| Forum topic by scvwood27 | posted 123 days ago | 727 views | 0 times favorited | 11 replies | ![]() |
123 days ago |
Thinking of building garage storage cabinets that measure 80×40 that will hang on the garage wall with french cleats. i plan on using 1/2 birch ply instead of 3/4 birch ply to save weight. going to use pocket hole joints and no face frame. any thoughts on 1/2 instead of 3/4? |
11 replies so far
#1 posted 123 days ago |
I’ve been considering garage cabinets myself, for awhile now (always another priority). I though for awhile about 1/2” ply, but someone pointed out to me that the contents of the cabinets will far outweigh the material. And mass will help support those contents. -- Jim Maher, Illinois |
#2 posted 122 days ago |
I’m ready to learn something here. I didn’t know pocket holes would work in 1/2. L o n g p a u s e….......................r u m b l i n g a n d w h i r r i n g n o i s e s f r o m They won’t, at least with my Kreg jig. I used two pieces of 12mm Baltic stacked in there, and the screw exits right on the corner. Set up for this kind of joinery and you’re looking at an extended period of shop heartbreak. BUT if you’re planning face frames, you can dado the bottom and top into the sides and 1/2” material will work fine. Your shelves may need to be thicker however. If you’re planning Euro, you’ll have difficulty with hinge mounting and overlay. I wouldn’t bother with french cleats. More work, more material, and you’re giving up capacity. Just put a nailer in each box, top and bottom, and screw (not lags!) the boxes to the studs. I’ve done major footage of Euro cabinets of 5/8 material. You can also put face frames on it. It makes an inexpensive box, Melamine or even MDF. Use veneer ply for shelves. Paint as needed. Use the rest of your life. Kindly, Lee -- "...in his brain, which is as dry as the remainder biscuit after a voyage, he hath strange places cramm'd with observation, the which he vents in mangled forms." --Shakespeare, "As You Like It" |
#3 posted 122 days ago |
Lee, why not lags into the studs? |
#4 posted 122 days ago |
GRK’s are available in Home Depot and work well. |
#5 posted 122 days ago |
I think that I would prefer 3/4 plywood and I would use a face frame to stiffen it up. I would also put a couple of mid uprights in there and all the middle shelves could be loose with shelf supports. You’ve got 80 inches to distribute the weight and the cabinets would have stronger joints with the 3/4. That’s the way I would do it. It’s my 2 cents worth. helluvawreck aka Charles -- If a man does not keep pace with his companions, perhaps it is because he hears a different drummer. Let him step to the music which he hears, however measured or far away. Henry David Thoreau |
#6 posted 122 days ago |
Lags are a waste of time, unnecessary, sometimes break. If you have 5/8 sheetrock, and 3/4 nailers, 1/4 backs, 2 1/2” screws are just fine. Of course you’ll shim so the box is tight to the wall. If I were doing Euro boxes I’d do three boxes 26 inches wide (w/ 2 finished ends to make the 80). Pair of doors per box. Face frame: Two boxes 40 (or one 80 if I had a helper to raise it). Either construction method will be adequate to your garage stashing needs provided you store your priceless anvil collection somewhere else. Regarding the 1/2 material and pocket screws, here’s my result:
#7 posted 122 days ago |
Thanks Lee, I understand your reasoning on the lags. I’ve used them many times over the years in applications like this. Obviously not anywhere that I’d be concerned about appearance. But I like them because of the hex head. I find it easier to use a ratchet and socket than a screwdriver. You’re right, they do have a tendancy to break, and that can cause a lot of grief. |
#8 posted 122 days ago |
Lee, do you have your Kreg jig instructions still? As I recall, 1/2” material can be done with it but I concur however that pocket screws are not a great I have found these Jet clamps useful in putting together |
#9 posted 122 days ago |
Pocket screws will work with 1/2” material provided the correct settings and screws are used. I would use 3/4” material for the cabinets though. -- He who dies with the most tools... dies with the emptiest wallet. |
#10 posted 122 days ago |
Thanks for the help guys , im gonna go with 3/4 and face frame. |
#11 posted 122 days ago |
Aha! I see! Thanks Loren and NiteWalker for opening my eyes. It’s an adjustment I never give a thought to. Learn something every day here at LJ. Kindly, Lee -- "...in his brain, which is as dry as the remainder biscuit after a voyage, he hath strange places cramm'd with observation, the which he vents in mangled forms." --Shakespeare, "As You Like It" |
| Forum | Topics |
Woodworking Skill Share
8798 |
Woodturning
224 |
Woodcarving
28 |
Scrollsawing
61 |
Joinery
82 |
Finishing
1537 |
3554 |
15807 |
Hand Tools
2039 |
Jigs & Fixtures
496 |
Wood & Lumber
2846 |
810 |
Focus on the Workspace
903 |
766 |
Woodworking Trade & Swap
2742 |
LumberJocks.com Site Feedback
1547 |
Coffee Lounge
6165 |
