Solid or ply for shelves
Forum topic by sawedoff posted 01-19-2013 03:44 PM 5656 views 0 times favorited 14 replies Add to Favorites Watch
View sawedoff's profile
sawedoff
155 posts in 2655 days
01-19-2013 03:44 PM
What’s the general concensus about what to use for shelves? I’m looking at building some either out of oak boards or ply or maple wood or birch ply. The longest shelf would be 48”, however, I believe there will be a divider which would make them slightly less than 24” each.
Thanks
-- still wet behind the ears.....
14 replies so far
View FeralVermonter's profile
FeralVermonter
100 posts in 2206 days
#1 posted 01-19-2013 04:03 PM
For a two foot span, any of these should work just fine.
View oldretiredjim's profile
oldretiredjim
206 posts in 2620 days
#2 posted 01-19-2013 04:08 PM
I use birch ply but I do reinforce 4’ spans. Too much flex. My wife is a potter and storing her stuff between shows creates issues for shelves. Like storing concrete on shelves. The oak will be much better and with some thought you can make the shelves such that the oak can be reused when the shelving inevitably becomes obsolete. It is much harder to reuse the ply.
View MJCD's profile
MJCD
582 posts in 2606 days
#3 posted 01-19-2013 04:33 PM
Depending on your design requirements, you could make the shelving from the ply, and put a 1” x 1” Oak/Maple banding on the front lip – this would had both strength and ‘substance’ to the shelf. Any 48” span needs support.
MJCD
View MonteCristo's profile
MonteCristo
2099 posts in 2423 days
#4 posted 01-19-2013 08:10 PM
Most shelves that I see with sag are because the unsupported span is too long. You can go more than about 2’ by beefing things up but if you stick with short spans and shelves at least 3/4” thick you run a lot less risk of sag, even when heavier objects like books are placed on the shelves.
View Gene Howe's profile
Gene Howe
11138 posts in 3664 days
#5 posted 01-19-2013 09:07 PM
MJCD has the solution. I over build and usually face both edges with 3/4 X 1 1/2” solid.
sawedoff
#6 posted 01-19-2013 09:15 PM
MJCD and Gene,
so you guys use ply and then rip a face frame solid piece to put on the front edge of the plywood shelf? How are you fastening it? pocket screws or finish nails?
Gene Howe
#7 posted 01-19-2013 10:53 PM
I usually just use Tite Bond. Nothing has come apart yet. :-)
The bookshelves in our home have various spans up to 4’ with no supports. All over 12 years old and none have sagged and all are loaded!
It’s always been my theory that nails or screws simply replace clamps until the glue dries, anyway.
sawedoff
#8 posted 01-19-2013 11:06 PM
Gene,
That’s with plywood? Sounds like that’s what I’m probably going to go with
View SamuraiSaw's profile
SamuraiSaw
515 posts in 2199 days
#9 posted 01-19-2013 11:06 PM
I prefer plywood. There is little strength advantage (if any) of solid over plywood. But solid does have inherent disadvantages such as warping and cupping.
I usually cut a shallow rabbett, say 1/4”, in 1 to 1 1/2” stock to add strength and mask the raw plywood edge. The rabbett provides greater glue area.
-- Artisan Woodworks of Texas.... www.awwtx.com
Gene Howe
#10 posted 01-20-2013 12:21 AM
Yep, plywood. I’ve never done as SamuraiSaw suggests, but it sounds like a good method.
View MJCD's profile
MJCD
#11 posted 01-20-2013 03:50 AM
Sawedoff:
I use the table saw (or Router) to create a 1/4” wide x 3/8” deep dado on the front-edge of the ply; then create a mating tongue in the edging: the 1” x 1” is the non-inset piece of the hardwood. I secure this with T2 (Titebond II). This approach is a bit more woodworking than a simple edging; however, it provides significant strength, and will not come apart.
I hope this helps.
MJCD
View bondogaposis's profile
bondogaposis
5149 posts in 2586 days
#12 posted 01-20-2013 04:42 PM
Ply is ok for 2 ft spans but I would reinforce it with edges of hardwood. It somewhat depends on what you intend the shelves to support, books are heavy, bric a brac not so much.
-- Bondo Gaposis
View Woodknack's profile
Woodknack
12455 posts in 2615 days
#13 posted 01-20-2013 07:18 PM
sawedoff
#14 posted 01-20-2013 07:54 PM
Rick…........ Way cool. Thanks Man!
