Help me with cedar
Forum topic by joeyinsouthaustin posted 01-19-2013 10:16 PM 5008 views 0 times favorited 31 replies Add to Favorites Watch
View joeyinsouthaustin's profile
joeyinsouthaustin
1294 posts in 1945 days
01-19-2013 10:16 PM
Topic tags/keywords: question finishing cedar
I need to find a finish or oil that is compatible with cedar. Client would like a wet or oiled look, but not too glossy. I know that many finishes react with cedar, so I thought I would tap into the LJ brain trust on this one. This entire house is western red cedar, inside and out. They want to do the inside, so needs to be compatible with interior life.
-- Who is John Galt?
31 replies so far
View Jim Finn's profile
Jim Finn
2592 posts in 2794 days
#1 posted 01-20-2013 01:58 AM
I use lacquer on cedar.
joeyinsouthaustin
#2 posted 01-20-2013 02:16 AM
the client has refined their idea. they want to “refresh the wood” it is 40 years old in the raw, and they feel it is dry looking, and want it to look “fresh cut” this may not be possible. Still interested in thoughts. It does look like some type of lacquer has been used on the exterior.
View Moron's profile
Moron
5032 posts in 3766 days
#3 posted 01-20-2013 02:49 AM
any furniture grade oil sold in laymen’s stores will work, so will the urethanes which I am not a fan of but some folks are.
Oils are good for high traffic areas as the are easy to repair, easy to apply but they do require maintenance. Urethanes (I repeat I do not like them) have some elasticity to them and on cedar, a rather soft and dentable wood, soft, allows for some forgiveness but its slow going application techniques are hindering
lacquer on cedar is perfect so long as you know it isnt subject to even the slightest bruise as each bruise leaves fractures on the finish so personally I would use a high end marine varnish, perhaps and maybe add more flexibility to the varnish by an adding oil, a catalyst and some thinner…….its the best of all worlds
joeyinsouthaustin
#4 posted 01-20-2013 02:57 AM
moron I agree on lacquer… it is not appropriate for the interior. too much traffic and will prolly end up looking to glossy. The original idea from the home owners was a wax. I just am not experienced enough to know what waxes or products like that would react with cedar. I thing an oil is the way to go, because they are looking to revitalize more than finish the wood. A wax would be a bear on the texture of this cedar. It is a very unique house, and client. So the question is what oil is best matched to ceday.
View JesseTutt's profile
JesseTutt
853 posts in 1983 days
#5 posted 01-20-2013 02:59 AM
Somewhere I have seen cedar oil that is supposed to make the wood look good and restore (add) the cedar smell.
View gfadvm's profile
gfadvm
14940 posts in 2562 days
#6 posted 01-20-2013 03:03 AM
Are we talking rough cedar here? Or planed but unfinished smooth surface?
joeyinsouthaustin
#7 posted 01-20-2013 03:05 AM
cedar oil appears to restore the smell of cedar. Does anyone know if it refreshes the wood. The home owners keep talking about how there teak table looks after they oil it to keep it from drying out
View bandit571's profile
bandit571
18908 posts in 2555 days
#8 posted 01-20-2013 03:07 AM
I have always used three coats of Minwax Gloss Poly, brushed on. I only finish the outside of a Cedar Chest, if it is solid cedar. I never finish cedar that is inside, like a liner.
The outside of a chest, made of solid Red Aromatic Cedar.
and a look under the lid.
No need for a fancy oil. Just some sandpaper. Sand the exposed cedar to bring the aroma right back. Leave the 220 grit nearby.
joeyinsouthaustin
#9 posted 01-20-2013 03:13 AM
gfadvm and all. This is rough cedar, and years have made it rougher. The home is an all cedar construction. There is NO drywall in this home. The same siding that was used on the outside was used to finish the inside. Even the cabinets are made from cedar. I think the original owner, who built the home, might have liked cedar. Cost does not seem like an object to these folks, but I want to get a good suggestion for them.
Moron
#10 posted 01-20-2013 03:16 AM
do it
joeyinsouthaustin
#11 posted 01-20-2013 03:16 AM
bandit571 I like the comment, but do you have a picture that shows more of the finished side. They are quite concerned about the “sheen” factor. It appears you answer the question that polyurethanes don’t react with cedar and discolor, so I assume that I could do a matte type finish. Have you experience with that?
joeyinsouthaustin
#12 posted 01-20-2013 03:26 AM
Moron I would like to avoid urethanes. There are a lot of reasons why, and I think you know, what oils do you suggest. I would like to know what oils could potentially react with the cedar.
BTW: All is currently unfinished in any way.
bandit571
#13 posted 01-20-2013 03:46 AM
I have a few more such pictures in my Projects pages. I prefer gloss, but one could knock down the shine if it is wanted. Poly will Darken the red, making it stand out more. The “white” sap wood will turn a yellow. If one uses the water-borne poly, no changes in colour happen. All depends on what look you are after.
Note: On that chest, it took two coats just to get a shine. i had to sand again, and add a third coat. The wood came from an old tree on a friend’s property. He had it rough sawn into 2×8 x 12’ planks, I did a lot of resawing to get things down to what is shown. I only used three of those old planks.
The biggest problem with this wood IS the oil in it. It will affect the glue-ups. I will leave thing open to let it “air dry” as i work with it. Of course, the shop does smell pretty good, for a few days.
Moron
#14 posted 01-20-2013 04:02 AM
why do resumes determine pay scales ?
why does word of mouth travel faster then the digital world ?
how many square ft of wood are we talkn about ?
Moron
#15 posted 01-20-2013 04:09 AM
its fundamentally important to realize not just your own limits but those to whom surround you
showing 1 through 15 of 31 replies
