Softwood VS Hardwood
Forum topic by Holbs posted 01-29-2013 03:28 AM 3099 views 0 times favorited 16 replies Add to Favorites Watch
View Holbs's profile
Holbs
1869 posts in 2029 days
01-29-2013 03:28 AM
in my ongoing education of wood working (chisels, sharpening stones, which screws to use, power tool reviews here, etc).... now comes the confusing topic. softwood vs hardwood.
i’ve researched this weekend about which wood is ideal for lifting and holding up 100-200lbs machinery: torque values, density, compression values for a utility project i have going on (i’m still working on my retractable wheels, entering phase2!). i’ll share my thoughts to others who are starting out in wood working.
the first sentence of every comparison is the vocabulary: softwood and hardwood are misleading. example: balsa (the kind of wood for model airplanes) is classified as hardwood but i wouldn’t want to build a desk out of it.
poplar (hardwood) to pine (softwood): pine has more density than poplar, yet it is labeled softwood? even the standard douglas fir (softwood) is more dense than either poplar and pine by a fraction. when it comes to strength, i’m learning not rely on vocabulary.
i know there are other things to consider like grain pattern, mold resistance, knots, how it takes liquids, the weight, how it fairs with turning or sawing tools, how easily it dents, etc. i guess the real test is to just buy various types of wood on my journey to be a more experienced wood worker.
some helpful insights for engineer guru’s who understand formula’s:
http://www.fpl.fs.fed.us/products/publications/several_pubs.php?grouping_id=100&header_id=p Wood as an Engineering Material
http://www.engineeringtoolbox.com/wood-density-d_40.html
The density of seasoned & dry wood
and a couple billion other links.
-- The Carpenter Bee is derived from the Ancient Greek word wood-cutter
16 replies so far
View Zboom's profile
Zboom
72 posts in 2354 days
#1 posted 01-29-2013 03:51 AM
I was told that deciduous trees are classed as hardwoods and coniferous SE softwoods. Im not 100% sure this is correct but does seem to have some clout once you think about it.
-- Michael, www.facebook.com/flatlandersww
View bbasiaga's profile
bbasiaga
1233 posts in 1994 days
#2 posted 01-29-2013 03:56 AM
I have read the classification the same was as Zboom has it. Most homes are built out of ‘soft wood’, right? The stuff you get from lumber supply yards. Its still pretty strong. But it dents easy so not the best choice for certain projects. I’ve built a flip top cart out of cheap home depot wood and ply…its holding together just fine with about 125lbs of tools on it. Actually, I keep my small jointer in the bottom and that adds another 65lbs…plenty strong.
-Brian
View BentheViking's profile
BentheViking
1782 posts in 2563 days
#3 posted 01-29-2013 03:59 AM
check out nick gibbs real wood bible for a good introduction to a lot of things about wood
-- It's made of wood. Real sturdy.--Chubbs Peterson
View MonteCristo's profile
MonteCristo
2099 posts in 2188 days
#4 posted 01-29-2013 04:16 AM
Hardwood vs softwood has nothing to do with how hard or soft the wood actually is. The terms are used to distinguish trees based on the two fundamentally different types of basic cell structure. Softwoods are a much simpler (and more ancient I believe) type of tree than hardwoods, which have a much more complex cell structure.
More often than not, a given hardwood will actually be fairly hard, harder than many/most softwoods, but not always. Also, most softwoods are needle bearing evergreens, and most hardwoods are deciduous and leaf bearing. But there are exceptions here also.
Hence the confusion.
Once again, I recommend R. Bruce Hoadley’s seminal book “Understanding Wood”. A must read for any serious woodworker.
Holbs
#5 posted 01-29-2013 04:43 AM
am i wrong to suggest using douglas fir as a carcass structure frame only, would be the most bang for the buck? again, i’m just talking more of a utility wood than a presentation wood.
and i read that chestnut trees were wiped out in the early 1900’s by some scourge or something? all the remaining ones are on their last legs then POOF, gone forever?
View crank49's profile
crank49
4030 posts in 2970 days
#6 posted 01-29-2013 05:00 AM
The history of the Chestnut is a long and interesting read in itself.
The few remaining Chestnut trees all reach a certain size then die.
Another sprout may come back from the roots and develope into a tree but it will also reach a certain size and then die.
