Stuck router bit help
Forum topic by Reaper417 posted 01-26-2013 05:53 PM 1584 views 0 times favorited 19 replies Add to Favorites Watch
View Reaper417's profile
Reaper417
49 posts in 2148 days
01-26-2013 05:53 PM
Hey guys! I need a little help here. Everytime I put a bit in my router it’s gets stuck inside the collet. I know banging it out isn’t the answer. Any ideas? Really getting on my nerves. Thanks for the help….
19 replies so far
View Mark Davisson's profile
Mark Davisson
597 posts in 3220 days
#1 posted 01-26-2013 05:59 PM
I have experienced this, and my problem was solved by wrapping some sandpaper around a small dowel and sanding the inside surface of the collet. Corrosion, I guess, had built up on the inside of the collet.
-- I'm selfless because it feels so good!
View bondogaposis's profile
bondogaposis
4596 posts in 2254 days
#2 posted 01-26-2013 05:59 PM
What kind of router? What kind of collet?
-- Bondo Gaposis
View MonteCristo's profile
MonteCristo
2099 posts in 2091 days
#3 posted 01-26-2013 07:47 PM
Some collects have a little c-clip near the top that, if it comes off, affects their ability to release the bit. Also, undo the collect until the bit is clearly released. Some require more undoing than others.
4873 posts in 2396 days
#4 posted 01-26-2013 08:23 PM
Some routers have self releasing collets (what Montecristo mentioned), you loosen the collet, than keep turning until a second “bump” is felt, that does the release. The Freud is like that, and the Milwaukee…and i think the PC does it that way as well…maybe others.
View sprucegum's profile
sprucegum
324 posts in 1901 days
#5 posted 01-26-2013 09:10 PM
My porta cable has done this since day one I just loosen the nut and give the bit a sharp smack sideways with a piece of hardwood and it releases. Been doing it this way for at least ten years have not damaged the router or a bit yet. I would rather they stick a little than have them loosen up while in use. My new Makita uses the same type of collet and does the same thing.
-- A tube of calk and a gallon of paint will make a carpenter what he ain't
View Jorge G.'s profile
Jorge G.
1537 posts in 2378 days
#6 posted 01-26-2013 09:13 PM
Rub a little bit of oil on the bit shaft. This used to happen to me a lot with my trim router and the sales person recommended this. After a few uses the problem was solved.
-- To surrender a dream leaves life as it is — and not as it could be.
View huff's profile
huff
2828 posts in 3188 days
#7 posted 01-27-2013 02:01 AM
Like Fred and MonteCristo mentioned, I know my Porter Cable is like that; if you continue to loosen the collet nut you will feel a little resistance and then it will release the bit.
-- John @ http://www.thehuffordfurnituregroup.com
404 - Not Found
2544 posts in 2872 days
#8 posted 01-27-2013 02:07 AM
Is this something that has only just happened or has it always done it?
View Cosmicsniper's profile
Cosmicsniper
2202 posts in 3061 days
#9 posted 01-27-2013 02:08 AM
My Bosch 1617 is like that as well, Fred.
Often, to release the collet, you tap the bit IN..which then releases the bit OUT.
-- jay, www.allaboutastro.com
View madts's profile
madts
1841 posts in 2243 days
#10 posted 01-27-2013 02:16 AM
The whole collet needs to be cleaned. Use WD 40 or sim. Soak all parts well and then put just a wee bit of grease on the parts. Just enough to prevent corrosion. Then you should be ready to go.
-- Thor and Odin are still the greatest of Gods.
View rustfever's profile
rustfever
745 posts in 3213 days
#11 posted 01-27-2013 02:21 AM
First,make sure you do not bottom out in the collet. If not bottoming out, then lightly polish the bit shank with 2000 [or finer] grit sanding medium. Next, wipe with very light oil. Finally, lightly tap with a dead blow mallet if it still hangs up.
Happens to me frequently. This system seems to work
-- Rustfever, Central California
View NormG's profile
NormG
5900 posts in 2907 days
#12 posted 01-27-2013 02:41 AM
Take apart, clean it up, lightly oil and wipe off completely and reassemble
-- Norman - I never never make a mistake, I just change the design.
runswithscissors
2646 posts in 1928 days
#13 posted 01-27-2013 02:46 AM
A couple sideways taps seem to loosen them up. Don’t hit too hard, avoid bearings and DON’T hit the carbide.
View gfadvm's profile
gfadvm
14940 posts in 2593 days
#14 posted 01-27-2013 04:20 AM
I solved mine by swabbing the inside of the collet with a Q-tip and lacquer thinner.
View TCCcabinetmaker's profile
TCCcabinetmaker
932 posts in 2258 days
#15 posted 01-27-2013 04:39 AM
check the router bit shafts as well for rust, lightly sand if that is the issue.
-- The mark of a good carpenter is not how few mistakes he makes, but rather how well he fixes them.
