small 1000 bf kiln for sale
Forum topic by REO posted 112 days ago 402 views 0 times favorited 3 replies Add to Favorites Watch
View REO's profile
REO
279 posts in 240 days
112 days ago
Topic tags/keywords: milling resource diy kiln
2 years ago I built a kiln for a friend who makes hardwood toys. It is about 8 feet wide and 10 feet long.It will dry about 1000 bf of 4/4 material. It uses an air conditioner for both moisture removal and for heat. There are two locations for circulating fans although only one has been used. His business has grown to the point that he uses to much material to keep up by drying it himself. The kiln is three sides and a top on rollers. to operate you build a stickered pile endwise to the wall and roll the kiln over the top. use door stops to keep it pushed up against the wall and turn it on. water is delivered through a hose to the outside of the structure. If anyone wants it let me know he needs the space.
3 replies so far
View Don W's profile
Don W
9932 posts in 733 days
#1 posted 112 days ago
It might help if you posted where it is and how it could be moved and How much your friend is asking for it.
View REO's profile
REO
#2 posted 112 days ago
Its in Minneapolis MN. It comes apart in panels. snowmobile trailer. he says if he doesn’t have to mess with it 200 will take it. I know he put about 1000 into it. its to far for you to come Don. I though that people would naturally just check to see where the poster was from for location.
Don W
#3 posted 112 days ago
I actually did check, but didn’t know where coon rapids was. I didn’t think to dig into your workshop to find out. To bad its not closer, for that number I’d be all over it. That’s a pretty good deal. Good luck selling it.
