| Forum topic by boxcarmarty | posted 150 days ago | 525 views | 0 times favorited | 31 replies | ![]() |
150 days ago |
I’m looking for opinions on mounting glass in doors and/or framework. Usually I would use a bead of silicone or frame it in with quarter round. I recently had a fellow woodworker recommend these clips, but I’m not sure they are all that practical. While they appear better then other clips that I have worked with, They seem to be bulky and any bump to the clip or to much pressure can break the glass. (yes I can verify that) I am interested in which clips or methods others have used and the goods and bads of it all….. -- My mind is like lighting, one brilliant flash, then its gone..... |
31 replies so far
#1 posted 150 days ago |
#2 posted 150 days ago |
Duct Tape. It now comes in designer colors!!! -- Randy-- I may not be good...but I am slow! |
#3 posted 150 days ago |
I use Lexcel clear caulk to glue the glass in after the door frame is finished. A few glazing points hole the glass in place, caulk all the way around and clean up/ smooth out the bead with mineral spirits/ paint thinner. Lexcel is not silicone, it never lets loose! Takes a few days to fully cure . No rattle at all. Stays flexible. -- Fine Custom Woodwork since 1978 |
#4 posted 150 days ago |
Wdwerker, Thanks for the tip on Lexcel. I’ll check it out….. Randy, I knew I could count on your 2 cents. I’ll be waiting for my money’s worth….. -- My mind is like lighting, one brilliant flash, then its gone..... |
#5 posted 150 days ago |
I always just put glass in with quarter inch by quarter inch strips that I attach behind the glass with a 23ga pin nailer. |
#6 posted 150 days ago |
Marty I haven’t mounted glass in years, other than in picture frames. I use glazing points for that. I wouldn’t know where to start. I am interested in finding out what you pick. Good luck. -- Superdav "No matter where you go - there you are." http://chiselandforge.com |
#7 posted 150 days ago |
Dave, I usually just use silicone to glue the glass in and probably continue to do so. I was just curious as to what others used. The Lexel that Wdwerker mentioned sounds like it’s worth looking into….. -- My mind is like lighting, one brilliant flash, then its gone..... |
#8 posted 150 days ago |
I’m curious. |
#9 posted 150 days ago |
I have seen Lexcel at Lowes in a hand squeeze tube. I get mine from a hardware store in a caulk tube for under $9 . -- Fine Custom Woodwork since 1978 |
#10 posted 150 days ago |
Oops double posted -- Fine Custom Woodwork since 1978 |
#11 posted 149 days ago |
William, I use it on the edge and top of the glass to hold it in place when it dries…. Wdwerker, I seen it was available in the small tube as well as the caulking tube. I’ll check Lowes and Menards around here….. -- My mind is like lighting, one brilliant flash, then its gone..... |
#12 posted 149 days ago |
last window i did was some kind of clear plastic pane just brads on the edge -- Jesus Is Alright with me |
#13 posted 149 days ago |
I set the glass in place then run a bead of silicone around it and let it dry. Then I cover that with 1/4 round or any suitable strip of wood. Brads only, no glue.. in case I ever have to replace it. I do the silicone after setting the glass in place so I can cut it free if I have to. That lexel works great too, but I only use that when it might be visible. I like how clear it is. It’s a polyurethane caulk that smells like model cement, and melts plastic like model cement too. Found that out when I used it on some plexiglass. There are other brands besides Lexel, but I think Lexel is the brand that made it popular. A little story about glass and silicone caulk. Some years ago I went to remove a mirror that was glued to a door. Rather than trying to get a flexible scraper back behind the mirror, I figured I could just break the mirror to pieces, then scrape the pieces off the door. I whacked it right in the middle with my hammer and nuthin.. not a crack, not even a chip. So I hit it a few more times, and then a few more. I figured maybe it wasn’t glass at all, but maybe acrylic or something… but no, it was glass. And no matter how much I hammered away at it, that darn mirror would not crack! Turns out the beads of silicone behind it, about every few inches, was actually absorbing the shock. What finally worked is I used a glass cutter to score it, then it would break at the score. Anywayz, that just goes to show how a bead of silicone not only prevents the glass from rattling… it can also help prevent it from breaking. I’m not sure polyurethane caulk has the same properties.. I think probably not but it might. -- I'll grow up when ketchup bottle farts stop being funny. |
#14 posted 149 days ago |
Thanks eddie….. Thanks Ted, It sounds like the old fashion way is the best way….. -- My mind is like lighting, one brilliant flash, then its gone..... |
#15 posted 149 days ago |
who you callin old? -- I'll grow up when ketchup bottle farts stop being funny. |
| Forum | Topics |
Woodworking Skill Share
8848 |
Woodturning
246 |
Woodcarving
32 |
Scrollsawing
69 |
Joinery
96 |
Finishing
1600 |
3595 |
15984 |
Hand Tools
2101 |
Jigs & Fixtures
501 |
Wood & Lumber
2909 |
813 |
Focus on the Workspace
925 |
778 |
Woodworking Trade & Swap
2778 |
LumberJocks.com Site Feedback
1553 |
Coffee Lounge
6134 |
