Air Dried Walnut for Furniture/ Workbench Question
Forum topic by Dan3 posted 121 days ago 689 views 0 times favorited 19 replies Add to Favorites Watch
View Dan3's profile
Dan3
3 posts in 122 days
121 days ago
Hi All,
I’m new to woodworking so bare with me.
I bought some rough air dried walnut which was stored outside for well over a year. The 2 boards are 13 feet in length, 9 inches wide and 2.75 inches thick. I bought them for making a work bench top. I wanted a lighter color wood but this was the only dried thick lumber he had and the price was right. My question is since this wood was stored outside do I need to dry it inside before I use it for my bench? It looks like nice wood and I will have a lot of extra when I’m done so would I be able to also use this for furniture even though it was dried in this manor? The wood seems to be very striahgt, but it’s just a little damp.Any thoughts?
Thanks,
Dan
19 replies so far
View Melanie's profile
Melanie
13 posts in 124 days
#1 posted 121 days ago
Your wood needs to be acclimated to the environment that it will be kept in. Do you have a wood moisture sensor? On the low end they can be purchased for as little as $30. on up to hundreds. The wood might look dry but there is nothing worst that spending time working on a piece that looks beautiful at first until the moisture leaves & along with it makes vacant gaps in the wood.
View Jorge G.'s profile
Jorge G.
1311 posts in 644 days
#2 posted 121 days ago
Jeeez men, buy some pine to make your bench and save the walnut for something better. Those are some awesome boards, why waste them on something that is going to get nicked, scratched, etc? If you plan to use your bench for wood work, buy some cheap wood, if you plan it to be for show, then go buy some maple as well so it makes contrast with your walnut… ;-)
-- Just because you’ve always done it that way doesn’t mean it’s not incredibly stupid.
View MedicKen's profile
MedicKen
1560 posts in 1631 days
#3 posted 121 days ago
I agree with Melanie, it needs to acclimate. Also be prepared for some movement when milling the lumber. When you first cut it, cut it over size by about 1/2” to allow for movement. There is a good possibility that when milled you will release tension in the lumber and it will warp, twist etc. I would also let the boards sit for a few days after the initial milling to allow for more acclimation.
View Brandon's profile (online now)
Brandon
3753 posts in 1120 days
#4 posted 121 days ago
If it’s only been air drying for a year, it probably isn’t dry enough. As a general rule, you want it to air dry one year for every inch of thickness. Of course, the moister meter will either confirm or deny this.
So if you need a bench now, perhaps Jorge is right. I personally prefer benches made of hardwood over pine, but there are many nice benches made of SYP that function perfectly fine.
-- "hold fast to that which is good"
View JesseTutt's profile
JesseTutt
707 posts in 280 days
#5 posted 121 days ago
The wood is probably not dry enough. If there is a board you could cut about a foot off of and then use a moister meter on the center of the fresh cut that would give you a useful reading. You want 6-8% moister.
I agree with Jorge, save the walnut. Buy some dense heavy pine 2x?? and mill them down and glue them so that the 2” edge is up. This will form a thick workbench top and you have the more valuable walnut for projects.
View shampeon's profile
shampeon
517 posts in 352 days
#6 posted 121 days ago
Just to be clear here, when you bought the wood, was it air-dried, and then you stored it for a year outside? Or did the sawyer say that he had air-dried it for a year when you bought it?
The supposed disadvantage of darker-colored work benches is that you don’t get as much light and contrast on your workpiece.
View pintodeluxe's profile
pintodeluxe
1743 posts in 982 days
#7 posted 120 days ago
Air dried wood is the absolute best kind. Lumber that is properly stacked, covered and stickered outside, will dry slowly down to equilibrium with the climate. In my climate that is about 12-15% moisture content. From there I put them in a home dehumidification kiln, which is nothing more than a space heater, box fans and a home dehumidifier in a confined space. Run that for about two weeks, and you will have nice dry lumber at 6-8% MC.
If your workbench is destined for a a non-heated shop, you can get by with drying to about 10% MC. Bringing the wood into a heated / air conditioned home for a month will accomplish the 10% MC.
Best of luck!
View MonteCristo's profile
MonteCristo
2060 posts in 358 days
#8 posted 120 days ago
I wouldn’t use walnut for a bench (top) for two reasons. One is it isn’t all that hard and the other is its dark color will be a real pain.
View Rob Drown's profile
Rob Drown
638 posts in 2002 days
#9 posted 120 days ago
Sounds like you got some thick walnut. Awesome. Save it for some furniture. Air dried walnut take on a much more beautiful appearance than kiln dried. Kiln dried walnut just looks muddy. Depending on you part of the country, souther yellow pine or Douglas fir are great materials for benches.
-- The expectations of life depend upon diligence; the mechanic that would perfect his work must first sharpen his tools. Confucius, 经过艰苦的努力的梦想可以成真
View Don W's profile
Don W
9952 posts in 737 days
#10 posted 120 days ago
I’m in the “don’t use the walnut for a bench” crowd. I also agree a 3” piece is probably not dry.
View John Ormsby's profile
John Ormsby
1235 posts in 1906 days
#11 posted 120 days ago
You also want to check it very carefully for any small holes that would be an indication of an infestation of boring beetles. You don’t want them in your house or shop. they love walnut. walnut that is stored outside is especially vulnerable to them.
-- Oldworld, Fair Oaks, Ca
runswithscissors
609 posts in 194 days
#12 posted 120 days ago
After reading what you have planned, I had to make an emergency appointment with my therapist. Up here in the Pac. N. W., walnut is rare, exotic, and very espensive.
View newwoodbutcher's profile
newwoodbutcher
288 posts in 1019 days
#13 posted 120 days ago
I can’t see where you are located but if you are close to Southern California, I would be happy to trade some hard maple for some of that Walnut
-- Ken
View Dan3's profile
Dan3
3 posts in 122 days
#14 posted 120 days ago
Thanks everyone for the reposnses. I believe I’m going to use this for my next furniture project instead and contact the mill to see just how long it’s been air drying. The bench is going to have to be made out of pine for now. They have a bunch more of this at the yard so I think I’m going to pick up a few more boards for some future projects. I calculated it out and I got it for a $1.64 a board foot. Maybe I will make the front vise and tail vises in walnut for some contrast.
Pintodeluxe, I’m going to take your suggestion on get it dry once I find out how long over a year it’s been sitting.
For those of you who asked, I’m on Long Island in NY.
Thanks,
Dan
Jorge G.
#15 posted 120 days ago
wow, that is a great price…...you better get as much as you can.
