Where Can an Arbor Wrench Be Purchased?
Forum topic by DavidNJ posted 01-19-2013 04:39 PM 12495 views 0 times favorited 31 replies Add to Favorites Watch
View DavidNJ's profile
DavidNJ
389 posts in 1864 days
01-19-2013 04:39 PM
My old Skil 3400 Type 2 long ago lost its arbor wrench. How careless of it!
I’m flipping blades quite a bit lately and would like to get another. Is there a place where a 1.25” arbor wrench can be purchased?
Thanks,
David
31 replies so far
View DIYaholic's profile
DIYaholic
19483 posts in 2545 days
#1 posted 01-19-2013 06:15 PM
NO, is the simple answer. Sorry!
What about a cheapo HF wrench?
View bandit571's profile
bandit571
18894 posts in 2554 days
#2 posted 01-19-2013 06:22 PM
H-F, Sears/Craftsman both sell a open end 1-1/4” wrench. How much room do you have to work with, in order to get a wrench in there? All one needs the wrench for is just to loosen the nut enough it can be taken off by hand, anyway.
last time i looked, a Craftsman 1-1/4 open end wrench was about ~~$19 or so.
PS: Do you have a Cresent Adjustable wrench that can open that far? It will get you by until you can buy a new wrench. BTDT.
DavidNJ
#3 posted 01-19-2013 06:52 PM
The answer isn’t so simple. The blade has to be about 1/8” wide.
bandit571
#4 posted 01-19-2013 06:55 PM
Then, buy the H-F one and grind it thinner. Make it into a LARGE tappett wrench.
View Cosmicsniper's profile
Cosmicsniper
2202 posts in 3029 days
#5 posted 01-19-2013 07:08 PM
I found an old, open end wrench and ground it down to a width that would fit my Unisaw.
-- jay, www.allaboutastro.com
View NormG's profile
NormG
5889 posts in 2874 days
#6 posted 01-19-2013 07:13 PM
See if your saw is hiding the wrench inside itself
-- Norman - I never never make a mistake, I just change the design.
View SCOTSMAN's profile
SCOTSMAN
5845 posts in 3455 days
#7 posted 01-19-2013 07:24 PM
Yeh if you have been hearing a special sound like heavy clunking when the saw is running then write to me I know where it is, and won’t charge you much for my time. Alistair
View MonteCristo's profile
MonteCristo
2099 posts in 2059 days
#8 posted 01-19-2013 08:05 PM
These arbor nuts are usually a fairly common size. Odds are a wrench off something else will work . . .
View lieutenantdan's profile
lieutenantdan
176 posts in 2176 days
#9 posted 01-19-2013 10:58 PM
Can always have a couple made by your local machine shop.
-- "Of all the things I have lost in life, I miss my mind the most."
DavidNJ
#10 posted 01-20-2013 03:45 AM
The question is which other will work? I could probably make one using a jigsaw, an 1/8” steel strip, and a bunch of time.
Skil still makes this saw, so buying one should be possible.
bandit571
#11 posted 01-20-2013 04:17 AM
Maybe a picture of what we are talking about? If you only have 1/8” of room for a wrench, how do you get a hand in there to remove the nut, or start it back on? Are we talking the arbor nut, or just a way to “lock” the arbor in place?
View History's profile
History
399 posts in 1852 days
#12 posted 01-20-2013 06:15 AM
Bandit brings up a good question. You don’t need an arbor wrench to remove the blade from a table saw. For the arbor nut, an open end wrench or a cresent wrench will do the job. But if you insist that you have to have an arbor wrench then I guess that it’s your decision on how much effort you want to put into finding one, or making one. I made one for a radial arm saw, it wasn’t too difficult.
DavidNJ
#13 posted 01-20-2013 01:08 PM
It is just a flat piece of metal. the limit is the distance between the arbor and the the motor.
4823 posts in 2363 days
#14 posted 01-20-2013 01:28 PM
Sometimes metric bicycle wrenchs will work, they don’t have to fit perfectly. I use one on the inside of my Dewalt RAS to hold the arbor. Look up a Park HCW7. It’s a 32MM (close to 1 1/4”) headset wrench that’s very thin…it likely will work for you.
View Don W's profile
Don W
18558 posts in 2438 days
#15 posted 01-20-2013 02:10 PM
I’ve used Bandit’s suggestion of grinding down a open end wrench for all kinds of similar applications. Why would it not work?
showing 1 through 15 of 31 replies
