Shaving Giraffe - a shave horse re-design from Africa
Forum topic by RobynHoodridge posted 110 days ago 988 views 1 time favorited 19 replies Add to Favorites Watch
View RobynHoodridge's profile
RobynHoodridge
38 posts in 495 days
110 days ago
Hello all.
I’m a designer. So when i see something i’m automatically assessing it. “Why is it made that way?” “Is there another way?” “Could it be easier, lighter, different or specifically suited to some conditions?” So as i’m embarking on making myself a small bench which will hold wood in place while i work it, i’m obviously giving the shaving horse (and bodgers’ horse) the same mental analysis. And i think i’ve found another way.
.....Now this is where i need your help. Telling me whether the concept is a stallion or a stallion’s manure. Cause i’m a designer who’s never sat at a shaving bench.
Specific elements could also be commented on. For instance, are wheels good or bad? etc..
And if the concept is strong, let’s develop the product together here as a community. So it can serve us all.
Re-inventing the … horse?
Okay, not re-inventing. But finding another type.
Like finding out how great a motorcycle is for getting through traffic faster when everyone else is at a standstill in their cars. Or if we all still rode horses, wouldn’t it be awesome riding a giraffe instead? Bigger strides, seeing above the traffic. More horse-power.
Basically, the traditional shaving horse employs cantilever action to apply a strong force and clamp the work piece in place. Your feet work the clamping mechanism, which is great because then you have your hands free. You’re sitting, so you’re more rested and those legs are free to use for the clamping. It’s an ingenious, simple principle. But what if we could achieve the same thing without any awkward leg levering at all? And get a better clamping action while we’re at it?
.....What’s the worse way a real horse could pin you down? – Standing on you? Or sitting on you? They’ll both work, but i think i’d rather not be clamped down by being sat on. So why not apply our own weight to clamp the work piece down, instead of our leg action?
.....And that’s really all the difference there is between the shaving Horse and the shaving Giraffe that is the design concept i present here. I’ve lost the legs, and used the cantilever arm as legs instead. The weight of the unit and the amount of the user’s weight they choose to put on it force that cantilever arm to rotate on the pivot point and the other (business) end to clamp down against the body. Just like it does in the shaving Horse. But you’re sitting on a clamp, instead of sitting on a bench which has additions and changes that make it also be able to clamp something in place.
I made this model quickly to show you generally how the mechanism would work.
There’s a clamping head that comes down upon the work piece. There’s a wedge shaped piece that is the other clamping surface (if you want to include it in the design). There’s a seat on the body of the shaving Giraffe. All just like the shaving Horse.
The design with and without a wedge that changes the ‘angle of attack’.
I have lost the rear legs too, in my version. And this end of the vice bench gets propped up on something suitably high. Like a tree stump, box, bench, vehicle wheel, etc.. Though there’s nothing to say that your version couldn’t have rear legs to your liking.
Two legs good, four legs bad.
Having no rear legs, the design can be more compact (see below). But the thing is, you’re going to need something to support or prop-up that end of the Giraffe. Granted, the broad spacing of the front legs will give the bench sideways stability, so that almost anything can be used at the rear. But it’s still a requirement to have a something else. Don’t know if that’s a crippling flaw. Maybe it would be better with permanent rear legs?
.....Unlike the shaving Horse with its foot operated swing arm though, the height of the rear support isn’t really prescribed at all in the Giraffe design. That means you could use whatever’s available. But it also means that the seat height is ‘adjustable’. Want to sit higher? – Find a longer log. Want to adjust it to use by different persons? – possible. Junk like shavings piling up under the bench? – no problem for this design. Uneven floor? – no jamming of foot levers cause there aren’t any.
.....Well, i say above that you “need” a rear support to prop up the back end of the bench part. But you’ll see in the picture below that the whole thing could actually work without it. Albeit perhaps less comfortable to sit / work at. Because there’s no foot operated lever system below the bench, anything goes.
Yoga pose – Legless Giraffe.
And this leads me to maybe the biggest reason that i like the Giraffe concept more than shaving horses. It’s that i think the whole foot operated lever system that we use to date is awkward. I’m sure the bodgers who first used shaving horses as they set up shop in a forest; who had to make everything from scratch; and who had no design software or time saving tools to allow them time to contemplate their design, were very proud of employing the cantilever principle. And they should be. But we’re not in their position, and i think we can do even better.
