| Forum topic by Rustic | posted 1716 days ago | 21824 views | 2 times favorited | 8 replies | ![]() |
1716 days ago |
Has anyone made a beeswax, turpentine, and boiled linseed oil finish? I made it to the recipe, but when I checked on it this morning, the beeswax and turpentine had solidified. Is this supposed to happen? -- www.carvingandturningsbyrick.com, Rick Kruse, Grand Rapids, MI |
8 replies so far
#1 posted 1716 days ago |
Hello Rick; First question I would have to ask is; ”what is the recipe that you are using?” Next I’m wondering what you mean when you say that you checked it this morning and the mixture had ‘solidified’. In my way of working a finish into the wood, (boiled linseed oil and beeswax) I would add that this is a ‘hand rub finish’ and that the lesser you apply is the best way to go….and then comes more of many lesser coats also. When you speak of ‘solidify’ I must admit that that makes me want to ask as to how thick was the coat you put on, was the application done by hand and rag and then did you come back and remove any extra finish//residue that had not as yet soaked into the wood….say after 20-30 minutes or so? While I use boiled linseed oil and beeswax for a wood finish, I must admit that I’ve never had it ‘solidify’ on me yet….since what remains after the excess is wiped off, is only whats all-ready now absorbed into the wood. I will admit that I have had the residue become ‘gummy’ and take weeks to dry when I one time put this mixture on too thick and did not re-move the over-excess. Hope this helps some….and if not, well write some more and we’ll see what else is happening. Thank you. -- --frank, NH, http://rusticwoodart.tumblr.com/ |
#2 posted 1715 days ago |
I am using equal parts of turpentine,beeswax, and blo. The recipe called for the turpentine and beeswax to be combined after shaving the beeswax. The concept is that the turpentine will dissolve the beeswax overnight. When i checked the mixture this morning it was solid. I got the recipe from Woodsmith magazine. -- www.carvingandturningsbyrick.com, Rick Kruse, Grand Rapids, MI |
#3 posted 1715 days ago |
Hello Rick; Take a large pan and fill with some water (paying attention that you do not float the can in the water) and place on a stove, do not bring the water to the point of boil, but now place the mixture in a smaller can and place inside the pot of water that is being heated. Care-fully stir the mixture, paying attention so as to not splash the mixture outside of can and onto the stove. Now when the mixture is dissolved, you can apply the warmed and dissolved mixture to the wood with a small rag and after letting sit for 20-30 minutes, be sure and wipe off all excess mixture that has not soaked into the wood. Remember that when applying the wax mixture, lesser is better and then do multiple coats. Here is a picture of a table I completed for a show back last April, where I used boiled linseed oil and beeswax on a curly maple top. The legs are white oak done up with multiple coats of shellac.
Again….I hope this helps some, and if you still having an issue with the mixture be-coming solid, ask some more and we will try and explore further. I really believe though that the problem//opportunity is in the understanding that the mixture needs some warmth to it, in order to get the wax work-able as a liquid. If one is not wanting to use the sun and a window or a stove top, they also sell glue pots which work safe also. I might add that in the winter time I also use the top of one of my wood stoves to heat the mixture up into a more work-able liquid. Once again….; Thank you. -- --frank, NH, http://rusticwoodart.tumblr.com/ |
#4 posted 1715 days ago |
I used to make beeswax/linseed oil/turpentine and it always solidified, especially in cold weather. It should be slightly soft. In hot weather, its’ soft. |
#5 posted 1715 days ago |
ok thanks Frank that helps.. I will give that a try cmaeda next time -- www.carvingandturningsbyrick.com, Rick Kruse, Grand Rapids, MI |
#6 posted 1714 days ago |
Well, I am trying out the mixture. I stirred it and some beeswax was still solid, but not as bad, it seems to be doing ok. -- www.carvingandturningsbyrick.com, Rick Kruse, Grand Rapids, MI |
#7 posted 1710 days ago |
Frank has given you some good direction. Dave |
#8 posted 1710 days ago |
I am not making furniture I am going to put it on some toys and games that I make -- www.carvingandturningsbyrick.com, Rick Kruse, Grand Rapids, MI |
| Forum | Topics |
Woodworking Skill Share
8788 |
Woodturning
219 |
Woodcarving
28 |
Scrollsawing
61 |
Joinery
78 |
Finishing
1528 |
3544 |
15758 |
Hand Tools
2032 |
Jigs & Fixtures
494 |
Wood & Lumber
2837 |
808 |
Focus on the Workspace
901 |
766 |
Woodworking Trade & Swap
2738 |
LumberJocks.com Site Feedback
1547 |
Coffee Lounge
6153 |
