best handplane
« back to Hand Tools forum
Forum topic by airman posted 01-20-2013 01:03 AM 1553 views 0 times favorited 18 replies Add to Favorites Watch
View airman's profile
airman
51 posts in 3179 days
01-20-2013 01:03 AM
The Wood Show will be here soon and I have almost convinced myself to buy a good hand plane. Any thoughts as which one it should be? I’m not necessarily talking brand as much as which model. All suggestions appreciated
18 replies so far
View Alexandre's profile
Alexandre
1417 posts in 2154 days
#1 posted 01-20-2013 01:10 AM
Depends… A #4 Lie Nielsen brass is my dream…
with a pm-v11 blade.
-- My terrible signature...
View Loren's profile
10244 posts in 3611 days
#2 posted 01-20-2013 01:39 AM
Among bench planes, a fine #4 is a nice thing
to have as it used for final surfacing. The heavier
castings in premium planes add mass and the
thicker irons help make fine cuts. More
concentrated mass helps a plane take finer
cuts.
View Francisco Luna's profile
Francisco Luna
943 posts in 3356 days
#3 posted 01-20-2013 01:56 AM
Low angle, bevel up Jack plne with 25, 38, 50 degrees and toothed blades.
-- Nature is my manifestation of God. I go to nature every day for inspiration in the day's work. I follow in building the principles which nature has used in its domain" Frank Lloyd Wright
View MonteCristo's profile
MonteCristo
2099 posts in 2151 days
#4 posted 01-20-2013 08:18 PM
Lee Valley planes are good value. They are way better than big box junk and not as expensive as Lie-Nielsen. The latter are usually ranked tops among the widely available ones but they ain’t cheap ! Don’t go cheaper than Lee Valley as there is nothing more frustrating to use than a cheap plane !
View rockindavan's profile
rockindavan
299 posts in 2599 days
#5 posted 01-20-2013 09:26 PM
If you don’t have a block plane, thats your best bet. I have the Veritas NX60 which is a marvelous piece of work. My brother has the DX60 which lacks the rust resistance but he prefers the patina.
View sikrap's profile
sikrap
1121 posts in 3322 days
#6 posted 01-20-2013 09:47 PM
It depends greatly on what you want to do with it. A good block plane is almost a necessity. In that vein, the Lee Valley low angle w/adjustable mouth is a fantastic plane. If you can afford it, the Lie Nielsen rabbeting block plane is also a fantastic tool. If you’re looking at bench planes, its really dependent on what you want it for.
-- Dave, Colonie, NY
View exelectrician's profile
exelectrician
2327 posts in 2390 days
#7 posted 01-20-2013 10:08 PM
A refurbished Bedrock eagerly won with crazy bidding on ebay, will be your pride and joy for as long as you have it. I love to do the refurb part so saving a bunch in the process. Either way the plane becomes part of you with the sweat equity and care and attention to every detail.
-- Love thy neighbour as thyself
View PurpLev's profile
PurpLev
8534 posts in 3611 days
#8 posted 01-20-2013 10:14 PM
is this for actual use or just to “have”?
if it’s just to “have” than – any plane might do.
if it’s for actual use – than if you don’t have any hand planes a block plane would be a good place to start. any other hand plane sort of relies on yet another plane to work together (jointer + finish for example), but a block plane is very versatile and can be used in conjunction to machine work, as well as hand tool work (chamfering, end grain, cleaning up, rabbeting, etc)
airman
#9 posted 01-20-2013 10:45 PM
I plan on using it mainly for getting a straight edge and for smoothing. Is a block plane still a “best” bet and if so which one?
View JayT's profile
JayT
5586 posts in 2174 days
#10 posted 01-20-2013 10:54 PM
I’d be looking at a #5 then. It is long enough for some short jointing and still able to work as a smoother, as well.
View Don W's profile
Don W
18684 posts in 2530 days
#11 posted 01-20-2013 10:58 PM
Getting a straight edge on what? Typically a joiner is for getting straight edges (a #7 or #8). A smoother (#4 +/-) is for smoothing, and a block plane is for detail work, rounding edges, fitting joints etc.
I typically recommend starting with a good block, then move to a #4.
View OnlyJustME's profile
OnlyJustME
1562 posts in 2340 days
#12 posted 01-20-2013 11:07 PM
then again Paul Sellers uses a Stanley #4 size for just about everything. I would also recommend a nice #5 a.k.a. Jack plane though. It’s not called a Jack plane for nothing(jack of all trades). A jack plane (usually around 14” in length) with a small block plane would be a good start. whether you want to go vintage and rehab/tune it up or brand new is up to you. I like to save a few $$ and spend some time tuning up a vintage plane and getting to know it better. Of course i can’t afford the good new ones either but that’s besides the point. lol
-- In the end, when your life flashes before your eyes, will you like what you see?
View racerglen's profile
racerglen
3112 posts in 2743 days
#13 posted 01-21-2013 12:07 AM
Love the thought Alexandre, a L/N with a L/V, Veritas blade….....................
-- Glen, B.C. Canada
View Kimchi4u's profile
Kimchi4u
18 posts in 1959 days
#14 posted 01-21-2013 12:41 AM
The best hand plane is the one you’re most comfortable using.
-- Project Coordinator at Nord Alta Construction
View Manitario's profile
Manitario
2629 posts in 2846 days
#15 posted 01-21-2013 12:55 AM
If I had to limit to one hand plane, I’d buy a bevel up #5 from Lee Valley. I have used it for everything from dimensioning to final smoothing. It also is easy to get a couple of different blades with different blade angles to work figured wood. That said, if I was just buying a new dedicated smoother I’d go with a Lie-Nielson #4 or 4 1/2.