.....Pushing with your legs (on a shaving Horse) is surely bound to unsettle your seated position. And this while you’re trying to work the wood. If it doesn’t literally shift you, you’re using lots of (back) muscles to achieve both of the actions simultaneously without shifting. Right? Well the Giraffe doesn’t have this issue. You just sit.
.....You can still vary the force of the clamping, if this is even necessary, by the force you exert sitting on it. And though this also uses muscles, they’re your legs. Which are used to the necessary action, and stronger than your back.
.....I’m sure the clamping force can be altered in other ways too. The relative lengths of the cantilever sides. Or how far forward (how much directly under you) the rear support is placed. Or just how far forward / back you sit.
The rear support in three different positions – to differently support the user’s mass.
Using the front legs as the levers also means that the clamping force is being applied more directly down upon the work piece. This may be an academic advantage of the Giraffe design. I don’t know if work pieces slip in shaving Horses because of this. But it’s one thing that led me to think of a better way, so i want to mention it.
With the lever’s pivot below the clamping point in a shaving Horse, the forces are actually more easily transferred in a direction that would push the work piece toward the person. And the swing arm is always trying to reach around, over the top, and in that way be able to apply the force downward. But in the Giraffe design the pivot is way back behind the clamping head, and with straight (=simpler) swing arms the force applied is very close to straight down upon the work piece. And this translates to better clamping. Not just because of the greater pressure that the Giraffe has the potential to apply, but also because of how it is applied.
Simpler IS better
I say above that we can do better. But better isn’t more complicated. The Giraffe has many similarities to the horse, only it’s even simpler. But with (what i think is) a stronger basic principle.
I made the model you see in the pictures from ‘lumber’ of one size. Which let’s say, were it made at full scale, could be something as easily accessible as 2 b’ 8 inch stock. So the Giraffe retains all of the ease of production that i think has made the shaving horse a foundational tool.
Stabling
There’s no getting around it, the giraffe is longer than the horse. You’re gonna need more working room for it to stretch its legs.
But there’s an up side. More specifically a straight up, vertical side. In that it’s easy to make the design of the Giraffe incorporate the ability to fold on itself, and become easy to stow away vertically and flat. Against a wall say. There are take-down shave horses. But here it’s already a function of the fundamental design.
Collapsed and dismantled versions of the shaving Giraffe.
Awkwardly stretched out to drink
Ever seen a giraffe drinking? With its legs splayed apart so it can reach down to the water? I think that’s what the splayed apart shaving Giraffe looks like.
.....And in the same way as the giraffe’s feet need to get further apart for it to be able to lower itself to drink, the distance between the front and rear ‘resting points’ of the shaving Giraffe (front legs and back of body) needs to increase in order for the clamping action to happen. Slightly. The legs need to move slightly. To facilitate this action, would the front legs be better with wheels on them? I’m almost sure they’ll slide on the ground enough to accomplish clamping. But what do you think? Or maybe the rear contact point should move?
Reaching the tips of the longest branches
Even in my first mockup model (pictured), a long, straight, work piece can fit in the Giraffe since it clears the pivot bar, and runs un-interrupted till it would meet the ground (see pic). So even long stock can be positioned to comfortably work on the tips.
A long (black) work piece can be accommodated.
But in revisions of the design there needn’t BE a continuous bar accross the width of the Giraffe the way i have in the model. Some arangement such as individual bolts at each leg would free up the centre space, and allow tweaks to the design. Such as a steeper angle of the wedge and therefore work piece.
Knowing the Arse End of a horse
I’ve made my little model in the English style (as opposed to the Bodgers style). But there’s no reason that the Giraffe couldn’t also be made both ways. In my mind, by basically just swapping the orientation of the body of the horse around, you could use a single leg that clamps down in the middle of the work area.
Horseing around
So that’s my revision of the shaving horse. If you have the inclination to horse around with the concept, and maybe make a version yourself, please tell me how it goes. And if an idea reared while you were reading this, please let me know. Even if it isn’t something that ends up working with the design, it might spawn an idea we can run with.
