Routing MDF cabinet doors
Forum topic by WOODIE1 posted 01-26-2013 06:44 AM 3916 views 0 times favorited 6 replies Add to Favorites Watch
View WOODIE1's profile
WOODIE1
117 posts in 2187 days
01-26-2013 06:44 AM
Probably a stupid question but this is a budget project and don’t want to waste money on bits and material if it won’t get results I want .
I want a simple MDF slab door but want to route a simple 3/16 groove approx 2 1/2” in from the perimeter edge. I am unsure if using a simple straight bit will give me clean square corners or will I wind up with rounded corners?
Not sure if this will show up but this is what I am looking to do with the possibility of adding vertical grooves to create a bead board look within the new inner routed panel. Kind of a clean modern bead board inset design.
As always I appreciate the help.
Anybody in SOCAL make MDF doors to save me some time??? Barker is great but lead time is too long for this project.
THANKS!!
http://www.barkerdoor.com/Miami-MDF-Raised-Panel-Cabinet-Doors-s/64.htm
View Mark Davisson's profile
Mark Davisson
597 posts in 3225 days
#1 posted 01-26-2013 12:40 PM
Woodie, your corners will be rounded, with a 3/32” radius (using a 3/16” bit). Those corners can be chiseled to square the old fashioned way, or you could pick up one of these:
http://www.woodcraft.com/product/2004433/8388/quick-cutting-corner-chisel.aspx
-- I'm selfless because it feels so good!
4885 posts in 2401 days
#2 posted 01-26-2013 12:53 PM
Remember the bottom of the groove will have that radius as well, chiseling those square might likely require a touch of finesse.
View joeyinsouthaustin's profile
joeyinsouthaustin
1294 posts in 1981 days
#3 posted 01-26-2013 03:14 PM
By using a smaller bit, and a template or collar settup you can at least make the inside of the corner square, and just have to chisel the outside!!
-- Who is John Galt?
WOODIE1
#4 posted 01-26-2013 11:55 PM
Thanks, thats what I thought but I thought maybe the straight bit vs a raised panel type would have had a different outcome.
For the cost I found a place that can knock them out in 3 days for not much more then they would cost me. I have no idea how thy do them so cheap.
View Wdwerker's profile
Wdwerker
333 posts in 2141 days
#5 posted 01-27-2013 12:11 AM
They buy MDF in full bundles. Their saws and routers are computer controlled . You are paying retail for a probably lower grade of MDF. Most of the expense is in finishing that MDF door and sanding between coats to get a primo finish!
-- Fine Custom Woodwork since 1978
9974 posts in 3556 days
#6 posted 01-27-2013 01:26 AM
Try Decore-ative Specialties.
