polyethylene
Forum topic by mariva57 posted 01-23-2013 08:56 PM 1254 views 0 times favorited 9 replies Add to Favorites Watch
View mariva57's profile
mariva57
666 posts in 2090 days
01-23-2013 08:56 PM
Topic tags/keywords: question
Today I bought a piece of polyethylene (such as cutting boards) with the size of 40×80 cm, thickness 1 cm, I would like to kindly know if I can cut it with the table saw.Naturalmente with the same knife that I use for
cut the wood. Thanks to those who will give me an answer.
-- The common man thinks. The wise man is silent. The stupid man discusses.
9 replies so far
View ChrisK's profile
ChrisK
1983 posts in 3167 days
#1 posted 01-23-2013 09:07 PM
There are blades for plastic, but a good sharp blade will work. Go slow so you do not burn the plastic.
-- Chris K
View bandit571's profile
bandit571
20742 posts in 2769 days
#2 posted 01-23-2013 09:19 PM
Add a thin piece of plywood under the plastic, as a support. Less cracking that way.
View crank49's profile
crank49
4032 posts in 3057 days
#3 posted 01-23-2013 09:55 PM
No problem to cut polyethylene and a wood blade works just fine.
Will not crack like plexiglass or similar hard plastics.
Try to avoid getting it too hot. It melts easily.
View RogerInColorado's profile
RogerInColorado
321 posts in 2040 days
#4 posted 02-01-2013 03:30 AM
You can route it, too, and you can plane it if you need to get rid of milling marks.
View madts's profile
madts
1866 posts in 2425 days
#5 posted 02-01-2013 04:04 AM
I would say move fast as this stuff will melt and burn. A sharp blade and fast cuts will give you what you want.
-- Thor and Odin are still the greatest of Gods.
View MrRon's profile
MrRon
4928 posts in 3329 days
#6 posted 02-06-2013 09:44 PM
Use a blade with few teeth.
View bullhead1's profile
bullhead1
228 posts in 2335 days
#7 posted 02-06-2013 10:42 PM
I cut this stuff on my band saw with out any problem. Sand the edge smooth when done.
View oldnovice's profile
oldnovice
7026 posts in 3453 days
#8 posted 02-07-2013 01:24 AM
Poly doesn’t melt as easy as thermoplastics do but the chips stick to everything … have your vacuum ready!
I have cut it with my TS and router in my RT without any issues and as RogerInColorado said you can plane the edges too!
mariva57
#9 posted 02-07-2013 06:27 AM
Thank you all, I cut the polyethylene disc
24 tooth, no problem.
