Watco Butcher Block oil and Finish - Funky after-taste on foods
Forum topic by camps764 posted 01-29-2013 01:20 PM 9676 views 0 times favorited 6 replies Add to Favorites Watch
View camps764's profile
camps764
867 posts in 2264 days
01-29-2013 01:20 PM
I know there are tons of opinions on the right way to finish a cutting board. I bought this Watco stuff a while back to use on some end grain boards, it worked nicely, left a nice finish. I think the boards ended up as decorations in my dad’s home and are not daily users.
I decided I wanted a “live edge” cutting board made from a Walnut off cut.
Sanded it down, cut it to shape, followed the finish routine.
Let it cure for a week. Used it to cut some food and I swear I could still taste the finish.
Let it cure for a few more weeks, used it to cut some fresh bread, still could taste it.
Let the loaf of bread sit on it overnight, cut side down to preserve it, cut the bread on a different board, and the end piece of bread still tasted like the finish.
Took the board back to the shop and will be stripping it and refinishing with mineral oil/bee’s wax.
Anyone else experienced this?
Does it just take months to fully cure and not taste disgusting?
I like the way it looks, but I don’t think I will be using this stuff for anything that will handle food ever again. Nasty!
-- Steve
View lumberjoe's profile
lumberjoe
2894 posts in 2152 days
#1 posted 01-29-2013 02:32 PM
I tend to stick with Mineral oil and beeswax. It looks just as nice, easier to apply, and easy to re-apply. Looking that the MSDS for that stuff, it contains Xylene and Stoddard solvents (Mineral Spirits). It’s possible it could take MUCH longer to cure depending on temperature, air flow, etc.
View Gene Howe's profile (online now)
Gene Howe
10114 posts in 3332 days
#2 posted 01-29-2013 03:05 PM
Having never used (or seen) a Watco product designed for finishing surfaces that will contact food, my observations might not be worth 2 cents. However, I have used their products on many other projects and have found that the odor lingers for months, years even, when it’s closed up, like a box interior.
JMHO, I’d never use it on any food prep surface.
Behlens makes a food safe finish. I’ve used it on bowls and candy dishes, but I’m not sure it would hold up well on a cutting board.
Lumberjoe has it right.
View SnowyRiver's profile
SnowyRiver
51457 posts in 3384 days
#3 posted 01-29-2013 03:09 PM
I tend to stick with mineral oil and beeswax too. I used to use Watco on a butcher block table we had but nothing that regularly comes in contact with food. Howard’s (sold at Rockler) makes a good mineral oil and beeswax finish for bowls and cutting boards.
-- Wayne - Plymouth MN
Gene Howe
#4 posted 01-29-2013 03:13 PM
View RussellAP's profile
RussellAP
3103 posts in 2191 days
#5 posted 01-29-2013 03:59 PM
The Watco Butcher Block is combustible which means they added a dryer to it. On end grain it gets sucked deep into the wood, mineral oil and bees wax is much better.
camps764
#6 posted 01-29-2013 11:06 PM
Thanks guys…appreciate the perspectives…I don’t do a lot of the cutting boards, but will default to mineral oil and bee’s wax from here on out.
-- Steve
