views 0 times favorited 9 replies Add to Favorites Watch
View snowstorm's profile
snowstorm
6 posts in 1918 days
01-13-2013 08:47 PM
Hi
I’ve just acquired a unisaw, and would like to remount the switch from its current position which is attached to the cabinet. I’m finding that I have to reach under the fence rail to get at it more than I would like.
I noticed there is a large threaded hole on both the underside of the cast table, and in the unifence rail itself.
Is this intended to mount the switch, on a short piece of threaded rod, or threaded conduit type of pipe?
Photos attached of what I’m referring to. If anyone would be so kind to post a photo of how their switich is mounted this way it would be much appreciated.
Thanks in advance
9 replies so far
View MonteCristo's profile
MonteCristo
2099 posts in 2154 days
#1 posted 01-29-2013 07:46 PM
I put a Uniguard on my Unisaw. The switch is mounted on the guard structure and is very handy to get at. Delta makes this add-on but it ain’t cheap !
View hairy's profile
hairy
2655 posts in 3497 days
#2 posted 01-29-2013 08:19 PM
I think this is the switch I’m using. They say memory goes first, I can’t remember. The box and the pipe came from Lowe’s.
-- My reality check bounced...
View joeyinsouthaustin's profile
joeyinsouthaustin
1294 posts in 2038 days
#3 posted 01-29-2013 08:57 PM
I used a twist bracket my supplier found for me to mount from one of the table bolts. just to give you ideas, If you prefer the switch on the left side. optimum body position puts the switch on the left side, to function as a true bump switch for me.
-- Who is John Galt?
View Scot's profile
Scot
344 posts in 3361 days
#4 posted 01-30-2013 11:52 AM
The hole in the uni fence rail is intended for the switch.
-- If the old masters had power tools, they would have used them. So get off your damn High Horse.
snowstorm
#5 posted 01-31-2013 04:40 PM
Thanks for the replies. I noticed that this bracket came with some parts along with my saw.
Is this meant for holding the switch box, or if not, would you know what it is for?
thanks again
View BUBBATAY's profile
BUBBATAY
57 posts in 2279 days
#6 posted 01-31-2013 04:54 PM
Snow storm i believe it was a bracket for keeping the arbor from moving when it was shipped
snowstorm
#7 posted 01-31-2013 05:26 PM
Thanks, wondering what that red bracket was for
joeyinsouthaustin
#8 posted 01-31-2013 10:55 PM
If you look at my pic, that is the red bracket attached to the backing plate holding my switch box. It is attached using the table leaf bolt at the top, and to the side of the backing plate at the bottom. I drilled an extra hole to attach it to the backing plate. I puts the switch in a great spot for me. Just proud of the fence rail, and right in line with 6” above my knee.
View b2rtch's profile
b2rtch
4851 posts in 3014 days
#9 posted 01-31-2013 11:00 PM
THIS IS HOW I MOUNTED THE SWITCH ON MINE.
-- Bert