People are working to try to save the Chestnut by genetically altering its resistance to the blight that infected the species.
View ScottinTexas's profile
ScottinTexas
108 posts in 1947 days
#7 posted 01-29-2013 05:07 AM
I only recently heard about the sad tale of the chestnut trees from someone who knew quite a bit about it – they were part of some society to preserve them. I believe one approach is to cross them with some Chinese variety that is reistanct to the blight.
View Mark Kornell's profile
Mark Kornell
1169 posts in 2530 days
#8 posted 01-29-2013 05:08 AM
Holbs, for a structure frame any construction-grade lumber would probably be your best bang for the buck. Douglas-fir is likely a bit more expensive per board-foot, but maybe not by much.
You haven’t shared any details about your project and how you are planning on constructing it. Most woods, soft or hard, could be used to support 200 lbs. Balsa excepted. How you construct it is more important.
For example, I built a table to put my 90-lb planer + in/outfeed tables on. The unsupported span is about 78 inches. Made from standard 2×4s, primarily spruce. The Sagulator says I’ll get about .01” of total sag. It is way overbuilt for what it needs to hold up, could probably support upwards of 500 lbs.
And, according to Hoadley, the differentiation between hard and softwoods is the type of seed pod. Hardwoods have closed seed pods (think acorns and walnuts) whereas softwoods have open seed pods (think pine cones).
-- Mark Kornell, Kornell Wood Design
ScottinTexas
#9 posted 01-29-2013 05:12 AM
As has been stated, deciduous versus non-deciduous is what I’ve learned recently myself.
(I’m still trying to get open vs closed grain straight.)
I found a neat chart here: http://tinytimbers.com/janka.htm
I ran across another that was more information-rich – let me see if I can find it….
Here we go:
http://www.woodbin.com/ref/wood/strength_table.htm
Holbs
#10 posted 01-29-2013 05:15 AM
iguana… look in my workshop (or maybe it’s my blog) about my retracting wheels project (i actually added a 3rd cross piece to lower the wheels at equal height). it’s from a compound lever design. it might be rather excessive JUST to raise/lower your machine… but i have time and i love levers and gears :)
and then, i plan on creating something similar to the planer infeed/outfeed mobile table like this one by christopher merrill: http://christophermerrill.net/ww/shop/PlanerStand.html
or i could use my small jointer with this type of infeed/outfeed table, or drill press, bandsaw, etc.
Holbs
#11 posted 01-29-2013 05:18 AM
scott… after all this research, i think i’ll get a 2×4 of alder and a 2×4 of beech. whack both on my head. then pick :)
View pintodeluxe's profile
pintodeluxe
5660 posts in 2813 days
#12 posted 01-29-2013 05:21 AM
The compression strength of most lumber far exceeds anything that will be stored on a bench. It is the racking force you need to account for. This can easily be accomplished with shouldered tenons, and a little bracing. Fir is a suitable material.
View bondogaposis's profile
bondogaposis
4727 posts in 2351 days
#13 posted 01-29-2013 02:36 PM
Zboom is correct. Softwoods are confers, like pine, fir spruce, cedar, etc. Deciduous trees are generally considered hardwoods, think, oak, maple, cherry. There are exceptions to all rules. For instance larch is a deciduous conifer. It’s wood is similar to fir and is considered a softwood. Some of the hardwoods are evergreens, like Pacific madrone and live oak. It really comes down to conifers vs broadleaf trees and has little to do with actual hardness. The best way to understand hardness is to use the Janka scale. It is a test that measures how much force is needed to embed a .444” steel ball halfway into the surface of a piece of wood. Here is a link to the Janka wood hardness chart.
-- Bondo Gaposis
Zboom
#14 posted 01-29-2013 03:54 PM
Holbs, please post a video if you decide to do that, lol!!!
Mark Kornell
#15 posted 01-31-2013 05:33 AM
Holbs,
I looked at that mobile cart design. I like the compound lever idea, gonna file that away for future use.
I didn’t need a mobile base for the planer – I wanted to put it on a table above the jointer. (Jointer is already on a mobile base.) So, long, unsupported span. A torsion box might’ve been OK, but I figured construction studs were easier and probably cheaper. Pic:
BTW, beech is considerably harder than alder. Alder is slightly softer than Douglas-fir. But I’d still watch the video…
