Moisture Meters
Forum topic by CaseyJones posted 01-19-2013 06:54 AM 875 views 0 times favorited 2 replies Add to Favorites Watch
View CaseyJones's profile
7 posts in 2238 days
01-19-2013 06:54 AM
I’ve narrowed it down to the Lignomat Mini or the Delmhorst J-Lite…...which one do y’all like the best?
2 replies so far
View Scsmith42's profile
125 posts in 2613 days
#1 posted 01-20-2013 02:14 AM
Both are good meters from great companies; you won’t go wrong with either one for basic woodworking. If you are going to be more involved with drying, you need to consider a meter that has species and temperature correction built into it, such as the higher end Delmhorst meters.
-- Scott, North Carolina,
View MonteCristo's profile
2099 posts in 2124 days
#2 posted 01-20-2013 03:17 AM
I wouldn’t agonize overly with choice of moisture meter. Get one that has a good rating but don’t be surprised when you find that moisture readings vary quite a bit within the same board. That is, it’s not as simple as one might hope, and even a $400 meter only gives you a good idea of the actual moisture content. Like Scsmith42 says, the better meters account for species but even then it’s not bullet proof. I think they likely only react to density differences and my guess is that there’s a bit more to it than that.
What I do is meter the wood and then keep checking it until the readings stabilize. I write on the board with chalk and meter the very same places time after time.
