Shop Insulation
Forum topic by CharlieW posted 118 days ago 358 views 0 times favorited 6 replies Add to Favorites Watch
View CharlieW's profile
CharlieW
24 posts in 123 days
118 days ago
Hi all. I’m in the process of converting my attached 3 car garage to a wood shop. Prep is underway. I’m bringing in the electrician Monday to quote on a new sub-panel and new circuits, the epoxy floor goes down at the end of February and in the meantime I’ll be painting. I’m also going to bring in an HVAC guy to give me some options on conditioning the air. I’m in San Diego so we don’t get to much in extremes so I don’t need anything too major. The one problem I have is that the builder didn’t insulate the walls before being finished and I sure would like them to be insulated. Is there anyway to retrofit insulation without tearing the walls down (is blown in insulation in the walls an option?) Thanks all, I appreciate your thoughts.
View Arminius's profile
Arminius
219 posts in 1975 days
#1 posted 118 days ago
If it is just drywall against stud framing, blown-in cellulose or similar will be fine. In most climates a vapour barrier would be needed, but in San Diego for a garage I don’t think it will make much difference.
CharlieW
#2 posted 117 days ago
Thanks! I think thats the ticket
View MedicKen's profile
MedicKen
1561 posts in 1634 days
#3 posted 117 days ago
Vapor barriers are not necessary in California. I did a complete overhaul of my garage, er shop, a few years ago. Complete removal of all the drywall. electrical upgrade, insulation and lighting. It was well worth it. I used R19 in the walls and R30 in the ceiling. It made a HUGE difference. If you dont want to get into the drywall portion, blown in would be fine. I would also insulate the ceiling/attic space as well. If you decide to have an electrician come in, the cost will be a lot less if they dont have to remove drywall. It may be more cost effective to strip it to the studs and have the electrical work done, that will then give you the opportunity to insulate and inspect the inside of the walls for termites, ants, and other problems. Drywall is cheap. termite damage on the other hand can be quite expensive to fix
View JesseTutt's profile
JesseTutt
707 posts in 282 days
#4 posted 117 days ago
If you are going to have an electrician install a sub-panel and outlets there will be some damage to the drywall. Also, drywall does not have much strength in holding for shelves, or even a nail to hang something from. It sounds like you are planning a first rate shop so you might consider removing the drywall, inserting regular fiberglass insulation and then covering the walls with plywood.
View MrRon's profile
MrRon
1575 posts in 1415 days
#5 posted 117 days ago
I would go with surface mount wiring and blown in insulation. Surface wiring (as opposed to hidden wiring in the wall) will allow you to expand or make changes without getting into the sheet rock.
View Jim Finn's profile
Jim Finn
1068 posts in 1094 days
#6 posted 117 days ago
I did all that MrRon suggested. In order to limit the work required I just made the holes to blow the insulation in, near the ceiling and covered them all with one long 1×6 and painted it to match the wall.
-- In God We Trust
