Advice on mounting end vice wanted
Forum topic by JesseTutt posted 119 days ago 289 views 0 times favorited 1 reply Add to Favorites Watch
View JesseTutt's profile
JesseTutt
707 posts in 277 days
119 days ago
Topic tags/keywords: work bench end vice vice
I want to mount a end vice on my new workbench. I bought the screw assembly from Woodcraft while they had it on sale. I am debating if I should screw it direct to the bottom of the 2” thick top or use a space to lower it between 1 and 2”. Lowering the rods will allow me to clamp a wider board horizontal in the vice, but would take more time.
What do you think?
1 reply so far
View PurpLev's profile
PurpLev
7730 posts in 1815 days
#1 posted 119 days ago
for an end vise?
end vices are usually used to clamp things on the workbench with bench dogs. for clamping wide boards for working on their edges you’d usually want to use the front vise + deadman/alternative, so to answer your question I wouldn’t put the extra effort into the end vise if it won’t be necessary.
that said, each woodworker has their own ways of doing things. if you plan on using the end vise for edge work, and plan on clamping wide boards in it, than obviously you’d want to lower the vise.
what are you really planning to using this vise for?
