Pockethole joinery: joining panels at 90 degrees?
Forum topic by Brett posted 109 days ago 610 views 0 times favorited 9 replies Add to Favorites Watch
View Brett's profile
Brett
603 posts in 848 days
109 days ago
What is the best way to join panels at 90 degrees (for a cabinet) when using pocket holes? Kreg sells a couple clamps that appear to do the job, but are there better (and cheaper) alternatives?
-- More tools, fewer machines.
9 replies so far
View SnowyRiver's profile
SnowyRiver
45571 posts in 1645 days
#1 posted 109 days ago
IMO I would buy the Kreig pocket hole jig kit. It makes it very easy and if you get the complete kit you would get the clamps, drill bits, drivers, and screws.
-- Wayne - Plymouth MN
View renners's profile
renners
1871 posts in 1134 days
#2 posted 109 days ago
Pocket screws will pull a piece out of position when tightening.
You can get around this by cramping the two pieces together really tight before you put in the screws. I’ve used parallel clamps and sash cramps to good effect.
-- Do or do not, there is no try
View Purrmaster's profile
Purrmaster
401 posts in 258 days
#3 posted 109 days ago
Kreg sells a “right angle clamp” for just that sort of thing:
http://www.lowes.com/pd_194999-39450-KHC-RAC_0__?productId=3115809&Ntt=kreg&pl=1&currentURL=%3FNtt%3Dkreg&facetInfo=
I bought one. It works. But it doesn’t work as smoothly as their videos would lead you to believe. It really should be longer. And it can be a pain to get it into position in the pocket hole.
But it does work and has strong clamping pressure.
View BinghamtonEd's profile
BinghamtonEd
652 posts in 534 days
#4 posted 109 days ago
I’ll second what renners said, just clamp it in good and tight, then put the screws in. It also helps to have a few right-angle clamps on-hand (just use shop-made ones).
View waho6o9's profile
waho6o9
2876 posts in 742 days
#5 posted 109 days ago
View muleskinner's profile
muleskinner
550 posts in 601 days
#6 posted 109 days ago
I’ve used the Kreg Jr along with rennners’ clamping advice on 1/2” and over panels and have never had a complaint. I found out on one of my first practice joints to be careful not to over torque. I haven’t seen any need for any clamps other than the generic bar and pipe clamps I already have available.
-- Visualize whirled peas
View pintodeluxe's profile
pintodeluxe
1731 posts in 978 days
#7 posted 109 days ago
You might consider dados too if you have access to a router table or table saw with dado blade.
On their own, dados might not be the strongest joint, but they are a great help when it comes to aligning case goods. A glued dado does lend significant rigidty to a project.
Don’t get me wrong, I like pocket holes too. I use them all the time. The dedicated Kreg clamps really work better than a simple F style clamp.
BinghamtonEd
#8 posted 109 days ago
I was thinking more along the lines of this (a bit cheaper and quicker when you need several of them) :
View weldoman's profile
weldoman
34 posts in 222 days
#9 posted 109 days ago
1 1/2” Angle iron comes in handy , it’s just the right height, Wont cover the pocket holes.
-- missouri, dave
