Welding for a Plane Casted Sole.....? - - - Pic - - - -
« back to Hand Tools forum
Forum topic by Francisco Luna posted 01-28-2013 12:41 AM 1856 views 0 times favorited 8 replies Add to Favorites Watch
View Francisco Luna's profile
Francisco Luna
943 posts in 3595 days
01-28-2013 12:41 AM
Topic tags/keywords: plane
I have this Stanley plane with this damage as seen in the picture and I have also the little chip that came out from there…....I was wondering about the type of welding -if possible- that would repair this …?
-- Nature is my manifestation of God. I go to nature every day for inspiration in the day's work. I follow in building the principles which nature has used in its domain" Frank Lloyd Wright
8 replies so far
View Loren's profile
10477 posts in 3849 days
#1 posted 01-28-2013 12:48 AM
Brazing.
You can try to fix it yourself with J-B weld. It is in a
non-stressed area so I’d be optimistic about J-B Weld
working there.
Francisco Luna
#2 posted 01-28-2013 01:14 AM
Brazing sounds the right wy to go, but as the section needs to be heated until the steel is red, I’m worry about the japaning at the other side….......In the Hndplane Book, Garrett Hack uses a block plane that has been repired, I guess by brazing.
35148 posts in 4602 days
#3 posted 01-28-2013 01:41 AM
Brazing would be a brass color and silver solder would be silver color. Welding cast iron rules would be to heat up the entire piece and not just the section that needs to be repaired. Cast iron expands when heated and it would be possible for the plane to crack if only heated in the front section.
-- I've been blessed with a father who liked to tinker in wood, and a wife who lets me tinker in wood. Appomattox Virginia karsonwm@gmail.com †
View REO's profile
REO
929 posts in 2275 days
#4 posted 01-28-2013 04:43 AM
brazing or silver solder. you will be able to see the path of the weld even if it is built up and ground down. you will be able to see the braze line or the silver solder but it will be much less so. Get a hold of someone in tool and die to furnace braze it for you. The heat will be evenly applied and stress removed from the piece as well less chance of further damage and it will be hard to find the seam when you are done.
View stefang's profile
stefang
16133 posts in 3536 days
#5 posted 01-28-2013 10:20 AM
I dropped my Stanley Jack plane on a concrete floor about 15 years ago and broke off on side. I’ve been using it that way since with no problems. It does irritate me every time I look at it though.
View David Kirtley's profile
David Kirtley
1286 posts in 3199 days
#6 posted 01-28-2013 06:19 PM
No te preocupes. Dejalo asi. Si te ofende, hechas un gottito de superglue por el pedacito.
View USMCSergeant's profile
USMCSergeant
28 posts in 2156 days
#7 posted 02-05-2013 05:22 AM
If that is cast iron welding will be difficult. You’ll need nickel rods. Cast iron is temp sensitive so unless it’s preheated correctly and cooled correctly it will crack badly. If it’s steel, go at it with a mig welder, done,
View realcowtown_eric's profile
realcowtown_eric
617 posts in 2138 days
#8 posted 02-05-2013 05:31 AM
Just dull the sharp edges and leave it.
Then make up some story how your were working in the shop so hard that you didn;t notice that the sole got overheated and caused that little chip to break off!!
Really, trying to repair that little chip will depreciated the value of the tool more than just leaving it as is!!
Eric
-- Real_cowtown_eric
