Incra 1000HD or Kreg KMS7102 Miter Gages
Forum topic by kdc68 posted 145 days ago 784 views 0 times favorited 17 replies Add to Favorites Watch
View kdc68's profile (online now)
kdc68
965 posts in 473 days
145 days ago
Topic tags/keywords: question jig
Thinking of purchasing one of these miter gages. Owners of either please provide likes and dislikes.
Your input would be appreciated
-- Measure "at least" twice and cut once
17 replies so far
View bygrace's profile
bygrace
6 posts in 165 days
#1 posted 145 days ago
I bought the incra 1000HD and have really loved it. Being adjustable to a tenth of a degree has really been useful in building lamp shade frames. If i’m off by just a tiny bit it’s multiplied by four(or the number of sides of the shade), so accuracy is very important. The extention works well, but it’s kinda a pain to switch it to the other side if you move the gage to the other side of the blade. Not really a big deal though. If i had to, I wouldn’t hesitate to buy it again.
-- Andy
kdc68
#2 posted 145 days ago
bygrace....thank you for your opinion
View John Ormsby's profile
John Ormsby
1238 posts in 1933 days
#3 posted 145 days ago
You might also look at an Osborne miter guide. They are excellent.
-- Oldworld, Fair Oaks, Ca
kdc68
#4 posted 145 days ago
John Ormsby...thanks…will check them out
View don1960's profile
don1960
195 posts in 883 days
#5 posted 145 days ago
I have the 1000HD. light years ahead of the original miter gage on my Ridgid 4512.
see above.
built like a tank.
extremely accurate and repeatable AFTER setting it up properly, which takes a while.
adjustable rail for no slop
very cool stop, easy to adjust for repeat cuts.
ridiculous amount of angle settings. All anyone could ever want.
colorful :-)
dislikes:
rail is too short. I would prefer it to be about 5 or 6 inches longer and have one more adjustment screw.
would prefer thumbscrews instead of hex bolts for all adjustments so didn’t have to have the hex wrench handy.
Overall, very pleased with it. Can’t compare it to the Kreg, although I bet the Kreg is very nice.
-- -- Don from PA
kdc68
#6 posted 145 days ago
don1960...thank you for your opinion
View fuigb's profile
fuigb
64 posts in 1154 days
#7 posted 145 days ago
I also have and enjoy the 1000hd. Worth the investment. I’ve heard good things about the Kreg , but have no experience with it.
-- - Crud. Go tell your mother that I need a Band-aid.
View mbs's profile
mbs
987 posts in 1136 days
#8 posted 145 days ago
I like the osborne best
-- Sorry the reply is so long. I didn't have time to write a short reply.
kdc68
#9 posted 145 days ago
fuigb and mbs – thanks for your input
View sprucegum's profile (online now)
sprucegum
293 posts in 194 days
#10 posted 145 days ago
I have the Incra sled that uses a very similar fence set up it works very well and I find the stop for cutting identical length pieces works flawlessly. On the down side you must use a allen wrench to loosen the set screws on the extendable part of the fence, not a real big deal it comes with a nice long ball end allen wrench but it just seems like they could have come with a way to do this without a tool.
-- A tube of calk and a gallon of paint will make a carpenter what he ain't
View Marcus's profile
Marcus
550 posts in 216 days
#11 posted 145 days ago
Another 1000HD owner, and also a big fan. Mine came out of the box as square as I could hope to get it. My only two complaints are pretty minor. Like a couple others mentioned, having to use an allen wrench to change the fence length is kind of a pain. I suppose the bolt could easily be switched out w/ a thumb screw, but it hasnt been that big of an issue so I havent swapped it out yet. Also, I found that adjusting the nylon washers to get it to fit into the track to be a bit of a pain. I am not sure if its the same on everyone’s, but the screws seem very “sticky” on mine so there is not a a nice smooth continuous turning, but really jumping an 1/8 turn. It made it a bit difficult to dial in accurately.
Oh, one other complaint…the little screw knobs on the stop block are kind of annoying too. There is not much channel for them to ride in, so I accidentally pop them out all the time.
Having said all of that, I would absolutely buy the 1000HD again and my complaints are very minor compared to how much I enjoy using the gauge.
View HorizontalMike's profile
HorizontalMike
5585 posts in 1110 days
#12 posted 145 days ago
PRO—very accurate for pieces less than ~15-18in
CON—unit flexes on longer pieces. I built a SuperSled for my crosscuts and this solved my crosscut needs. The 1000HD now hangs on the wall. I might use it in the future on smaller projects, but have found my crosscut sled so useful that I am not so sure…
kdc68
#13 posted 145 days ago
sprucegum, Marcus and HorizontalMike...thanks to you for your comments. HorizontalMike great looking sled, thanks for sharing your creativity
View roofner's profile
roofner
63 posts in 479 days
#14 posted 115 days ago
I have the hd and miter express
View waho6o9's profile
waho6o9
3059 posts in 773 days
#15 posted 115 days ago
I have an Incra and to square it up it’s recommended to shim it and I
didn’t know that when it was purchased.
I haven’t shimmed it either. I think if I’d known about the Osborne I might
have purchased that one instead.
No complaints about the Incra though, it’s very accurate so far.
