Delta Miter saw plastic guard replacment
Forum topic by rweitz posted 01-26-2013 07:31 PM 15592 views 0 times favorited 8 replies Add to Favorites Watch
View rweitz's profile
116 posts in 3009 days
01-26-2013 07:31 PM
Topic tags/keywords: question miter saw
Hi all,
I dumped my miter saw on the ground the other day cleaning out the garage and busted the plastic guard all to pieces.
Delta Tool Part 905890 is the part number for the guard, Delta 36-070 is the model of the saw I think but it seems this part is not made or available from what I can find on the interweb.
Anyone have any ideas on alternatives to getting the part that might make this saw safe again? I hate to just junk it because I can’t find a plastic part.
-- You cannot build a reputation on what you are going to do. - Henry Ford
8 replies so far
View Knothead62's profile
2581 posts in 2892 days
#1 posted 01-26-2013 08:50 PM
I would be surprised if other models were made by the same company and had interchangeable parts. Go to Lowe’s, HD, Ace, Woodcraft, Rockler, etc. and look at TS’s there. I’m guessing you could find a match.
View albroswift's profile
3 posts in 1765 days
#2 posted 05-19-2013 07:52 PM
Rweitz, Did you ever find a guard that fit? I’m in the same boat, only worse, I don’t have the original guard to compare. Like to fix this saw up for someone, don’t want to give it away with no guard.
View wmlaveck's profile
25 posts in 3082 days
#3 posted 10-18-2013 01:41 PM
I too need a blade guard for my 10” Delta Miter Saw (36-220). I got it at a church sale for $10. Monday I am going to call the church to see if they know the seller to see if they still have the plastic guard. I know it will be broken as part of it is attached to the saw. But I may be able to repair it or use it as a model to make a new guard. Any further Ideas on this?
-- If I ever turn up missing, check the garage.
#4 posted 10-18-2013 03:09 PM
Hello, WM
I milled about 1/4” off the spring side of the aluminum guard housing and used a guard from the newer saw. Used the spring assembly from the newer guard, drilled new holes in the tin spring cover plate to fit the old housing. Don’t remember which arm I used. Have about 8 hrs and $60.00 into the retrofit. Way better then just finding a newer model with a working guard on craigslist for $50.00.
(My suggestion, put a metal cutoff wheel in it and don’t waste any more time/ money on the beast).
View distrbd's profile
2252 posts in 2378 days
#5 posted 10-18-2013 04:06 PM
Have you tried tool parts ?is it type 1,or 2 or 3?
-- Ken from Ontario, Canada
#6 posted 10-18-2013 04:39 PM
The saw is a 36-220 type 1
View Loren's profile
10084 posts in 3579 days
#7 posted 10-18-2013 05:07 PM
Sears had a version of that saw.
View DuaneH's profile
1 post in 132 days
#8 posted 11-07-2017 01:52 AM
I broke the plastic blade guard on my Delta 36-220 Type III miter saw where the lift arm attaches. Since replacement was not an option, I crafted a strip of copper about 2 1/2 inches long and soldered a nut to it that fit the original pivot screw. Pop riveted this to the blade guard and reattached the lift arm. So far, things are good and I can still use my miter saw in a safe manner.
