Carbon Monoxide
Forum topic by David Craig posted 01-26-2013 12:54 PM 1106 views 0 times favorited 10 replies Add to Favorites Watch
View David Craig's profile
David Craig
2137 posts in 3012 days
01-26-2013 12:54 PM
Topic tags/keywords: co carbon monoxide detector heating shop safety monitor
During this latest cold spell, I came home to a house that was just over 50 degrees. I had a clogged condenser pipe that triggered an automatic shutoff. I was able to take care of it myself and heard the general warnings about carbon monoxide and home repair on heating devices. I became very conscious of the fact that my basement workshop has gas appliances heating the water and the air and I had no detectors for monitoring for CO. I picked up two monitors, one for my shop, and one for my living space. If I am working or sleeping, I will know if there is a leak.
With all the cold weather and discussions generated about the various ways one heats the shop and the fact that what we do has the potential for clogging the airflow, I thought it might be a good idea to remind everyone to get one of these contraptions. No odor, no visible traces, by the time you know something is wrong, you are already in serious trouble.
David
10 replies so far
View helluvawreck's profile
helluvawreck
30112 posts in 2770 days
#1 posted 01-26-2013 01:56 PM
That’s a good word of advice, David. Sometimes we all can be negligent about these things. Thanks.
helluvawreck aka Charles
View whitebeast88's profile
whitebeast88
4128 posts in 2094 days
#2 posted 01-26-2013 02:17 PM
thanks david thats something you really don’t think about,but should.
-- Marty.Athens,AL
View Jim Bertelson's profile
Jim Bertelson
4150 posts in 3068 days
#3 posted 01-26-2013 04:06 PM
I have one in the shop, since there are cars, and two furnaces there, and we also have them in a couple other places in the house. Definitely an imortant reminder.
Got my fish moved to there new aquarium. It presents opportunities for an arts and crafts veneer of wood for the stand and the top. And I have start the glueups on my cutoffs cart…....finally.
-- Jim, Anchorage Alaska
View JesseTutt's profile
JesseTutt
853 posts in 2014 days
#4 posted 01-26-2013 04:19 PM
Thanks for the reminder. I have a CO detector in the shop, but I think I will replace the battery.
Some detectors are more sensitive than others.
Gerald Thompson
870 posts in 2138 days
#5 posted 01-26-2013 08:33 PM
One of the symptoms of CO poisoning is pink cheeks. CO has a geater affinity for hemoglobin than O2. It stays in the red blood cells and will not be used and it is stuck there. This keeps red cells red hence one ends up with more cells being red and it shows up often times in the cheeks.
If one sees this it is best to get out of the area anc call 911. This is not being overly alarmist. Ones blood O2 level should be 90% or above. One woild have no way of measuring this. Supplemental O2 may be needed. Remember the CO will stay latched on to the red blood cell. It take a little while for the body to get more RBCs into the body.
CO sensors are the first line of defense not a mirror.
-- Jerry
View Knothead62's profile
Knothead62
2581 posts in 2864 days
#6 posted 01-26-2013 08:45 PM
“pink cheeks”
My wife calls them hot flashes. We have smoke detectors in key places in the house and a CO alarm in the den where we have a gas heater (need to open a window when it’s on). Very important! We had a fire in the county a while back and smoke detectors were disabled!
Rule of thumb- change the batteries when the time changes.
View Roger's profile
Roger
20904 posts in 2707 days
#7 posted 01-28-2013 03:19 PM
Thnx for the heads-up David
View REO's profile
REO
928 posts in 1977 days
#8 posted 01-28-2013 04:28 PM
CO is a by product of incomplete combustion. the reason CO is poisonous is because the oxygen in the molecule is attracted to the hemoglobin and neither one wants to give it up. Hemoglobin is no dummy though when it comes into contact with O2 it lets the CO molecule walk. Most of the symptoms are readily recognizable symptoms including mild headache, dizziness, and nausea. Pink cheeks depends on the individual does not happen in all cases and is caused by an increase in the heart rate, a reaction to the body’s need for more oxygen. As the condition worsens finger nails will lose their pink look and be replaced by a bluish cast. properly maintained CO detectors will detect levels of CO far below harmful concentrations. They are a great investment!
View CL810's profile
CL810
3726 posts in 2891 days
#9 posted 01-28-2013 04:36 PM
Extreme care should be exercised when exhausting a dust collector to the outside from a workshop that contains a fuel burning unit. The negative air pressure will pull the exhaust fumes into the workplace.
-- "The only limits to our realization of tomorrow will be our doubts of today." - FDR
View mnguy's profile
mnguy
190 posts in 3301 days
#10 posted 01-28-2013 04:43 PM
Anoter safety step I have in my shop is a heat detector, not a smoke detector. It gives me some detection and warning of fires, but isn’t nuisance tripped by the inevitable, occassional ‘smoke’ from some burn on wood from a blade or a bit. I have the detector wired into the smoke detectors in the house; hardwire with battery back up. My shop is in the basement.
Great tip on the CO detector!
