Hi LJ's! I was looking at way to create raised panels cheaply as I can't dish out a hundred or so dollars for a set of router/shaper bits. My question is, has anyone ever used the table saw set up to cut a cove, to cut the profile around the edge of a raised panel?
I think this could be a great solution for raised panels, and the frame shouldn't be too hard, a couple of rabbets and ogee profile and I should be set. Whats your opinion on this idea?
You can also cut a straight raised panel with hand planes. So people who don't have any power tools yet have a way to do it to. Of course many craftspeople choose to do it this way anyways.
Wow thanks guys! Didn't know this was already an idea, I should've done some searching first. Thanks for the videos, I can't wait to watch.
@helluvawreck - Thanks, I've seen I think Paul Sellers cut the straight raised panels by hand also, It works out pretty well with a bit of practice. Im sure that you could easily make a cove-cut raised panel by hand with a hollow moulding plane, but I don't have any yet
You can also use a "Safe T Planer" on either a radial drill press or a RAS. By tilting the tool head a few degrees you get a cove type cut. You vary the profile by the amount of tile. I did this many years ago to build my roll top desk, using a radial drill press. It does call for a lot of sanding.
Well, all you need is a raised panel bit… not a whole
set.
The issue with doing them on the table saw is
you'll have to do a lot of sanding to get rid of
the machine marks.
There are moulding heads for table saws. They
aren't expensive and not a lot of people like to
use them anymore, but they work and you can
do some very creative things with them.
Related Threads
LumberJocks Woodworking Forum
2.5M posts
96K members
Since 2006