-- Never is longer than forever.
19 replies so far
View MattADK's profile
MattADK
16 posts in 554 days
#1 posted 110 days ago
Very cool!
-- Matt
View Rick M.'s profile
Rick M.
1455 posts in 545 days
#2 posted 109 days ago
This is interesting but I suggest making a life size version along with a traditional shaving horse and actually trying them out.
-- -- Rick M.
View woodsmithshop's profile
woodsmithshop
918 posts in 1711 days
#3 posted 109 days ago
you will have to stand up to change your clamping position
-- Smitty!!!
RobynHoodridge
#4 posted 109 days ago
Woodsmithshop, you’ve brought up what i think is the biggest thing to address.
You may not need to stand up completely. Just take up your body weight with your legs. I agree this could be too much to ask the user to repeat for very long.
But that’s for a version of the design concept where one’s weight is (the seat is) far forward of where the rear support holds up the Giraffe. How about if we move that forward to be directly under, or nearly under the seating position. Maybe even resting on a see-saw point – something much like a saw horse with an apex. Then a slight shift of ones weight backward (rolling on ones bum, so no standing up required) would release any clamping force. Maybe even counter the clamping that’s a result of the mass of the Giraffe?
RobynHoodridge
#5 posted 109 days ago
What i’ve thought about the release of the clamping action so far is that it might be functional to have handles on the end of the swing arm that clamps down. These are used to push up and out against, and counter the clamping force to open the vise. Especially if the ratio of the swing arm sides is around 1:1 this action should be quite easy. More so if you’re not lifting your own weight because of the positioning of the rear ‘legs’ as i suggest above.
This way the clamping action is ‘on’ most of the time (automatic state) and ‘off’ only when it needs to be, when changing orientation of the work piece.
There is another way. I hesitate to even mention it because i like how simple the Giraffe could be. But there could also be included a foot operated lever to lift the bench up and release the clamping force. Maybe a part of the bench, or maybe a separate device. Think of those old manual operated railway platforms with the dual pump up and down action cantilever to make them go. You stand on one side and the other pushes up on the bottom of the Giraffe.
I prefer the first ideas though. But as Rick M. says, i may need to have it in full scale to test that.
woodsmithshop
#6 posted 109 days ago
as far as the raising up of ones body even a small amount would get tiresome, especially, even though I am only 21, my knees are 70, and they would not like very much of that.
I realize you are trying to develop a more efficient method, and I appreciate that you are innovative.
but I think if your efforts were to be used to come up with a higher leverage method in the existing shaving horse design, then it would not take so much downward pressure with the legs to clamp stock. the existing design has proven over many years to be very efficient. maybe just an improvement on the clamping force. I have watched Roy Underhill work on a shaving horse many times and he changes the position of his work quite often, and standing or rolling back would result in lost time, imo , he seems to be able to change stock position quickly almost without losing a stroke.
-- Smitty!!!
RobynHoodridge
#7 posted 109 days ago
You’re right, i wouldn’t want to be continually doing squats.
Does he change the position of the work for every type of activity at the shaving horse? Or might the horse suit one type of activity and the giraffe another? Like holding down something that’s being chiseled or carved from only one side.
But i still think there’s a way to make the giraffe cycle quickly through clamping.
I’m not trying to replace the horse. I think we’ll be better off also contemplating other options. Which might be better for certain things.
There is a much better lever system than just a straight leg for the more typical shave horse style bench. Have a look at what Bob Slade has done here – http://www.forestofavonproducts.co.uk/news/stanford-shave-horse
I mean besides the standing aspect of it. Which i think is great, but isn’t what i want to point to. The ‘triangular’ extension of where the foot ‘pedal’ is should let you use your weight rather than muscles, and should rotate the force around and over the work piece better. Also allows a longer lever for greater force.
Rick M.
#8 posted 109 days ago
It seems like you are trying to improve something you haven’t used. The German dumbhead has been around for centuries with very little modification and for good reason; the English style is a tad newer but works on the same principle. That’s why I suggested you make working models and actually use them. Awhile back two prominent woodworking authors set out to modernize the shaving horse, unfortunately I can’t find the video at the moment, and what they came up with was pretty cool but very complicated and in the end I didn’t see that it worked any better. Don’t get me wrong, I’m not trying to dissuade you just encouraging you to build and use the horses so that you know what works and what doesn’t.
