Bandsaw Wheel Shrinking?
Forum topic by Jeff posted 01-27-2013 08:53 PM 1197 views 0 times favorited 6 replies Add to Favorites Watch
View Jeff's profile
Jeff
433 posts in 3193 days
01-27-2013 08:53 PM
Topic tags/keywords: question bandsaw
My shop is in an unheated garage. This week the temps have been in the high 40’s to low 50’s in the garage. With a sweater and a portable heater it’s tolerable. I have a Grizzly G0513 bandsaw that up till now has given me no trouble. Yesterday I was sawing something and just as as I was finishing my cut I heard a loud bang and then a rubbing noise. I looked all around and found the tire on the lower wheel had come off and the blade was riding on the wheel. The wheels are cast aluminum. Can these shrink in the cold to the point where the tire can come off? I put the tire back on and while running I can it lifting just after and before the blade comes into contact. It’s more pronounced as the blades lifts off, maybe half an inch. It seems to settle back down when stopped. I can see how the tire might slip off. It’s never happened before so I’m wondering if the wheel shrunk and the circumference decreased. Or is this just a coincidental wearing out of the tire?
View gfadvm's profile
gfadvm
14940 posts in 2688 days
#1 posted 01-28-2013 04:22 AM
You can glue those tires on with automotive GOOP brand adhesive (from the auto parts store). I did this on my big Grizz to get me through the project and have never put the new tires I ordered on! It’s been several months now. I don’t think your wheels shrank enough to cause this.
View Ted's profile
Ted
2846 posts in 2209 days
#2 posted 01-28-2013 04:41 AM
More likely the tire stretched.
-- You can collect dust or you can make dust. I choose to make it.
View kizerpea's profile
kizerpea
774 posts in 2366 days
#3 posted 01-28-2013 01:15 PM
gasket shellac from ace hardware..the old brown stuff…
-- IF YOUR NOT MAKING DUST...YOU ARE COLLECTING IT! SOUTH CAROLINA.
View johnstoneb's profile
johnstoneb
2914 posts in 2171 days
#4 posted 01-28-2013 01:31 PM
At those temperatures, thats’s not cold enough to shrink. Most likely your tire stretched. I’d glue it on.
-- Bruce, Boise, ID
View bondogaposis's profile
bondogaposis
4727 posts in 2349 days
#5 posted 01-28-2013 03:54 PM
It is most certainly not the cold that is causing your tire problems.
-- Bondo Gaposis
View Surfside's profile
Surfside
3389 posts in 2172 days
#6 posted 01-28-2013 07:48 PM
Rubber tires become hard and brittle during cold but it will expand slightly when it’s hot/ exposed to heat. Have you tried using urethane tires?
-- "someone has to be wounded for others to be saved, someone has to sacrifice for others to feel happiness, someone has to die so others could live"
