What kind of fastener have to use?
Forum topic by Toninho posted 01-27-2013 06:16 PM 1086 views 0 times favorited 16 replies Add to Favorites Watch
View Toninho's profile
Toninho
190 posts in 2851 days
01-27-2013 06:16 PM
Topic tags/keywords: question
Hello friends! I need to fix this word “LOVE” along the wall. I do not know what kind of accessory I have to use the word. Someone give me some advice? I wanted to know your opinion!
Thank you and good Sunday!
-- António Guerreiro https://www.facebook.com/bichosdamadeira
16 replies so far
View DocSavage45's profile
DocSavage45
8589 posts in 2866 days
#1 posted 01-27-2013 06:28 PM
Depeds on how heavy? Permanence? Simplist way… drill two holes in back of piece. If it’s going on dry wall and not a heavy piece ues a couple finishing nails. Easy repair when taking it down, most of the small pictures in my office are hung this way.
If into plaster you can use screw anchors.
-- Cau Haus Designs, Thomas J. Tieffenbacher
View Biff's profile
Biff
126 posts in 2038 days
#2 posted 01-27-2013 06:41 PM
I’ve had great luck on light pieces with the removable double sided tape. It’s often used for hanging coat hooks, etc and it holds great and then easily removed by pulling a little tab and stretching the adhesive.
3M Command Adhesive is what I use, it doesn’t pull off paint or finish.
-- Interested in Oregon property? Visit me at http://www.willamettepropertiesgroup.com
Toninho
#3 posted 01-27-2013 06:49 PM
The wall is plaster Docsavage yes! The word is very light. Thanks for your help.
Greetings!
DocSavage45
#4 posted 01-27-2013 06:49 PM
My wife is a big fan of it. The hangers are great. Dry surfaces a must. She hung an outlet in our barthroom with it . Keeps falling off the tile. But it holds coats, and clothes well.
DocSavage45
#5 posted 01-27-2013 06:52 PM
My pleasure. another thought isdrill fine holes into the lath and use small screws. If dry surface the 3m tape might be simplest?
Hey!
Toninho
#6 posted 01-27-2013 07:01 PM
I also liked a lot of the solution of 3M double sided adhesive tape!
Thanks Biff!
I’ll think of your two councils.
Thank you!
View SCOTSMAN's profile
SCOTSMAN
5849 posts in 3609 days
#7 posted 01-27-2013 07:26 PM
What about hot melt glue? easy peezy and strong. Alistair
View Dusty56's profile
Dusty56
11819 posts in 3712 days
#8 posted 01-27-2013 07:29 PM
That came out perfectly : )
View EMVarona's profile
EMVarona
437 posts in 2859 days
#9 posted 01-28-2013 09:48 AM
If you decide to use tape, use the double sided mounting tape. That’s also called “double-sided foam” tape. It’s used by photographers and artists when mounting their art pieces and they hold quite well. The regular or ordinary double-sided does not cling too well.
-- Ed "Real happiness is one that you share."
Toninho
#10 posted 01-28-2013 09:36 PM
I really like the 3M adhesive tape EMVarona!!
Thanks for your comment my friend. Once I fixed 3M double sided adhesive tape in a frame on the wall in my mother’s house and the frame was there for four years, until she moved away from home and I had to pull the frame too hard! Thank 3M
Greetings my friend!
View PurpLev's profile
PurpLev
8536 posts in 3672 days
#11 posted 01-28-2013 09:42 PM
2 holes in the back of the word, and 2 nails on the wall.
I would rather put my confidence in gravity holding it (nails) over glue for long term (also less messy to remove/relocate).
Toninho
#12 posted 01-28-2013 09:58 PM
Some customers like more nail in the wall! Tomorrow I have to finish this project and decide on the best idea!
thank you @PurpLev!!
thank you
Loved your work, congratulations my friend!
View waho6o9's profile
waho6o9
8207 posts in 2600 days
#13 posted 01-28-2013 10:00 PM
Velcro?
View Jim Finn's profile
Jim Finn
2657 posts in 2945 days
#14 posted 01-29-2013 03:47 AM
I make small metal straps to screw to the backside of the word and hang this on a nail in the wall. I make the straps out of scrap metal…... like old band saw blades.
-- Website is No PHD just a DD214 and a GED https://craftingcouple.com/
View BentheViking's profile
BentheViking
1782 posts in 2588 days
#15 posted 01-29-2013 03:58 AM
my router bit set came with a keyhole bit…you could try one of those with a screw in the wall. I’d think if you just drilled a regular hole and hung it on nails if someone bumped it it’d fall over
-- It's made of wood. Real sturdy.--Chubbs Peterson