-- -- Rick M.
RobynHoodridge
#9 posted 109 days ago
Thanks Rick. No, i get it. Don’t worry. And you’re right of course i should build it. Them. Many iterations.
But i can’t. Not right now.
Different folks have different approaches to product design. I can usually see a lot of what’s going on even before the thing’s built. (what works and what won’t) And so work through a lot of changes before anything’s spent on prototypes. For now i’m looking for help on just this. The concept. I know they’re maybes. But that’s how i like to work – dealing with all the maybes first. Someone working a different way, like those prominent woodworking authors you mention say, might create something quite different just because of difference in that approach. Complicating it for instance.
Also, because i’m not developing a product for my own gain (not selling them and won’t own the intellectual property), I’m not going to do all the development through to perfect before i tell the world about it.
And thinking of ALL the possible versions is something i want to promote too. Shelling out a finished product that we don’t have to have considered possibilities on would leave something that people either take up or don’t. Instead of something like “Hey, that version sucks because of X, but if i replaced that with Y it’d be great.”
So i know i should build it. But not yet. And i will definately report findings when i do.
View JJohnston's profile
JJohnston
1394 posts in 1456 days
#10 posted 108 days ago
I’m skeptical. I think you need to push/brace with your legs, for the equilibrium, whether or not the leg force is being used to clamp the piece. I don’t think you’re right with the assertion that bracing with your legs will unsettle your sitting position; just the opposite. Think of doing seated rows with the rope & pulley at the gym. You have to have your feet up against the machine. I don’t have a horse, but I’ve tried some shaving work with a piece clamped to the outfeed table of my jointer. It was nearly impossible, because I couldn’t brace myself.
-- My broker promised me he would treat my money as if it were his own. Trouble is, he did.
RobynHoodridge
#11 posted 108 days ago
Ooh, great point to bring up.
I’ll probably end up re-phrasing what you said so succinctly. If I do, it’s just to help explain, especially to those reading who haven’t already thought on this.
I probably talked about pushing with your legs shifting you because I imagine really having to bear down on the foot pedal to keep the stock still for some tasks. And especially if the perpendicular (normal) force in equal and opposite reaction to this hefty pushing is angled somewhat upward through your leg, it seems it would want to push you up and out of your seat backward. Obviously not a major issue with shaving horses, since they function and function well. And I may be entirely wrong about that scenario.
So at the same time I think you’re absolutely right, the rowing action against (or braced by) your legs is probably vital. Else you’d flop forward, rotating at the seat, if you were using a drawknife. Luckily you could still use your legs this way at the Giraffe. Only, pushing against the ground.
I imagine two scenes when you mention your trial at the out-feed table. In one you’re sitting on a chair or stool and get pulled horizontally toward the work and directly in line with it, rather than shaving it. (Your chair even has wheels in my head.) Because as you rightly say, there’s nothing to stop that. However, on a shaving bench (whatever kind) you’re attached to it in at least one place. You’re sitting on the very thing you’re pulling against.
(i’m certain this isn’t what you’re concerned about, but bear with me)
Being ‘attached’ to the structure you’re pulling on becomes especially handy when you’re not just pulling horizontally and relying on friction to act against a horizontal force. And this is the main ‘trick’ of the shaving bench design. It’s clamping platform is angled upward from the horizontal. Gives a better action of your arms movements, but also means you’re pulling against an equal and opposite force directed down into the bench. Which is structural, what you’re ‘attached’ to, and therefore something to pull against. The vertical component like pulling a peg out of the ground, and like the rowing machine. This vertical component you also counter with your legs of course (mostly). So again, yes a very important thing to be able to do. Makes me wonder how functional an angled setup on the out-feed table would be? So that you could direct more of the force down into the floor and have something to pull against. Standing this time of course.
