| Forum topic by jimmyhopps | posted 113 days ago | 443 views | 0 times favorited | 11 replies | ![]() |
113 days ago |
Didn’t see any reviews, so I thought I’d post to see what people use.. |
11 replies so far
#1 posted 113 days ago |
I bought the only one Home Depot has in stock and love it. |
#2 posted 113 days ago |
http://www.homedepot.com/webapp/catalog/servlet/Search?storeId=10051&langId=-1&catalogId=10053&keyword=remote%20outlet&Ns=None&Ntpr=1&Ntpc=1&selectedCatgry=Search+All |
#3 posted 113 days ago |
I have a similar device from Lowe’s and have been using it for a while. If you need something for 220v I’d recommend the Long Ranger. -- Friends don't let friends use right tilt contractor saws...... |
#4 posted 113 days ago |
ToddinNH went a step beyond a simple remote. His DC isnt even located in his shop. check out his solution. |
#5 posted 113 days ago |
this is just a lazy mans setup: http://www.highlandwoodworking.com/longrangermultigatesystem110v.aspx I love mine. additional gates are not needed. just buy the sensor and epoxy it to your current blast gates. |
#6 posted 113 days ago |
I use and recommend the Long Ranger |
#7 posted 112 days ago |
Thanks guys. The HD/Lowes options look like they are the easy (and cheap) way out. I have the 2hp / 110v HF collector. Not being an electrician, can someone comment if it is compatible with these remotes? I would assume 110v is 110v… |
#8 posted 112 days ago |
The voltage isn’t what you need to check (well, not true….it does have to be either 120V or 240V as needed) but rather the amperage. A lot of those cheap lamp remotes are limited to 10 amps or less. So just look for one that would take 15 amps for your motor. -- I long for the days when Coke was a cola, and a joint was a bad place to be (Merle Haggard) |
#9 posted 112 days ago |
If I recall, the one I bought at Lowe’s was rated for 15amps. As Fred pointed out, that will be the deciding factor. I don’t know about the HD offering. -- Friends don't let friends use right tilt contractor saws...... |
#10 posted 112 days ago |
I use, and recommend, the lazy man’s system that Cole mentioned. -- jay, www.allaboutastro.com |
#11 posted 111 days ago |
and for the smarter, lazier man, there’s this: http://www.ivacswitch.com/index.action i use the ivac switches. very flexible and the company is absolutely first rate:
i can activate both 110v and 220v tools and activate both 110v and 220v dust collection/slave tools. -- there's a solution to every problem.......you just have to be willing to find it. |
| Forum | Topics |
Woodworking Skill Share
8790 |
Woodturning
220 |
Woodcarving
28 |
Scrollsawing
61 |
Joinery
78 |
Finishing
1529 |
3547 |
15763 |
Hand Tools
2034 |
Jigs & Fixtures
494 |
Wood & Lumber
2837 |
808 |
Focus on the Workspace
901 |
766 |
Woodworking Trade & Swap
2740 |
LumberJocks.com Site Feedback
1547 |
Coffee Lounge
6155 |
