| Forum topic by MT_Stringer | posted 119 days ago | 663 views | 0 times favorited | 15 replies | ![]() |
119 days ago |
Topic tags/keywords: question tablesaw Well, that sucks. I had a thin kerf rip blade on my saw and the riving knife is too thick. That sucks. Had to switch back to the blade that came with the saw to do my ripping. Grizzly doesn’t list a thin kerf riving knife. Guess I will call tomorrow and chat with them. So what do you guys do for a thin kerf riving knife? -- Handcrafted by Mike Henderson - Channelview, Texas |
15 replies so far
#1 posted 119 days ago |
“Well, that sucks. I had a thin kerf rip blade on my saw and the riving knife is too thin. That sucks. Had to switch back to the blade that came with the saw to do my ripping.” I’m assuming you mean the riving knIfe is too thick? The riving knife on my saw is pretty close to my thin kerf blades, about 0.090” or so. -- John, BC, Canada |
#2 posted 119 days ago |
@nwbusa – yeah, I wrote it up wrong. Had to edit it. The blade is an Irwin Marathon 24 tooth blade but it is too thin and the wood pinches at the knife. -- Handcrafted by Mike Henderson - Channelview, Texas |
#3 posted 119 days ago |
http://www.leestyron.com/zrkgrizzly.php -- Life has no remote. Get up and change it yourself. |
#4 posted 119 days ago |
Generally not too hard to make one yourself. I’ve made two… Find some steel sheet 0.80” or 2mm thick. This will work with almost all thin kerf blades, but you might be able to get away with 3/32” or 0.90” – you need the thickness to be just less than the blade kerf. Trace the outline of your existing riving knife on it and cut it out. It will cut pretty easily with a jigsaw or hacksaw with bimetal blades. Sand to your line and round over all edges. Take care that you don’t bend the sheet, you need it to remain straight. You’ll need to be very precise about the location of the mounting holes/slots/tabs where it attaches to the saw, as those are used for alignment. Depends on the saw, but if you’re too sloppy about them, you risk the knife being able to come in contact with the blade during operation. DAMHIKT. -- Mark Kornell, Kornell Wood Design |
#5 posted 119 days ago |
I’ve made riving knives out of a good piece of hardwood. Not as strong as steel but they work well and are a whole lot better than nothing. -- Dwight - "Free legal advice available - contact Dewey, Cheetam & Howe"" |
#6 posted 119 days ago |
Let us know if grizzly says anything. I went through this last year and have been debating recently if I was going to switch to my regular blade in anticipation of my new zero clearance insert and other jigs. |
#7 posted 119 days ago |
Which model saw do you have? FWIW, those Irwin Marathon blades aren’t much good for fine woodworking IMO….they’re more of a construction grade blade for rough carpentry. Try their Marples series, or CMT, Infinity, Freud Industrial or Diablo, DeWalt Precision Trim, Amana AGE, Oshlun, etc….you’ll get much better results. -- Happiness is like wetting your pants...everyone can see it, but only you can feel the warmth.... |
#8 posted 119 days ago |
This might be an alternative! |
#9 posted 119 days ago |
“Which model saw do you have? FWIW, those Irwin Marathon blades aren’t much good for fine woodworking IMO….they’re more of a construction grade blade for rough carpentry.” I have the Grizzly 1023. That is why I bought the Marathon blade. It says it is for ripping, construction. I am ripping 2×4’s and 2×10’s and it works OK on the outer part of the board but the knife binds when I try to rip through the inner part of the boards. I switched back to the factory blade, which is wider and went back to ripping. -- Handcrafted by Mike Henderson - Channelview, Texas |
#10 posted 119 days ago |
Why are you concerned about a thin kerf blade on that saw? You don’t need one with a 3hp saw. -- Friends don't let friends use right tilt contractor saws...... |
#11 posted 119 days ago |
My sawstop has thin kerf knives. I doubt they make them. May want to call SS and ask them where they get thiers from. -- Sorry the reply is so long. I didn't have time to write a short reply. |
#12 posted 119 days ago |
“Why are you concerned about a thin kerf blade on that saw? You don’t need one with a 3hp saw.” This is all a learning experience for me. I haven’t had a saw with a riving knife before and surely not a 3hp motor. Anyway, for the time being, it is put away. I will prolly forget I even bought it in a week or two. :-( -- Handcrafted by Mike Henderson - Channelview, Texas |
#13 posted 114 days ago |
Make your own riving knife out of an old saw blade. Cut it out with a thin steel-cutting disk in your angle grinder. You can make different thicknesses by selecting from various old blades. You should be able to buy non-carbide blades for almost nothing at a thrift store, if you don’t already have something in your old worn out blade collection. |
#14 posted 114 days ago |
To solve the problem, I bought a freud regular kerf blade for ripping. So far it is working just fine. -- Handcrafted by Mike Henderson - Channelview, Texas |
#15 posted 101 days ago |
I earlier suggested cutting up an old saw blade for a riving knife. And I did this, but it was a bit too thin. Then I ran into a suggestion to use 14 gauge plate steel. I dropped by my local steel supplier, and picked up an offcut about a foot square (enough to make 4 ore 5 riving knives). With a little sanding and polishing, it works perfectly with my Freud Diablo TK blade. For a standard blade, you’d probably want 13 or 12 gauge. The way I checked it out at the steel yard was to bring a piece of oak from home in which I’d sawed a 6” kerf. Slipped nicely over the 14 gauge, with no wiggling, so I knew it was good. |
| Forum | Topics |
Woodworking Skill Share
8798 |
Woodturning
224 |
Woodcarving
28 |
Scrollsawing
61 |
Joinery
82 |
Finishing
1538 |
3556 |
15816 |
Hand Tools
2039 |
Jigs & Fixtures
496 |
Wood & Lumber
2847 |
810 |
Focus on the Workspace
903 |
766 |
Woodworking Trade & Swap
2742 |
LumberJocks.com Site Feedback
1547 |
Coffee Lounge
6166 |
