Plunge router issue
Forum topic by Betsy posted 01-28-2013 06:32 PM 865 views 0 times favorited 6 replies Add to Favorites Watch
View Betsy's profile
Betsy
3391 posts in 3802 days
01-28-2013 06:32 PM
Topic tags/keywords: trammel
Okay – this is a little bit of a rant caused by frustration. I’ve been out of the shop a long time and am working on small projects to get myself back in the swing of things. I want to make some of these trivets http://lumberjocks.com/projects/78314 which Nelson has done such a nice job on. I’ve made the jig which was quite easy however, I am having issues getting a trammel made for the plunge router.
Now I know I’ve done this before but it seems that I can’t get the screw holes to line up after I’ve drilled them. I’ve used the router plate to mark and drill the holes but whenever I go to put in the screws it seems as though my holes have moved!
Does anyone have a bit of wisdom about what I am missing in this process? It seems so simple but obviously I’m not doing something right.
Here is the rant part—- why don’t they make routers with holes through the top to attach to a trammel – seems like such a simplier solution than trying to attach something from the bottom.
Thanks in advance.
-- "Our past judges our present." JFK - 1962; American Heritage Magazine
4881 posts in 2400 days
#1 posted 01-28-2013 06:42 PM
If you’re using twist drills to drill the holes, they may be wondering from your mark…a drill press would help with this. But you can do it free hand with brad point bits as well. Just a guess…..
Betsy
#2 posted 01-28-2013 06:55 PM
Hum that’s a simple thing. I was using a twist bit. It’s all these little things you forget when you are out of the shop. Thanks Fred.
View pintodeluxe's profile
pintodeluxe
5568 posts in 2720 days
#3 posted 01-28-2013 07:00 PM
1+ use brad point bits or forstner bits. Much better results.
View Loren's profile
9963 posts in 3554 days
#4 posted 01-28-2013 07:01 PM
Sometimes when I want very precise relationships between
holes (usually not in wood) I’ll centerpunch my markings,
double check the punch distances with a dial caliper,
then drill the first hole with a 1/16” bit. Then I check
the distance of the hole to the other centerpunch,
then drill the next hole, adding a bit of “english if needed
to compensate for the first hole not being perfectly
located.
Once the two holes are drilled, I enlarge them with
a larger twist drill.
View lew's profile
lew
11943 posts in 3662 days
#5 posted 01-28-2013 08:51 PM
To keep the holes from moving, after I drill them, I usually tape them in place with duct tape, Betsy.
Just kidding!
Anyway, there are a couple of other things you can try- along with the brad point bits. I have clamped the router plastic base onto my workpiece and used the holes as drill guides to mark the centers. Another thing, if you have them, are the self centering bits used to drill holes for hinges. Not certain if the diameter of the “centerer” would be the correct size to fit your router base.
View Mark Shymanski's profile
Mark Shymanski
5621 posts in 3619 days
#6 posted 01-28-2013 11:46 PM
Did you flip the router plate over? While this doesn’t change the topological relationship between holes it can mess with which hole we think matches the hole in the router…hole 1 to hole 1a hole 2 now orients in such a way that it doesn’t line up with 2a or even 3a.
