| Forum topic by grenger | posted 119 days ago | 583 views | 0 times favorited | 14 replies | ![]() |
119 days ago |
HELP! strawberries were cut on it and there is now red stained. I saw on the net that i could use VINEGAR and SODA to remove it. It did remove it but now the board is now a lot darker (black), especially the maple. What can i do to restore the colors thanks —Gerry (the beginner) -- Gerry (the beginner), Gatineau, QC, Canada |
14 replies so far
#1 posted 119 days ago |
Sand the board and re finish it again. -- Brett Miner www.NewEnglandsWoodWorking.com |
#2 posted 119 days ago |
THANKS, that is what i thought would be the best thing to do.. -- Gerry (the beginner), Gatineau, QC, Canada |
#3 posted 119 days ago |
Oil and wax are not finishes; at least not from a “sealed protective coating” point of view. -- Michael :-{| Diapers and politicians both need to be changed often; and for the same reason. |
#4 posted 119 days ago |
thanks for the comment crank49 but this does not really answer my question. ;-) -- Gerry (the beginner), Gatineau, QC, Canada |
#5 posted 119 days ago |
Hi To remove the stain get oxalic acid from your local pharmacy. Mix a past and apply to the marks, leave on for a few minutes 3-5 and wipe of with water. This should remove the stain down to a millimeter or two.May need a few applications suggest trying on a piece of scrape with the same stains. Hope this helps Tamboti —Africa is not for sissies -- Africa is not for sissies |
#6 posted 117 days ago |
thanks tamboti… -- Gerry (the beginner), Gatineau, QC, Canada |
#7 posted 117 days ago |
Finish both sides, cut on one and display the other. It’s a cutting board, it will eventually look ugly either way. -- --Rev. Russ in NY-- A posse ad esse |
#8 posted 117 days ago |
I put the router to it (endgrain board).... removed all the bad stuff…. like new now. -- Gerry (the beginner), Gatineau, QC, Canada |
#9 posted 7 days ago |
how deep did you need to router it? My girlfriend just made a beet salad using my brand new board… looks like a horror show :’( |
#10 posted 7 days ago |
LOL! depends, many factor. Was the board seasonned well, how long was the stain on the board, i started with the router 1/32 then lowered the bit till it was all removed. A drum sander (if you have) would do the job. good luck -- Gerry (the beginner), Gatineau, QC, Canada |
#11 posted 7 days ago |
noooope, no drum sander. i guess i may have to take it to the belt sander and work it ‘til it’s gone. oh well! |
#12 posted 6 days ago |
I have no belt sander ;-( rooter then 220 and 320 orbital sanderes show me pictures -- Gerry (the beginner), Gatineau, QC, Canada |
#13 posted 6 days ago |
This will happen many times over the life of the board if you put it through normal use. Just keep using and washing it and it will fade and eventually be gone. If you take a router to it ever time it incurs a stain it will be see through in no time. :) -- PaulMayer, http://www.vernswoodgoods.com |
#14 posted 6 days ago |
Before: After: I’m fine with a bit of regular discoloration, but this is a bit over the top! :) |
| Forum | Topics |
Woodworking Skill Share
8797 |
Woodturning
224 |
Woodcarving
28 |
Scrollsawing
61 |
Joinery
82 |
Finishing
1535 |
3553 |
15803 |
Hand Tools
2038 |
Jigs & Fixtures
496 |
Wood & Lumber
2844 |
810 |
Focus on the Workspace
903 |
766 |
Woodworking Trade & Swap
2740 |
LumberJocks.com Site Feedback
1547 |
Coffee Lounge
6163 |
