Can't identify this plane
« back to Hand Tools forum
Forum topic by jhut posted 01-24-2013 02:56 PM 1910 views 1 time favorited 23 replies Add to Favorites Watch
View jhut's profile
jhut
28 posts in 2446 days
01-24-2013 02:56 PM
This old plane was in my dad’s tool chest. There are no markings. Not even on the blade or lever cap. I took the frog off thinking that would help me identify it. I still have no clue. Its 9 1/2 inches long. Any ideas on the brand?
23 replies so far
View blackcherry's profile
blackcherry
3338 posts in 4058 days
#1 posted 01-24-2013 03:30 PM
Not much help from the picture but I can say it a Stanley handyman style plane from the blue color on the casting. These were at the lower end of quality and sold for around 20-25 dollars new…hope this helps BC
View jhut's profile
jhut
#2 posted 01-24-2013 03:40 PM
Sorry about the bad picture. This one might be better. There’s no blue on the casting. I think the flash just messed up the color of the photo.
View jhut's profile
jhut
#3 posted 01-24-2013 04:19 PM
I cleaned it up a little so you can see the area the frog sits on.
View Dwain's profile
Dwain
582 posts in 4094 days
#4 posted 01-24-2013 04:22 PM
Looks like an old jack plane. I don’t know a brand. Get that thing in some evaporust, scrub it off and take some more pictures.
-- When you earnestly believe you can compensate for a lack of skill by doubling your efforts, there is no end to what you CAN'T do
16281 posts in 4453 days
#5 posted 01-24-2013 04:35 PM
I don’t recall ever seeing a frog seat shaped quite like that. Maybe some else will recognize it.
View Deycart's profile
Deycart
444 posts in 2492 days
#6 posted 01-24-2013 05:16 PM
A few things make me think it is a union plane. First is the twist to the lateral adjust second is the shape of the frog and third is the hole in the blade is at the top instead of the bottom. You will probably find their trademark under the rust on the blade. Oh I just noticed the depth adjust looks steel and that can be found on some union planes along with the solid brass screw to hold the tote and knob. Hope that helps.
View Dan's profile
Dan
3630 posts in 3115 days
#7 posted 01-24-2013 06:27 PM
Looks like the blade is thicker then the standard vintage iron. Could be made by Ohio Tool Co. They had thicker irons that were tapered.
^ I agree with the last poster. Get the rust off the top of the iron and you will probably find some kind of logo or name stamped in it.
-- Dan - "Collector of Hand Planes"
View bandit571's profile
bandit571
21975 posts in 2918 days
#8 posted 01-24-2013 06:58 PM
A shot of my Union #4G’s base
Another look
and a look at the iron
Not sure what colour the base was originally, since mine was a pile of rust. The other side of the iron has a
UNION MFG CO
NEW BRITAIN CT USA
stamped on it.
View jhut's profile
jhut
#9 posted 01-24-2013 07:22 PM
Thanks for all the posts. Deycart, I think you’re right about it being a Union. I found a Union body for sale on ebay that has the same frog seat. Am I allowed to link to ebay? It’s item number 181067160925
View Don W's profile
Don W
19038 posts in 2802 days
#10 posted 01-25-2013 01:36 AM
jhut, you’re allowed to link to ebay.
I don’t know if Union had a tapered iron, but Ohio tools did. A better shot of the tote would help to. Ohio tools had a different style tote. Both Union and Ohio tools had the ring around the knob. The twist on an Ohio tools’ lat adjuster was twisting slightly different as well.
View jhut's profile
jhut
#11 posted 01-25-2013 02:17 AM
Here’s the tote.
Don W
#12 posted 01-25-2013 02:20 AM
probably Union….......
Deycart
#13 posted 01-25-2013 02:24 AM
Most ohio planes have a zero before the plane number, if im not mistaken. Union also liked to use mahogany for the knobs and totes.
Don W
#14 posted 01-25-2013 02:27 AM
Deycart, that’s true, but I think this is unbranded, without a number, but at 9 1/2” its about a #4 size.
View jhut's profile
jhut
#15 posted 01-25-2013 02:28 AM
It’s cleaning up nicely in the evapo-rust. I still don’t see any marking at all. Nothing on the casting, lateral adjustment lever or the iron.
Here’s the one on ebay I mentioned with the same frog seat.
http://www.ebay.com/itm/UNION-No-6C-Corrugated-Plane-Bottom-/181067160925?pt=LH_DefaultDomain_0&hash=item2a28719d5d