So one could still apply all the forces at the Giraffe as at the Horse. However there may be a special consideration at the Giraffe. Yes you’re attached to it where you sit, and yes you can still pull against those strong-as-a-horse legs. But now what you’re pushing against with your legs isn’t attached any more. Not vertically at least. And the vertical component of the pull stroke that’s created by the wedge platform isn’t countered within the structure and system of the bench. So you’d be pulling the bench upward with the work piece. Now if you were standing above the Giraffe pulling upward on the pivoting design i’d say this would be a problem. But you wouldn’t be. You’d be pulling mostly toward yourself with some component of the force acting upward. And at the same time all the weight of yourself and the bench countering that partial upward force.
The other thing that makes me think that the giraffe won’t fold upward is what happens when you push against the ground when seated as you would be at the bench. Try sitting on a chair or stool with legs not folded beneath it, and push with your legs. What it causes is rotation (tendancy to roll or fall backward), not lift. And you’d turn that into pulling stroke force. It will be more demanding than the Horse on frictional forces at the seat and at your feet on the ground. But I don’t predict problematically so.
So I don’t think that having no foot peg to ‘row’ against will be a major problem.
Important to note though, is that this all has to do with pulling action such as using a spoke shave at the Giraffe. Tasks where you just need the piece clamped in place wouldn’t suffer from having no foot peg to push against even if i were wrong about the above.
Thanks JJohnston, that’s exactly the type of thing i need help thinking of. I hadn’t given it that much thought, and you worried me for a minute. :)
View mafe's profile
mafe
8055 posts in 1254 days
#12 posted 108 days ago
Hi ho,
First thank you for asking my oppinion, it makes me happy knowing I’m not all hopeless. Smiles.
I am not sure that I understand it completely, but if I do so; the giraffe is loaded with a pice of wood and the weight of the body holds it in place – brilliant thinking!
But…
Using one of these shaving horses you usually turn the item you work on rapidly and on going, it is not a static tool – is this possible while sitting down?
How do you release? By lifting the Giraffe?
Why don’t you make a foldable leg in the back? It will make it useable in all situations and a stand alone tool.
I am impressed and love that you question the horse, this is where invention gets educated.
Kepp up the ideas.
Good hunting.
Mads
-- Mad F, the fanatical rhykenologist and vintage architect. Democraticwoodworking.
RobynHoodridge
#13 posted 107 days ago
Hi Mads
Thanks for taking the time.
Yes, you’ve understood the concept.
The thing about using the body weight to cause the clamping is that the standard state is with the jaws clamping the work. Good for tasks that need long sessions of the clamped state, but probably not good for drawknife work.
You asked if it’s possible to turn the work while sitting. Well, not in the most basic form of the design. There are ways to make it possible. None i’ve thought of make it as easy as it is with a shaving horse. Here’s one idea for making it possible-
The handle (or some other version of handles) in blue give you something to push on to forcibly open the clamp with your upper body against all force of the clamping action. Not something you really want to be doing much of. A foot actuated lever below the bench could also be developed for lifting the bench and therefore un-clamping. And here leg action would UN-clamp the work.
Yes, to remove clamping force you would have to remove force down on the bench. I think that a balance could be found by tweaking the design so that the weight of the bench only causes a light enough clamping that the work could still be manipulated, but when sitting on it that force is much greater.
I’ve also thought of a spring to counteract only the clamping that’s due to the bench weight. But all of these things are complications.
So all round, it’s not going to be a natural thing for the giraffe design to clamp and un-clamp repeatedly.
The idea of a fold-away leg at the rear is great. Thanks.
Cheers
View rance's profile
rance
3854 posts in 1326 days
#14 posted 107 days ago
Robyn, There are parts I like and some I don’t. As already mentioned, Sitting to apply pressure could be a problem. However, if you put the rear support right where you sit, then you can somewhat rock forward & back to adjust the pressure. In the end though, I’ll bet you’ll get too much pressure and it will be difficult/tiresome to rotate the workpiece.
See if you can find a video of someone using one of the styles of horses. You’ll see that there is quite often a release of pressure to rotate or move the piece.
I really like that you are building it to be collapsable. I think that is a key feature.
Keep tweeking. I’ll second the suggestion to build one as a prototype. Use 2×4’s which can be gotten for free. You’ll get as much feedback with using it as with just questions. Remember that in designing, you’ll have to do revisions. Press on(pun intended).
View mafe's profile
mafe
#15 posted 107 days ago
A spring perhaps? So when you lift the jaw opens…
