Setting tool bars in handles
« back to Hand Tools forum
Forum topic by socrbent posted 109 days ago 343 views 0 times favorited 3 replies Add to Favorites Watch
View socrbent's profile
socrbent
123 posts in 435 days
109 days ago
Topic tags/keywords: question maple lathe joining
I have turned 4 maple handles for 1/2” bars. Using the mortising attachment for my drill press, I’ve created 3” mortises for the bars. The bars slide in to the mortises with little free play.
My question is what is a good method to epoxy the bars in place? My fear is if I place epoxy in the hole that the bars will push a pool of expoxy to the bottom of the mortises and prevent the bar from seating. Or if I apply the epoxy to the bar that most will be scraped off as the bar is seated making a weak joint. Do I use a longer but smaller bit to drill a hole deeper into the handle or possibly a relief hole from the side of the handle into the bottom of the cavity in the handle.?
-- socrbent Ohio
3 replies so far
View crank49's profile
crank49
2276 posts in 1136 days
#1 posted 109 days ago
Take a V shaped corner chisel and make a groove in one or more of the flat sides of the mortise to provide a relief path for the excess epoxy to come out when you press the bar into the hole.
Or, rotate the handle 45 degrees and make another mortise in the same hole. Will now be an 8 sided star shaped mortise. The grooves will all fill up with epoxy anyway and hold the bar in place.
-- Michael :-{| Diapers and politicians both need to be changed often; and for the same reason.
View hairy's profile
hairy
1763 posts in 1698 days
#2 posted 109 days ago
A tight fit will cause problems. The air in the hole needs to get out for the tool to go in. I make the holes slightly deeper than I need to give excess glue a place to go. Squeezeout is a good thing.
I like how you did the square hole. Thanks for showing it.
-- It must be jelly baby, cause jam don't shake like that...
socrbent
#3 posted 107 days ago
Thanks for the suggestions. I have chosen to drill a small relief hole in the side. Have mounted one bar and that worked great.
-- socrbent Ohio
