Bandsaw support?
Forum topic by bondogaposis posted 01-23-2013 12:35 AM 1139 views 0 times favorited 5 replies Add to Favorites Watch
View bondogaposis's profile
4629 posts in 2281 days
01-23-2013 12:35 AM
Topic tags/keywords: jig bandsaw
I need a way to support some rather heavy bench legs while I cut them on the bandsaw. The table on the saw is too small and my HF roller stand is a couple inches short and rather flimsy. Anybody got any good ideas?
-- Bondo Gaposis
5 replies so far
View JoeinGa's profile
7733 posts in 1937 days
#1 posted 01-23-2013 12:59 AM
Measure the height of the saw table then start with something stable (like a trash can) and add a plywood top. Then start stacking things like a concrete block or perhaps a stack of 2X6 boards till you can match the height. Just be sure the temporary support is stable.
View bullhead1's profile
228 posts in 2179 days
#2 posted 01-23-2013 01:09 AM
I built an out feed table for my band saw that also doubles as a glue up table etc with a storage shelf under it to stack wood that I resaw.
View gfadvm's profile
14940 posts in 2620 days
#3 posted 01-23-2013 02:58 AM
I use a roller stand from HD on the infeed side and built a really simple 2 legged outfeed table that is six feet long (attached to the table on the saw with 2 legs at the far end).
#4 posted 01-24-2013 01:57 AM
Thank for the tips guys. This is what I came up with, very simple Two boards, a hinge and a couple of spring clamps. It works great and very easy take off and on and folds up to be put out of the way when not in use.
-- Bondo Gaposis
2691 posts in 1955 days
#5 posted 01-24-2013 05:44 AM
Good solution!
