Making Big Leaf Maple Pop
Forum topic by cdarney posted 01-20-2013 11:22 PM 1833 views 0 times favorited 9 replies Add to Favorites Watch
View cdarney's profile
cdarney
104 posts in 2994 days
01-20-2013 11:22 PM
I have very nice piece of Big leaf maple that I’m working into a project. Just throwing a little alcohol on to the wood shows amazing figure. I like to maximize the “pop” in the figure. Does anyone have sugguestions for maximizing the figure in this beautiful piece of wood?
I tried transtint dye with birdseye maple to enhance the figure but I don’t have much “spare” wood to work with for testing. I don’t want to darken the maple significantly but would like the maximize the figure.
Thanks…Chuck
9 replies so far
View jumbojack's profile
jumbojack
1674 posts in 2588 days
#1 posted 01-20-2013 11:38 PM
Tung oil will pretty much do what the alcohol did.
View NewEnglandsWoodWorks's profile
117 posts in 2565 days
#2 posted 01-20-2013 11:42 PM
Marc Spagnuolo made a video specifically about this. Just search on youtube pop goes the maple…
-- Brett
View shipwright's profile
shipwright
7965 posts in 2761 days
#3 posted 01-21-2013 12:03 AM
It’s hard to beat shellac, particularly finished with a French polish.
View bhog's profile
bhog
2236 posts in 2654 days
#4 posted 01-21-2013 12:09 AM
I really like dying figured big leaf,followed by shellac like shipwright suggested.
There are a couple things in my projects that are big leaf maple, all dyed followed by shellac.
-- I don't drive a Prius.
View MonteCristo's profile
MonteCristo
2099 posts in 2152 days
#5 posted 01-21-2013 08:06 PM
If it’s that good, I would skip the dye and use tung oil alone.
View Ripthorn's profile
Ripthorn
1454 posts in 2949 days
#6 posted 01-21-2013 08:13 PM
In building my guitars I did quite a bit of testing to find what would best pop the figure while keeping it natural. Oils work well, as does shellac, but the absolute best product I found was actually a can of Krylon crystal clear in satin. It was all of $4 at walmart and beat out my oils and such. This guitar neck was finished that way:
cdarney
#7 posted 04-02-2013 12:35 AM
I ended up sanding the Big Leaf Maple down to 600 grit with Abra. I then used clear Watco Danish oil until the wood stopped taking it – which was quite a bit then sanded it lightly when very dry. When I attached it to the table top I was working on I sanded it the entire top and covered with sanding sealer shellac. The other wood was Cocobolo and it turned the maple a rather unattractive yellow. I sanded everything done to bare wood. After a couple of tries at this I learned NOT to contaminate the maple with the cocobolo! I wanted a harder top since it’s a coffee table so I used Arm-R-Seal on it. Turns out the Arm-R-Seal doesn’t like to dry on Cocobolo even when I used mineral spirits and acetone to clean the Cocobolo first. I cleaned it off and sanded again to wood. I finally brushed on several thick coats of sanding sealer shellac and wet-sanded down to 2000 grit.
Unfortunately the pictures can’t do it justice. The figure and chatoyance of the BL Maple is spectacular.
http://lumberjocks.com/projects/82131
Thanks very much for all suggestions.
View Clint Searl's profile
Clint Searl
1533 posts in 2325 days
#8 posted 04-03-2013 06:43 PM
Ripthorn has it right. Water white gloss acrylic lacquer will emphasize the grain just like the alcohol did without adding any color. Also, don’t sand beyond 220.
cdarney
#9 posted 04-03-2013 06:53 PM
I worked with several test pieces and found that the BL Maple looked better sanded further than 220. It’s a softer maple I guess. Using Tiger Maple (hard maple) on another project 200 was the max without losing figure. 180 grit was good as well.
I’ll try the acrylic the next time I work with figured maple.
